Posted September 20, 201212 yr Does anyone have a lead on a substitution for the lego 3mm rigid hose here in the USA. i'm looking for a whole role of 25' or more. thanks, bob
September 20, 201212 yr You can get thin curtain rail from good DIY shops.It should be about 3mm thick. Edited September 20, 201212 yr by Alasdair Ryan
September 20, 201212 yr Author thanks guys. i just bought a 50M role on ebay. i trying my hand at a GBC module. hopefully it turns out so i can take it to BrickCon in a few weeks. bob
September 20, 201212 yr thanks guys. i just bought a 50M role on ebay. I'd like a link to that one please
September 20, 201212 yr Author I'd like a link to that one please this is what i got. they only had 1. bob
September 21, 201212 yr I found these hoses instead: http://www.airlines-pneumatics.co.uk/webcat/Detprod.asp?ProductCode=S08000105∏=
September 22, 201212 yr I found these hoses instead: http://www.airlines-pneumatics.co.uk/webcat/Detprod.asp?ProductCode=S08000105∏= Looks good and not a bad price, I was looking for 7mm before and never found any, any one got any ideas Edited September 22, 201212 yr by kieran
September 24, 201212 yr Author I found these hoses instead: http://www.airlines-pneumatics.co.uk/webcat/Detprod.asp?ProductCode=S08000105∏= this stuff might work better. the tube i bought got here and it is not rigid. it is very soft and very bendable. it's not going to work the way i wanted it to. bob
September 25, 201212 yr this stuff might work better. the tube i bought got here and it is not rigid. it is very soft and very bendable. it's not going to work the way i wanted it to. bob well I ordered a role so will let you know how it works out.
September 25, 201212 yr well I ordered a role so will let you know how it works out. I ordered one too last week so I'm just waiting
September 25, 201212 yr I ordered one too last week so I'm just waiting I went for Black, you? if you got blue we could maybe exchange a bit of each?
September 25, 201212 yr I went for Black, you? if you got blue we could maybe exchange a bit of each? Nope, I've got black too
September 25, 201212 yr Also note that for full compatibility (eg. fixing in clips), the tube should have an external diameter of 3.2mm, not 3.0mm
September 25, 201212 yr Also note that for full compatibility (eg. fixing in clips), the tube should have an external diameter of 3.2mm, not 3.0mm .2 mm? That's so little that I wouldn't even notice it! Besides, I'm gonna put in inside a thousand of 1/4 pins so I don't care about that small fact. Still nice to know though....
September 25, 201212 yr Author Also note that for full compatibility (eg. fixing in clips), the tube should have an external diameter of 3.2mm, not 3.0mm The 3.0mm OD i got held just fine in clips. even though it was softer. bob
September 26, 201212 yr Mine arrived, it does not hold all that well and its clear not black. Oh well keep looking
September 26, 201212 yr Mine arrived, it does not hold all that well and its clear not black. Oh well keep looking It's clear? Oh well, It's not like I can't build a track just because of that
September 27, 201212 yr It's clear? Oh well, It's not like I can't build a track just because of that Looks like we have the same idea, I do a bit the GBC and wanted to build a track still as you say it will be ok.
September 27, 201212 yr I think PFTE tubing is going to work better than vinyl tubing. you have to search for 1/8" OD (outer diameter), which is 3.2mm. maybe some sort of Teflon PFTE tubing like this one: http://www.store.cle...lon-Tubing.html or something like this: http://www.coleparme...ack/EW-06605-27 I do think it's important to have a thick wall and the ID (inner diameter) be as small as possible. Edited September 27, 201212 yr by Strikeman
September 27, 201212 yr Looks like we have the same idea, I do a bit the GBC and wanted to build a track still as you say it will be ok. I'm not planning on building a track for GBC but something very different. I think PFTE tubing is going to work better than vinyl tubing. you have to search for 1/8" OD (outer diameter), which is 3.2mm. maybe some sort of Teflon PFTE tubing like this one: http://www.store.cle...lon-Tubing.html or something like this: http://www.coleparme...ack/EW-06605-27 I do think it's important to have a thick wall and the ID (inner diameter) be as small as possible. The bend-ability on the hoses ordered is really great, just like the LEGO hoses. But you are right, 3.2mm is better since this hose is sliding inside the pins. I don't mind that though, it's still perfect for my purpose. The last tubing you linked to is really expensive so that's a no-go. I have no idea what material to look for so you could easily fool me.
September 2, 20168 yr ...have similar hoses to your requirements Becoming a member just to bump a four year old topic, to do promotion, is against site guidelines in multiple ways.
