D3K Posted September 19, 2012 Posted September 19, 2012 (edited) As I've stated in other topics earlier, I recenty got back into Technic, and I'm finally starting to get enough pieces to make my own creations! I thought I'd make a thread where I can show off my stuff (hope that's okay), and hpefully get some feedback, critisism and tips on improvements from the EuroBricks Technic community. As I'm just starting to get used to the whole studless construction techniques, I hope you're not expecting miracles just yet, but hopefully we'll get there in due time! (btw love the lego emoticons!) So here it is; my very first MOC! (Still a very much work in progress) I'm not quite sure what kind of vehicle this would classify as, it's not a hot rod, and it's not a buggy, and definately not a tractor, but something inbetween! The features I've managed to implement are: -RC drive via two PF-M motors linked together via differential -RC steering via one PF-M motor (with working steering wheel) -Inpendent double wishbone front suspension -Pendular suspension + shock absorber on the rear axle -Opening hood View of the steering. Found out I'd add the steering wheel after I had already installed the battery box, so I had to do a somewhat intricate bypass solution there It works allright though! No self centering though.. yet! A view of the rear suspension setup, as well as axle. I only have one differential yet (actually got it by accident when I bought the 8043 secondhand), but more are on the way! I know the entire rear of the car/buggy/tractor/hotrod looks very empty, but as I said; a work in progress! View of the front suspension and temporary grille. The shocks here defiantely have to be of the harder type. On the way! The entire front can come off pretty easily to make modifications. Bottom view of the drivetrain, as well as the vertical placement of the motor for the steering. Overall I'm happy with the result so far! Things are working, and the structure seems solid enough! I just spent a couple hundred Euros on bricklink ordering new pieces, among them new differentials, harder shocks, bigger wishbones and wheel hubs for the front, an XL-motor ++ lots of other things that'll come in handy in the future! So what do you think? Edited October 22, 2012 by D3K Quote
Edwin Korstanje Posted September 19, 2012 Posted September 19, 2012 (edited) Nice Wip Moc already. At the first i thougt it must be a hotrod, but when i look longer and see the back it's olso could be a Stockcar, only the roll cage is missing. Keep going your good work and let us now off your progess Edit: I find some video what i mean of the first looks at your WIP what came up at mine mind Iceland offroad racing whit V8 stockcars Edited September 19, 2012 by VFracingteam Quote
D3K Posted September 19, 2012 Author Posted September 19, 2012 Yeah, I remember seeing that episode of Top Gear, and you're right, there are definately some similarities! Maybe I'll use one of those Icelandic "formula offroad" cars! And thanks for the positive feedback!:-) Quote
mike_125 Posted September 20, 2012 Posted September 20, 2012 (edited) Nice MOC, now find a way to drive over water Edited September 20, 2012 by mike_125 Quote
D3K Posted September 22, 2012 Author Posted September 22, 2012 Done some minor reorganizing on the vehicle: As you can see I have relocated the battery box towards the rear, and added a differential to the rear axle. I have also added a small V4 engine (don't have any more cylinders yet ) Also, I found a way to make the front shocks twice as hard while awaiting new, hard shock absorbers: And lastly I implemented a simple 1+N gearbox, just to let the fake engine run while the actual vehicle doewn't! Looking at the thing now, I realize it's extremely wrongly scaled . I think I will dismantle the entire thing, and start more or less from scratch, to make something similar, but smaller, hopefully in the scale of the Technic Minifigs which I found a couple of! Quote
Carsten Svendsen Posted September 22, 2012 Posted September 22, 2012 Looking at the thing now, I realize it's extremely wrongly scaled . I think I will dismantle the entire thing, and start more or less from scratch, to make something similar, but smaller, hopefully in the scale of the Technic Minifigs which I found a couple of! It still looks awesome though Quote
D3K Posted September 27, 2012 Author Posted September 27, 2012 (edited) New MOC/WIP: I can't remember to have seen a BV206 or Viking type tracked vehicle made in Lego, except for the B-model of the snow groomer, so I thought I'd try to make one, motorized, and with realistic drive/steering. And this is my progress after a couple of hours intensive work this morning: As you can see, I need some more track links, and also a couple of more drive sprockets. It features drive on all four (three) tracks by one PF-XL motor, and steering via a PF-M motor and to small linear actuators. Haven't decided whether to have the battery box in the front or back yet, if it goes in the back, I'll probably reposition the XL motor to be able to implement seats and a more realistic driver's compartment. A close up of the steering: The real thing is steered in a similar way, with hydraulic actuators. I had to use a small turntable to get it to work properly, this function is also still a WIP, but at least it works as it is now! View of the underside with drivetrain Edited October 22, 2012 by D3K Quote
efferman Posted September 27, 2012 Posted September 27, 2012 (edited) maybe no heagglund, but one kaegglund was made by me i think you dont need to drive both ends of the tracks on the front parts. the front end of the tracks is enough. or is this only an failure in my optical systems? Edited September 27, 2012 by efferman Quote
Jan Posted September 27, 2012 Posted September 27, 2012 New MOC/WIP: I can't remember to have seen a BV206 or Viking type tracked vehicle made in Lego, except for the B-model of the snow groomer, so I thought I'd try to make one, motorized, and with realistic drive/steering. I don't know if you have seen this before, but Eurobricks member Mahjqa made several versions of that type of vehicle. Might be interesting for you mahjqa's photostream Quote
jorgeopesi Posted September 27, 2012 Posted September 27, 2012 I was so impressed with this video and the rubber tracked vehicle. Quote
D3K Posted September 29, 2012 Author Posted September 29, 2012 Heh, I didn't really look for similar models, I just couldn't remember having seen them i think you dont need to drive both ends of the tracks on the front parts. the front end of the tracks is enough. or is this only an failure in my optical systems? When I first looked at the driveline I too thought I mistakenly had put a drive on the rear sprockets of the front cab, but it's just coincidentally in line with them, as this is where the vertical axle from the motor comes down and onto the axle before it is split to go to the front and back. Have put this project on hold for the moment, as I am working on a new buggy-rod-tractor. Have got a lot of new pieces from bricklink, so I can implement some functions I couldn't earier. Will post pics later! Quote
Alasdair Ryan Posted September 29, 2012 Posted September 29, 2012 you have made good progress D3K. I look forward to seeing it finished. Quote
D3K Posted October 3, 2012 Author Posted October 3, 2012 (edited) Track links haven't arrived yet, so the tracked carrier is on hold for the time being.. Luckily, many other parts have indeed arrived, including new steering joints, fake engine cylinders, gears, connectors, liftarms and bricks, so I continued my quest towards vreating a better buggy-rod (I think that's what I'll refer to it as from now on). Here it is, more or less complete and in working condition! A lot of improvements, most notably to the aestethics and overall scale of the thing, but also vastly improved steering due to new ball joints, and stiffer shocks The only thing identical to the first version, is the actual hood, but here I've had to make a hole for the steering motor, which doubles as a fake supercharger of sorts... Also, a full V8 engine! Finally! View from the front. Finally found a place to use my PF lights! View of the interior. Seats are more or less in scale with the rest og=f the vehicle this time around. Went for a racing bucket style type Drivetrain and bottom Rear suspension and differential setup. Used bevel gears instead of universal joints this time to get through the turntabble. Not sure if it was necessary. THis is the main part that I think I'll have to redo, but it was getting late, and I needed to sleep! So what do you think? Edited October 22, 2012 by D3K Quote
D3K Posted October 12, 2012 Author Posted October 12, 2012 Got some portal axle hubs from BrickLink yesterday, so had to try it out. THe geometry is maybe a bit weird, but it raises the ground clearance, which was needed due to the placement of the XL motor (see last post). Also, put in a U-joint instead of the bevel gear setup, as it was slipping. Quote
D3K Posted October 21, 2012 Author Posted October 21, 2012 Ok, new project: Ring a bell, anyone? How about now: Quote
Lauris Posted October 21, 2012 Posted October 21, 2012 Looks like recreation of legendary claw-rig or 9397 mod Quote
D3K Posted October 21, 2012 Author Posted October 21, 2012 And you are ofcourse right! I am trying to recreate the 8868 Airtech Claw Rig in studless! The three main goals I have for this project are 1. To keep the original functions as they were on the 8868 2. To make it look like a "new" set (in the same style as the sets coming out these days) 3. To still make it instantly recognizable as the legendary Airtech Claw RIg Made some progress the last couple of hours: On a roll now, probably won't get much sleep tonight Quote
timslegos Posted October 21, 2012 Posted October 21, 2012 On a roll now, probably won't get much sleep tonight The lack of sleep always improves one's building abilities . Good luck, it looks great so far. tim Quote
D3K Posted October 22, 2012 Author Posted October 22, 2012 The lack of sleep always improves one's building abilities . Good luck, it looks great so far. tim Indeed, it does! But unfortunately I have to go and get educated early in the morning, so I think I'll call it the day now.. This is the current state of things: Quote
D3K Posted October 22, 2012 Author Posted October 22, 2012 (edited) Been working some more on it today: Also, from the back: I know the original 8868 did not have mudguards (or whatever it's called) on the rear wheels, but I really liked the way these turned out, so I left them on. Anyways, here's a picture without them: And lastly, I've been adding some seats and a steering wheel, as well as the steps to get up into the truck (under the valves), and also the white things on the sides of the hood and the white vertical exhaust pipes. FUN FACT: All the white parts I've used (the exhaust pipes, fuel tank and hood thingies) are from the actual 8868 set I got about 20 years ago!! Also, the reason I am doing this particular build now, is I found the instructions manual in the back of a closet here the other day! Edited October 22, 2012 by D3K Quote
timslegos Posted October 22, 2012 Posted October 22, 2012 Those fenders look nice. I hope to see a video when it is done. tim Quote
D3K Posted October 23, 2012 Author Posted October 23, 2012 The project is finished View from the front: Without the grille and fender. You can see the setup for the fake V6 is siilar to the original. Bottom view, drivetrain and pneumatic system Driver's cabin (with driver) Placement of the compressor system (under the cabin) Finally, a video of the truck: Quote
legomuppet9 Posted October 23, 2012 Posted October 23, 2012 Looks very good in studless, well done Quote
D3K Posted November 2, 2012 Author Posted November 2, 2012 I have the 8053 Mobile Crane, and love the chassis of that model, but the crane part seemed not so well thought out (except for the gearbox, which is brilliant). I have drooled over the 8421 for some time, because of the great looking three stage crane, but I really don't like the chassis of the model! Recently I had the chance to buy an 8421 reasonably cheap, but decided not to (I instead bought an 8455, even cheaper!!). But I always wanted to make at least the crane part of the huge model! So I though; what if both cranes, 8421 and 8053 had a love child? Take the best parts of both parents, and make something great? Well, here goes: I don't have the pneumatic cylinder coupler brackets, so I instead used old, flat bottomed, cylinders. Also, just one pair seemed a little weak, so I put two in. I also had to redesign the rear of the superstructure to better accomodate the PF battery box and XL motor, as I do not have a buggy motor or yellow battery box either. Anyways, I'm pretty pleased with the result! The crane might look a little big, but I don't think it is TOO big! Quote
DLuders Posted November 2, 2012 Posted November 2, 2012 WOW, that is a beautiful "love child" 8421+8053 hybrid mobile crane! Do you plan on making a video of it in action? Quote
