UrbanErwin Posted June 24, 2013 Posted June 24, 2013 Thanks to Colin Redner I've found them, they are under the motors Quote
Calabar Posted June 24, 2013 Author Posted June 24, 2013 I see. Parts results with Part IDs 75541 and 75542. Very strange, because I found 53404 and 53407 from LEGO references. Quote
JSN Posted July 3, 2013 Posted July 3, 2013 Hi, I am trying to find this part http://www.bricklink...Item.asp?P=4865 in LDD but can't find it in any of the categories so any help would be much appreciated. Thanks, John Quote
Sebeus I Posted July 3, 2013 Posted July 3, 2013 (edited) Yes, that's confusing in LDD (extended). It's not in the category 'panels' but you'll find it in the category 'doors and windows'. If you still don't find it try searching "wall element 1x2x1", I hope this helps. Edited July 3, 2013 by Sebeus I Quote
JSN Posted July 3, 2013 Posted July 3, 2013 What a random place to put it! Thank you for your help Sebeus I! By the way is there any way to put a minifig in a seated position or can they only stand up? Quote
Philo Posted July 3, 2013 Posted July 3, 2013 (edited) Just type in the reference (4865) in the search box! Or search for official LEGO name ("wall element") (Edit : sorry, I'm late ;) Edited July 3, 2013 by Philo Quote
Classicsmiley Posted July 3, 2013 Posted July 3, 2013 What a random place to put it! Thank you for your help Sebeus I! By the way is there any way to put a minifig in a seated position or can they only stand up? You can seat a minifig by using the hinge tool on the legs. Quote
Steven L Posted August 20, 2013 Posted August 20, 2013 Maybe not a bug, but I'm missing a piece. Where are the 2x2 turntables? I think the blue/gray version is number 4219825. Quote
DrJB Posted August 29, 2013 Posted August 29, 2013 Tried all the advice in prior posts, but can't locate part # 57702 ... Any hint or is it non-existent? Quote
pbat Posted August 31, 2013 Posted August 31, 2013 Tried all the advice in prior posts, but can't locate part # 57702 ... Any hint or is it non-existent? 57702 is not (yet) included in LDD. You may file a request in this thread. Quote
Takanuinuva Posted September 5, 2013 Posted September 5, 2013 Hey does this piece exist in LDD. http://www.bricklink.com/catalogItem.asp?P=2711, I know its counterpart exists in LDD http://www.bricklink.com/catalogItem.asp?P=32124 Quote
pbat Posted September 5, 2013 Posted September 5, 2013 Hey does this piece exist in LDD. http://www.bricklink...Item.asp?P=2711, I know its counterpart exists in LDD http://www.bricklink...tem.asp?P=32124 Nope, the first one is not (yet) in LDD: This part was discontinued 2003, whereas the latter is still in use. You may, however, file a request in this thread to get it added with a future update. Quote
murmillo Posted September 9, 2013 Posted September 9, 2013 Hello! Help me pls find this parts from Lego WeDo: http://www.bricklink...em.asp?S=9583-1 http://www.bricklink...em.asp?S=9581-1 I can't find it in LDD Quote
Calabar Posted September 9, 2013 Author Posted September 9, 2013 Hi murmillo, and welcome at Eurobricks. Did you tried the suggestions proposed in the first post? Anyway, looking at the brickset inventory of the lego WeDo set, the parts you linked are not present. As that inventory has been retrieved directly from LEGO site these parts are not there, and that means that probably you can't find that in LDD too. Quote
murmillo Posted September 10, 2013 Posted September 10, 2013 Anyway, looking at the brickset inventory of the lego WeDo set, the parts you linked are not present. As that inventory has been retrieved directly from LEGO site these parts are not there, and that means that probably you can't find that in LDD too. Thanks. These parts are supplied in the WeDo set (see this pdf): WeDo Robotics Motion Sensor NOT present in LDD WeDo Robotics USB Hub NOT present in LDD Electric, Motor 9V Power Functions PRRESENT in LDD Why? P.S. I found all in LDraw, that seems more complicated than LDD Quote
Philo Posted September 10, 2013 Posted September 10, 2013 Indeed, they are available for LDraw 'cause I modelled them ;) The WeDo tilt sensor is there too. P.S. I found all in LDraw, that seems more complicated than LDD Please try SR3DBuilder, it should make it easier to use! Have a look at Sergio's too. Quote
murmillo Posted September 10, 2013 Posted September 10, 2013 Indeed, they are available for LDraw 'cause I modelled them ;) The WeDo tilt sensor is there too. Incredible work! Please try SR3DBuilder, it should make it easier to use! Have a look at Sergio's too. Thanks! I will try to.. Quote
legolijntje Posted September 10, 2013 Posted September 10, 2013 Thanks! I will try to.. 1 tip: change the "LDD like rotation mode". In my experience it is way easier than the normal rotation mode in sr3d (especially if you're coming from LDD). If you start using SR3D, you change it to "LDD like rotation mode" in View>User Interface>Rotation mode. Quote
Crist Clapper Posted January 9, 2014 Posted January 9, 2014 How do I get this item added to the LDD? Dark Bluish Gray Vehicle, Mudguard 4 x 2 1/2 x 2 with Arch Round Quote
pbat Posted January 9, 2014 Posted January 9, 2014 How do I get this item added to the LDD? Dark Bluish Gray Vehicle, Mudguard 4 x 2 1/2 x 2 with Arch Round Use the extended mode, as described here. Then switch the colour to 199 (bricklink's dark bluish gray has the LEGO COLOUR ID 199, see the Peeron Colour Chart) and enter the number 50745 in the parts search box. Voilà. You also should have a look at the LDD reference thread. tl;dr: RTFM Quote
Crist Clapper Posted January 9, 2014 Posted January 9, 2014 Use the extended mode, as described here. Then switch the colour to 199 (bricklink's dark bluish gray has the LEGO COLOUR ID 199, see the Peeron Colour Chart) and enter the number 50745 in the parts search box. Voilà. You also should have a look at the LDD reference thread. tl;dr: RTFM Got it... Thanks! Now a basic problem... How the heck do I rotate and individual item? Quote
pbat Posted January 9, 2014 Posted January 9, 2014 Got it... Thanks! Now a basic problem... How the heck do I rotate and individual item? Arrow keys for 90˚ rotations. Or the rotation tool (available via the 'H' hotkey) for individual rotations. Please also try to press F1 for the manual, where such basic questions are already answered. Quote
