Endgame Posted December 1, 2012 Author Posted December 1, 2012 "When Punii washed up, I made the mistake of making eye contact with him. You see, the medbay, where I was getting Intel, is just beyond that door. Punii washed up, I made eye contact, they put two-and-two together. And now we're both here. And no, there is no key." Elgar lacks a Garnet, so he can't bend the bars. Also, see what Punii said above about explosions and magic. Quote
Dannylonglegs Posted December 1, 2012 Posted December 1, 2012 "When Punii washed up, I made the mistake of making eye contact with him. You see, the medbay, where I was getting Intel, is just beyond that door. Punii washed up, I made eye contact, they put two-and-two together. And now we're both here. And no, there is no key." Elgar lacks a Garnet, so he can't bend the bars. Also, see what Punii said above about explosions and magic. "Well, how'd you get in there?" Quote
TheBoyWonder Posted December 1, 2012 Posted December 1, 2012 "We need to break Punii out. Any ideas apart from Magic or explosions which would kill them. Quote
Dannylonglegs Posted December 1, 2012 Posted December 1, 2012 (edited) "We need to break Punii out. Any ideas apart from Magic or explosions which would kill them. "Well, I want to know how they got in there to start with." stated Sylph, annoyed. "If there's no door and no key, did a mage make this jail-cell?" Edited December 1, 2012 by Dannylonglegs Quote
Endgame Posted December 1, 2012 Author Posted December 1, 2012 "There are some insane proggs in there. So, they have a Progg Guardian in there to keep them in check - and to keep them from killing the nurse. When he found out that I was a traitor, he grabbed us, the nurse drugged us with something... and we woke up in here. I don't think this prison was meant to be exited or entered when the prisoners were inside... and I have no clue how it is here." "There are some broken ship parts over *wheeze* there. maybe you can use 'em?" Punii points to a secluded corner of the room. Sifting through the junk, they create an orderly pile. Lycan also rips some sticky Oozeling remains off his clothes and puts them into the pile. -Big plank -2 little planks -Average-sized barrel -2 oars -Piece of a sail -Brown bungee cord -Empty bottle -Green Rope -2 Oozeling remains (can be used as adhesive.) QM Note: Time to get creative, 48ers! Quote
Bricksandparts Posted December 1, 2012 Posted December 1, 2012 OoC: Are we actually building with legos, or are these pieces theoretical? First some preparations: Johon uses his pick axe to mine some stone from the wall, while be careful not to disturb the stalactites. "First off, we need to block off that door. We can also use some rocks as projectiles." Quote
Endgame Posted December 2, 2012 Author Posted December 2, 2012 QM Note: Theoritical. Johon only gets one stone the size of his fist out, knowing too much more and the two proggs would die. "Why would you block the door to the medbay? may be our only way out of this cavern..." Quote
Dannylonglegs Posted December 2, 2012 Posted December 2, 2012 QM Note: Theoritical. Johon only gets one stone the size of his fist out, knowing too much more and the two proggs would die. "Why would you block the door to the medbay? may be our only way out of this cavern..." "Unless anyone has any ideas, eroding the rock with water magic may be an option. I'm still unsure as to what we can do without releasing the stalactites." Quote
Bricksandparts Posted December 2, 2012 Posted December 2, 2012 "Hmm. We could use the stalactites to our advantage." Johon draws out his Idea in the dirt trying to explain his concept. "We can use leverage to bust the bars. We will try and hit stalactites into the barrel to use as force." Concept Quote
Dannylonglegs Posted December 2, 2012 Posted December 2, 2012 "Hmm. We could use the stalactites to our advantage." Johon draws out his Idea in the dirt trying to explain his concept. "We can use leverage to bust the bars. We will try and hit stalactites into the barrel to use as force." Concept "Hmmm... That's so crazy that it might just work." Stated Sylph, intrigued. "I can't see what you drew in the sand though." Quote
Endgame Posted December 2, 2012 Author Posted December 2, 2012 QM Note: B&P, can you please elaborate in words or make the picture public? Quote
Bricksandparts Posted December 2, 2012 Posted December 2, 2012 OoC: Oh, oops. I believe this should work. Quote
Endgame Posted December 2, 2012 Author Posted December 2, 2012 QM Note: So basically you're filling the barrel with rock and smashing it into the bars? Quote
Bricksandparts Posted December 2, 2012 Posted December 2, 2012 (edited) OoC: Using the force of the falling stalactites to break the bars, freeing our friends. Edited December 2, 2012 by Bricksandparts Quote
Endgame Posted December 2, 2012 Author Posted December 2, 2012 QM Note: I can allow that... just come up with a way to drop a stalagtite on the barrel without also dropping the ones in the cell. Quote
Bricksandparts Posted December 2, 2012 Posted December 2, 2012 (edited) "Hmm... Sylph, try and summon some vines to hang onto the stalictites in the cell, then we can throw a rock or have a vine jiggle a stalactite loose onto the barrel." Edited December 2, 2012 by Bricksandparts Quote
Dannylonglegs Posted December 2, 2012 Posted December 2, 2012 (edited) "Hmm... Sylph, try and summon some vines to hang onto the stalictites in the cell, then we can throw a rock or have a vine jiggle a stalactite loose onto the barrel." "Alas, I cannot." sighed Sylph. "But Elgar can. Let's do it." Edited December 2, 2012 by Dannylonglegs Quote
Fugazi Posted December 2, 2012 Posted December 2, 2012 "Hmm... Sylph, try and summon some vines to hang onto the stalictites in the cell, then we can throw a rock or have a vine jiggle a stalactite loose onto the barrel." "We can either tie a pickaxe to an oar and hope to reach the stalactite that way, or I can throw the Goblin Wrench at it -- I'm good at aiming with throwing weapons." Quote
TheBoyWonder Posted December 2, 2012 Posted December 2, 2012 "I can also help with my Throwing Dagger." Quote
Bricksandparts Posted December 2, 2012 Posted December 2, 2012 Johon picks up the stone he mined. "I'd rather not have one of you guys possibly lose your weapon, let me throw this rock at it. It was a sort of sport at my second home." Quote
Capt.JohnPaul Posted December 2, 2012 Posted December 2, 2012 Alexandre examines the drawing in the dirt. "Impressive, I'd never have thought of such a thing. Though I'm not sure how good a rock will be at bringing down the stalactite. I thing the pickaxe or using a vine will be better." Quote
Endgame Posted December 2, 2012 Author Posted December 2, 2012 Johon lobs a rock at the Stalagmite. It falls squarely into the barrel of the contraption he made, the force from the falling stalagmite causing the other side to flip up like a demented teeter-totter. The sturdy plank smashed through the bars, freeing the two prisoners! The two Proggs stroll out of their prison, relived they had their freedom back. "Thanks a lot. With my missing arm, I'm not exactly built for combat, but swing by the burrow later and we'll give you a free sample of our new venom. I'll wait here for you to find an exit." "Thanks *wheeze* a bundle, heroes! I'll try to best to carry my weight from now on." Punii had rejoined the party! Galen relinquishes the Blast jellies they had gotten from the Oozelings. The Party: Sylph Solanum (Dannylonglegs) *Party Leader!* unknown age, unknown race Druid Level 18.5 Power: 26 (18+7+1) Defense: 0 Health: 34/34c(9+17+7+1) Ether: 19/22 (5+16+1) Gold: 64 Equipment: Merry Bow (WP:7, ranged, steals 1 gold with each successful hit except Shield-skills), Ranger's Quiver (WP +1 to bows and crossbows), Helmet (Max. health +1) 20-20 glasses Inventory: Mockthril Rod (WP:7), Scroll of Frailty, Scroll of Sleep, Scroll of Blindness, Scroll of Sealing, Scroll of Confusion, 1 Potions, 1 Grand Potion, Tonic x2, Grand Tonic, Remedy, 2 Venoms, Smoke Bomb, 2 Fire Bombs, 2 Ice Bombs, 3 Water Bombs, 2 Lightning Bombs, Floral Bomb, Bedroll, Shovel, Pickaxe, Magnifying Glass, 8 Bones, Signet Ring, Saber Teeth, Crumbling Venom, Journal of The Bleeding, Sword Fragment (1), Smelling Salts x2, Helmet (Max. health +1) Johon [AKA Alf Gregory] (Bricksandparts) 25 years old male human Barbarian > Raider Level: 20.5 Power: 28 (20+8+0) Health: 35/35 (19+8+1+7+0) Shield Power: (1 + 5) Ether: ~/0 Positive effects: *Immune to:* (*Fragile*, *Cursed*), *Natural Respite* Negative effects: (none) Gold: 385(186G(1), 0GB(50), 0CB(50), 0GO(80), 0CC(70), 0GC(100), 0M) Equipment: Dog Statuette - (suitable for anyone, SP: 1, once named (Rover), speaking the name summons a dog almost certainly to tag along on madcap adventures and make snippy comments.), Sword of Decay (WP:8)(once the target is inflicted with damage they lose a quarter of the power of the strike each following turn for three turns. the effect cannot be compounded with more strikes. Suitable to Mages, Knights and Barbarians.) Hide of The Bleeding (Backwear, restores 10 HP and 5 ether for every enemy the wearer kills, suitable for anyone) Heavy Armour – SP:5, protects from fragile-effect, suitable for barbarians and knights. Extra Artefacts: Helmet (+1 max health), Blessed Amulet – Protects from cursed-effect. Extra Weapons: Greatsword (WP:3), Meteor Blade (WP:8, Light elemental), Focal Staff (WP:5, Focus Fire-Roll a 3 for 5 ether Suitable for clerics and mages) Tools: Shovel (1), Pick-axe (2), Magnifying Glass (1), Magic Compass (1) Consumables: Potion (3), Grand Potion, Venom, Ice Bomb (1), Mead (2), Phoenix Essence (3), Trail Brew (1), Nostrum (2), Smelling Salts (2) Elements: Aquamarine (1), Emerald (1) Scrolls: Scroll of Sleep (1), Scroll of Blindness (1), Scroll of Sealing (2), Scroll of Confusion (1) Quest items: (None) Elgar Gligin (played by Jedi master Brick) Level 19 Evoker Power: 30 Defense: 0 Health: 27/27 Ether: 11/18 Gold: 420 Equipment: Mockthril Crossbow (WP:11) Inventory: Fauxthril Longbow (WP: 5),Smoke Bomb, Bedroll, Emerald, Sapphire, Topaz, Opal, ,3 Venoms, Spade,Pickaxe,3 Potions, Trickster's Mask of the Elf(Accessory, Changes user's appearance into an Elf),Scroll of Poisoning (Grants target’s weapon the badly poisoned effect for one battle at the cost of 5 ether) ,Goblin's Wrench(WP:10,retrievable), Needlessly Large Rod (Non-Artifact Item, Curses a random enemy. Usuable once per battle.) Does not prevent free hits. Grand Potion x2, Grand Tonic x3, Scroll of Sleep, Scroll of Blindness, Scroll of Confusion, Scroll of Sealing Alexandre le Chevalier (Played by Capt.JohnPaul) Level 17 Paladin, 20 year old elf male Power: 25 Defense: 13 Health: 24/37 Ether: 8/17 Gold: 91 Equipment: Sword of the Elven Blademaster (WP: 8; ignores SP), Cross Heater Shield (SP: 10) (Mail of the Renegade Commander (SP: 3; Damage of all Free Hits is halved; suitable for Knights and Barbarians) Inventory: Potions (4), Bedroll, Smoke Bomb, Tonic x2, Smoke Bomb, Fire Bomb, Potion, Remedy, Grand Tonic, Mead, Phoenix Essence, Deadly Poison, Scroll of Sealing Lycan Dean (played by theBoyWonder) *Encouraged!* *Hastened!* *Lucky!* Level 11 Rogue *Immune to weakened* Power: 22 Health: 3/15 Gold: 254 (95 gold owed to Thormanil and 30 to Loreal) Equipment: Combrys (WP: 8, consecutive successful strikes raise Combry's WP by 1, unsuccessful strikes drop it to it's base WP), Pugillist Gloves(Power +2, protects from weakened), Sylvania's Cowl(grants Animal Talk to Wearer) Inventory: Bedroll, Staff of The Frog Paladin (WP:6, 1/6 chance of Amphibianocs Blessing (protects from damage)), Throwing Dagger (WP6), Warhammer (WP:4), Deadly Venom x2, Venom x3, Phoenix Essence, Nostrums x3 Galen Woodward (Fugazi) 36 year old male human Rogue Level 14.5 Power: 24 (14+10) Defense: 2 (+2) Health: 24/24 (7+13+4) Gold: 506 Equipment: Murkwood Thread (WP: 10), Chimera Headdress (Headwear, Suitable for Rangers and Rogues, +1 SP +4 Health), Leather Armour (SP:1) Inventory: Fauxthril Shuriken (WP:5, ranged), Throwing Dagger (WP:4, ranged), Bedroll, Venom, Smoke Bomb, Bomb XX, Grand Potion x3, Remedy x3, Nostrum x4, Mead x4, Fire Bomb, Deadly Venom x2, Crumbling Venom, Goblin's Wrench(WP:10,retrievable), Black Katana (WP:8), Phoenix Essence, Smelling Salts x2, Trial Brew "Back in *wheeze* action!" Punii, 2 month year old Progg Alchemist Jellies: Green x5, Red x3, Blue x3 Will the party prepare before heading into the Medbay? Quote
Jedi master Brick Posted December 2, 2012 Posted December 2, 2012 Elgar gives his wrench to Galen before shouting "onwards" Quote
Dannylonglegs Posted December 2, 2012 Posted December 2, 2012 Sylph envenomed his arrows with one of his two venoms."Good work team, glad to have you back Punii. I'm sure we can chat about our experiences in the caves later. For now, let's get ready to take over the med-bay." Quote
Fugazi Posted December 2, 2012 Posted December 2, 2012 Galen eyes the medbay door warily. "Are we sure there's no other way out? I'm not specially keen on fighting a roomful of crazy Proggs -- not that most of them aren't crazy in their natural state, present company excluded!" Quote
