  • Replies 3.2k
Round Seven of the Battle With The Tentacled Terror
>Punii askes politely to be let go, Aquos just laughs at him
>Sylph heals Aquos (back): Lesser Heal Greater Heal (9x2=18+19=37 HP healed)
>Alex VS Right Tentacle C (front): Hit Critical Hit (10x2=20+18=38 damage)
>Lycan VS Right Tentacle A (front): Miss
>Johon takes a Nostrum (back)
>Johon VS Left Tentacle C (back): Hit Hit (8+21=29-2=27 damage, 6 damage decay placed)
>Elgar VS Hostage Tentace (back): Damage Hit (11+20=31x2=62-3=59 damage)
>Galen VS Hostage Tentacle (back): Miss Miss
>Galen VS Big Tentacle (back): Damage Miss
>Sylph VS Big Tentacle (back): Special Damage Aim (19-3=16 damage)
The grueling battle goes on. Sylph confuses Aquos with another heal, undoing all of the damage that had been given to him. Alex, Lycan, and Johon all hit their respective targets, Aquos leaving his atrget with only a speck of life in it. The decay that was imbued into the slimy arm by Johon soon caused the tentacle to wither and sink under the water, dead. Elgar flings a ball of ice at the the hosatge tentacle, taking care not to hurt the young alchemist in its grip. Galen misses twice -Sylph nearly does too, but he scores a lucky shot on the tentacle.
The cavern rumbles as Aquos pulls out his remaining arsenal.
kSClG.png"It'll only takes one streak of bad luck to send you to the grave, heroes."
Aquos, Level 28 Beast *Counterstriking!*
HP: 1055/1100
SP: 20
Ether: 20/30
Specials:
1-2: Tentacle Lash: Does 28 damage to the hero who rolled Special Damage. The heroes above and below him in the battle order take 14 damage.
3-4: Ruckus: The sound of Aquos's tentacles clapping shakes loose some stalagmites, causing them to fall on top of the party. All heroes take 11 damage, disregarding SP.
5-6: Rhythmic Rampage: Grabs the hero who rolled Special Damage with his tentacles and slams him into all of his party members. The entire party (including the hero who rolled Special Damage) takes damage equal to that Party Member's power.
7-8: Catastrophe Cacophony: Nullifies all of the party's positive effects, and does 28 damage to the hero who rolled Special Damage.
0: Tail Swing: With a swing of his monstrous tail, Aquos does 18 damage to the entire party. Every party member has a 1/2 chance of being stunned for one round. (Can be remedied or removed for 5 ether.)
Note: Aquos's specials are not randomized! The numbers before each special is how many tentacles Aquos must have up for him to use it. For example, if he has 5 tentacles revealed, he will always use Rhythmic Rampage. He will only ever use Tail Swing when he has no tentacle revealed.
Passive Specials:
Tentacle Guard: As long as Aquos has 1 tentacle up, he will be counterstriking.
Ethereal Immunity: Aquos is immune to all scrolls.
SP Constant: Aquos's SP can only be lowered by destroying his tentacles, and nothing else. Each tentacle destroyed drops his SP by 2.
Hanging on a Thread: Aquos can have a minimum of 1 HP when he still has tentacles active! All of his tentacles must be destroyed before Aquos himself can be. When Aquos dies, the battle is won.
Drops:
Peculiar Egg, Garnet
Left Tentacle B, Level 19 Beast *Badly Poisoned!*
HP: 88/250
SP: 1
Specials:
Musical Mugging: Perfectly aligned with the beat, the tentacle slaps the hero who rolled special damage, stealing gold and doing damage equal to the hero's WP + SP.
Stone Spike: Uses 4 of Aquos's ether to raise a spike of stone from the ground, doing 9 damage to the entire party, disregarding SP. If no ether left, nothing happens.
Specials decided by die roll.
Immune to Blindness and Sleep!
Drops:
30 gold, potion.
Note: When defeated, does an automatic 45 damage to Aquos and drops his SP by 2.
Big Tentacle, Level 23 Beast *Badly Poisoned!*
HP: 289/325
SP: 2
Specials:
Musical Grand Theft: Aquos steals gold and does damage to all heroes equal to each hero's SP + WP.
Tentalce Slam: Picks up the hero who rolled Special Damage and smashes him into the hero next in the battle order, doing 23 damage to both.
Immune to Sleep, Blindness, and Sealing!
Drops:
Phoenix Essence, Elixir, Trial Brew
Right Tentacle A, Level 18 Beast *Badly Poisoned!*
HP: 60/250
SP: 2
Specials:
Stone Wall: Uses 4 of Aquos's ether to raise a stone wall, halving all damage done to all enemies next round.
Immune to Blindness and Sealing!
Drops:
30 gold, tonic
Right Tentacle B, Level 19 Beast *Badly Poisoned!*
HP: 131/250
SP: 1
Specials:
Drops:
30 gold, tonic
Right Tentacle C, Level 20 Beast *Badly Poisoned!*
HP: 165/250
SP: 2
Specials:
Drops:
30 gold, tonic
Hostage Tentacle, Level 23 Beast *Holding Punii!*
HP: 244/325
SP: 3
Specials:
Kablammo: Uses Punii's bombs to detonate a devastating blast, doing 17 fire elemental damage to the entire party. The hero who rolled Special Damage has their SP granting items overheat from the blast, disabling their SP for the rest of the round and 2 after. (Unremediable and unremoavable.)
Rockslide: Uses 6 of Aquos's ether to generate a mighty rock slide, doing 13 damage to the entire party, disregarding SP. if no ether left, defaults to Kablammo.
Specials decided by dice roll.
Immune to Venoms, Blindness, and Sealing!
Drops:
Punii (usable the turn after he is freed), 60 gold
QM Note: Aquos has 8 different tentacles, and every round, he will raise different ones. It works off a cycle, a repeating pattern: if you can figure out which tentacles appear when, you will be able to strategize far more efficiently.
Tentacle Chart:
>Left Tentacle B: Level 19, HP: 88/250, SP: 1 *Badly Poisoned!*
>Big Tentacle: Level 20, HP: 289/325, SP: 2 *Badly Poisoned!*
>Right Tentacle A: Level 18, HP: 60/250, SP: 2 *Badly Poisoned!*
>Right Tentacle B: Level 19, HP: 131/250, SP: 1 *Badly Poisoned!*
>Right Tentacle C: Level 20, HP: 165/250, SP: 2
>Hostage Tentacle: Level 23, HP: 244/325, SP: 2
The Party:
ava-sylph.jpgSylph Solanum (Dannylonglegs) *Party Leader!* *Lucky!* *Hastened!*
unknown age, unknown race Druid
Level 19.5
Power: 27 (19+7+1)
Defense: 0
Health: 35/35c(9+17+7+1)
Ether: 13/23 (5+16+1)
Gold: 19
Equipment: Shrapnel Bow (WP: 9, Bow *Deadly Envenomed!*. Every successful hit drops the target's SP by 1) , Ranger's Quiver (WP +1 to bows and crossbows), 20-20 glasses (headwear, +1 turn of effect for scrolls)
Inventory: Mockthril Rod (WP:7), Scroll of Frailty, Scroll of Sleep, Scroll of Blindness, Scroll of Sealing, Scroll of Confusion, 1 Potions, 1 Grand Potion, Tonic x3, Venom, Smoke Bomb, 2 Fire Bombs, 2 Ice Bombs, 3 Water Bombs, 2 Lightning Bombs, Floral Bomb, Bedroll, Shovel, Pickaxe, Magnifying Glass, 8 Bones, Signet Ring, Saber Teeth, Crumbling Venom, Journal of The Bleeding, Sword Fragment (1), Smelling Salts, Helmet (Max. health +1), Quartz, Tale of the Invincible King, Psych Documents, Merry Bow (WP:7, ranged, steals 1 gold with each successful hit except Shield-skills), Journal of The Wound, Sword Fragment (2), Grand Tonic, Emerald
Johon [AKA Alf Gregory] (Bricksandparts) *Hastened!* *Lucky!*
25 years old male human Barbarian > Raider
Level: 21
Power: 29 (21+8+0)
Health: 22/36 (19+8+1+7+0)
Shield Power: (1 + 5)
Ether: ~/0
Positive effects: *Immune to:* (*Fragile*, *Cursed*), *Natural Respite*
Negative effects: (none)
Gold: 753 (186G(1), 0GB(50), 0CB(50), 0GO(80), 0CC(70), 0GC(100), 0M)
Equipment: Dog Statuette - (suitable for anyone, SP: 1, once named (Rover), speaking the name summons a dog almost certainly to tag along on madcap adventures and make snippy comments.), Sword of Decay (WP:8)(once the target is inflicted with damage they lose a quarter of the power of the strike each following turn for three turns. the effect cannot be compounded with more strikes. Suitable to Mages, Knights and Barbarians.) Hide of The Bleeding (Backwear, restores 10 HP and 5 ether for every enemy the wearer kills, suitable for anyone)
Heavy Armour – SP:5, protects from fragile-effect, suitable for barbarians and knights.
Extra Artefacts: Helmet (+1 max health), Blessed Amulet – Protects from cursed-effect.
Extra Weapons: Greatsword (WP:3), Meteor Blade (WP:8, Light elemental), Focal Staff (WP:5, Focus Fire-Roll a 3 for 5 ether Suitable for clerics and mages)
Tools: Shovel (1), Pick-axe (2), Magnifying Glass (1), Magic Compass (1)
Consumables: Potion (4), Grand Potion, Venom, Ice Bomb (1), Mead (2), Phoenix Essence (2), Trial Brew (1), Smelling Salts, Remedy, Nostrum, Dragon Scale (Lucky and blessed effects upon consumption)
Elements: Aquamarine (1), Emerald (1)
Scrolls: Scroll of Sleep (1), Scroll of Blindness (1), Scroll of Sealing (2), Scroll of Confusion (1)
Quest items: (None)
Elgar Gligin (played by Jedi master Brick) *Lucky!*
Level 20 Evoker *Immune to Fragile!*
Power: 31
Defense: 6
Health: 22/28
Ether: 8/19
Gold: 193
Equipment: Mockthril Crossbow (WP:11), Chainmail (SP: 2, Bodywear: half damage from Fire elemental damage and double from Electric elemental damage) Emerald Hood (SP: 4, headwear, protects from Fragile)
Inventory: Fauxthril Longbow (WP: 5),Smoke Bomb, Bedroll, Emerald, Sapphire, Topaz, Opal, ,3 Venoms, Spade,Pickaxe,3 Potions, Trickster's Mask of the Elf(Accessory, Changes user's appearance into an Elf),Scroll of Poisoning (Grants target’s weapon the badly poisoned effect for one battle at the cost of 5 ether) ,Goblin's Wrench(WP:10,retrievable), Needlessly Large Rod (Non-Artifact Item, Curses a random enemy. Usable once per battle.) Does not prevent free hits. Grand Potion x2, Grand Tonic x3, Scroll of Sleep, Scroll of Blindness, Scroll of Confusion, Scroll of Sealing, Fireworks, Remedy, Tonic, Dualis Scepters (WP: 8, Club/Staff, Dual-striking), Greasy Sausage (max health +2 when consumed)
alexandreavatar.png Alexandre le Chevalier (Played by Capt.JohnPaul) *Lucky!*
Level 18 Paladin, 20 year old elf male
Power: 28
Defense: 13
Health: 31/38
Ether: 5/18
Gold: 4
Equipment: Sword of the Elven Blademaster (WP: 10 *Deadly Envenomed!*; ignores SP, +1 gold per successful strike), Cross Heater Shield (SP: 10) (Mail of the Renegade Commander (SP: 3; Damage of all Free Hits is halved; suitable for Knights and Barbarians), Dapper Hat (Headwear, wearer has a 1/6 chance of becoming encouraged at the start of each battle)
Inventory: Potions (4), Bedroll, Smoke Bomb, Tonic x2, Smoke Bomb, Fire Bomb, Potion, Grand Tonic, Scroll of Sealing, Tonic
Lycan Dean (played by theBoyWonder)
Level 13 Rogue *Immune to weakened* *Immune to Stunned*
Power: 33
Health: 17/17
Gold: 0 (95 gold owed to Thormanil and 30 to Loreal)
Equipment: Combrys (WP: 14 *Deadly Envenomed!*, consecutive successful strikes raise Combry's WP by 1, unsuccessful strikes drop it to it's base WP), Pugillist Gloves(Power +2, protects from weakened), Scarlet Hood (Headwear, Power +4, Protects from Stunned)
Inventory: Bedroll, Staff of The Frog Paladin (WP:6, 1/6 chance of Amphibianocs Blessing (protects from damage)), Throwing Dagger (WP6), Deadly Venom, Venom x3, Sylvania's Cowl(grants Animal Talk to Wearer)
galen2.pngGalen Woodward (Fugazi) *Hastened!* *Lucky!* *Encouraged!*
36 year old male human Rogue
Level 15.5
Power: 25 (15+10)
Defense: 1 (+1)
Health: 25/25 (7+13+4)
Gold: 925
Equipment: Murkwood Thread (WP: 10), Chimera Headdress (Headwear, Suitable for Rangers and Rogues, +1 SP +4 Health), Leather Armour (SP:1), Hide of The Wound (+6 power to throwing weapons),
Inventory: Fauxthril Shuriken (WP:5, ranged), Throwing Dagger (WP:4, ranged), Bedroll, Venom, Smoke Bomb, Bomb XX, Grand Potion x4, Remedy x3, Nostrum x2, Mead x2, Fire Bomb, Deadly Venom x2, Crumbling Venom, Goblin's Wrench(WP:10,retrievable), Black Katana (WP:8), Phoenix Essence, Smelling Salts x2, Trial Brew, Goblin's Wrench(WP:10,retrievable), Cast, Potion, Leather Armour (SP:1), Soma, Stretchy Rubber Band (Accessory, returns thrown weapons immediately)
qi64g.png"HEEELLLP!"
Punii, 2 month year old Progg Alchemist *Hostage!*
Jellies: Blue x2, Green x2, Red x1
Edited by Endgame
QM Note: Will fix, TBW.
"You know, I must admit, I have been a rather back seat villain as of late. A bit of trivia for you disgusting little things: I'm the one who planned the rally. We had a Roast of Rhodus planned too, after all this invasion business was done, but that obviously isn't going to come to fruition now.
I'm so glad The Regret is in our ranks, conversing with my brother isn't that much of a hassle. Oh, and he also told me to tell you to go get a pike and shove it up an orifice on your body where it doens't belong. Cheers."
Edited by Endgame
OoC: Your Tentacle chart rocks. It's exceedingly helpful! :wub:
Unless a new plan comes up, Alexandre thinks he should get the Hostage Tentacle from the back row.
"I might as well poison it and get past its SP."
"Nope! 'Can't let you do that. If you take special damage your SP'll burn up. Plus, he's immune to venom. Let those of us with low SP take him. :wink: Johon, next turn, you can kill RTA and regain some strength. Lycan, Galen, don't worry, we'll win this, luck or no luck. Mercutio's a fickle god, but I put my faith in nature to repel this horde of forest-desecraters."
Order (if everyone agrees)
Punii: Nice Try
Sylph: Heal TT, BR
Alex: RTC, FR
Lycan: RTA, FR
Johon: Mead, BR
Elgar: RTB, BR, Opal Spell
Galen: LTB, BR
Galen: HT, BR
Sylph: HT, BR
Johon: BT, FR
OoC: Johon should have 10 more health than he has. He gorged his hide with blood, if you get my drift. :wink:
QM note: Helps me out, that is for sure. :tongue:
Also, once again, it was Johon's decay that finished off the tentacle, not his actual hit.
I'll run a round this afternoon, I'm going to the Science Museum today.
OoC: Oh, well, thanks for reminding me. I keep forgetting that. :facepalm:
OOC: Have fun at the museum. Hopefully they have a scientific biography/section on Proggs. If not, you better call corporate. :sadnew::tongue: Also, did you account for my Mercutio's upgrade? I'm pretty sure you did, as at the start of the battle I had 0 gold, and now I have 4. Though it didn't gain round by round. Just making sure. :)
QM Note: They had a fossil of one! :tongue:
Also, yes. Thank Flipz for that one. :blush:
ALSO: I messed up Aqos's type! Being a progg over 1,000 years old, he should be an ancient be default. Aquos himself will be changed to an ancient (his type has't effected you at all anyway) but his tentacles will remain Beasts (planned anyway.) I apologize for the hiccup, folks! If any of you have an issue with this, I'll change it back.
Round Eight of the Battle With The Tentacled Terror
>Punii attempts to take a nap but fails
>Sylph heals Aquos (back): No heal Greater Heal (9x2=18+19=37 HP healed)
>Alex VS Right Tentacle C (front): Special Damage Critical Hit (10x2=20+18=38 damage)
>Lycan VS Right Tentacle A (front): Shield: Mug (14x3=42+13=55-2=52 damage, 53 gold earned, Combrys = WP: 15)
>Johon chugs a mead (back)
>Elgar VS Right Tentacle B (back): Hit Critical Hit (11x2=22+20=42x2=84-1=83 damage)
>Galen VS Left Tentacle B (back): Hit Shield: Mug (10x3=30+15=45x2=90/2=45-1=44 damage, 44 gold earned)
>Galen VS Hostage Tentacle (back): Damage Critical Hit (10x2=20+15=35x2=70/2=35-3=32 damage)
>Sylph VS Hostage Tentacle (back): Special Damage Damage (23/2=12 damage)
>Johon VS Big Tentacle (front): Damage Hit (21+8=29x2=58-2=56 damage, 56/4=14 damage decay placed)
The battle with the ancient prince continues. The party batters the monstrosities tentacles, once again suceeding in severing one. As Aquos strikes Sylph, all of his tentacles submerge themselves back into the water. johon scores one last hit before they all descend out of reach. Only Aquos remained, his counterstirking disabled by his lack of tentacles... but he remained a formidable foe.
kSClG.png"The plot thickens."
Aquos, Level 28 Ancient
HP: 1047/1100
SP: 18
Ether: 20/30
Specials:
Passive Specials:
Drops:
Tentacle Chart:
>Left Tentacle B: Level 19, HP: 34/250, SP: 1 *Badly Poisoned!*
>Big Tentacle: Level 20, HP: 265/325, SP: 2 *Badly Poisoned!* *Decaying! 14 damage (3 rounds remaining)*
>Right Tentacle B: Level 19, HP: 38/250, SP: 1 *Badly Poisoned!*
>Right Tentacle C: Level 20, HP: 117/250, SP: 2 *Badly Poisoned!*
>Hostage Tentacle: Level 23, HP: 212/325, SP: 2
The Party:
Level 19.5
Power: 27 (19+7+1)
Defense: 0
Health: 23/35c(9+17+7+1)
Ether: 12/23 (5+16+1)
Gold: 19
Johon [AKA Alf Gregory] (Bricksandparts) *Hastened!* *Lucky!* *Encouraged!*
Level: 21
Power: 29 (21+8+0)
Ether: ~/0
Consumables: Potion (4), Grand Potion, Venom, Ice Bomb (1), Mead, Phoenix Essence (2), Trial Brew (1), Smelling Salts, Remedy, Nostrum, Dragon Scale (Lucky and blessed effects upon consumption)
Quest items: (None)
Power: 31
Defense: 6
Health: 22/28
Ether: 8/19
Gold: 193
Power: 28
Defense: 13
Health: 31/38
Ether: 5/18
Gold: 4
Power: 33
Health: 17/17
Gold: 53 (95 gold owed to Thormanil and 30 to Loreal)
Equipment: Combrys (WP: 14 15 *Deadly Envenomed!*, consecutive successful strikes raise Combry's WP by 1, unsuccessful strikes drop it to it's base WP), Pugillist Gloves(Power +2, protects from weakened), Scarlet Hood (Headwear, Power +4, Protects from Stunned)
Level 15.5
Power: 25 (15+10)
Defense: 1 (+1)
Gold: 969
Edited by Endgame
"Hahaha. Disarmed. Get it?" Chuckled Sylph as he thought of his next moves. "Alex, would you mind poisoning the big guy? I'll heal you afterwards... It would make healing him feel less pointless. Galen, Johon, I've got a favour to ask of you in Lycan's name, It'll help us later when we don't want him to die every round once we've fully disarmed this guy."
Punii: Go to sleep little Punii...
Galen: Give Lycan Leather armour, BR
Johon: Give Lycan Rover, BR
Lycan: Accept Rover and armour, BR
Alex: TT, BR
Sylph: Heal Alex, BR
Elgar: Nothing, BR
Galen: Nothing, BR
Johon: Nothing, BR
Sylph: Heal Self, BR
"I don't think you understand the concept of a joke."
QM Note: As far as I know, Rover is only a role playing item... :wacko:
OoC: I thought it was SP:1, but am I wrong? I was looking for SP providing items on everyone's stats. It says usable by everyone. :sceptic:
"Eh, you're probably right. but it was funny, right?" :devil:
QM Note: Right you are: but Lycan is already wearing 2 artifacts. He'd have to take 2 turns to switch...
Aquos replies plainly, not a hint of emotion seeping out of his voice.
"No."
This prince was remarkably nonchalant, to say the least.
"No."
OoC: I am aware. I don't want him to die, and the Prince's arms aren't lasting much longer. :wink:
"Well, you wouldn't find it funny I guess. I've never been all that funny. Well, actually, I was a long long time ago.... Needless to say I find my entertainment in different ways these days. You're calm. I like that in an enemy. It's the sign of an intelligent, strategic, sane enemy when they don't go bat-shit crazy mid-battle. Hahaha. Your brother couldn't keep himself together. I think he used his own products a bit too liberally."
"good call!"
Alex: TT, BR
Elgar: Greasy Sausage, BR
Galen: Nothing, BR
Johon: Nothing, BR
"Of course Lycan, you can use the armour if you wish to."
Galen pulls the leather armour from his pouch and throws it to Lycan.
"Flattery will get you nowhere except your grave a bit quicker. I'd advise you stop.
It is in bad taste to speak ill of the dead, is it not? Especially when his brother is engaged in mortal combat with you. Also, I'll think you'll learn there is a difference between going insane and switching to more effective tactics mid-battle..."
QM Note: I'm so sorry about the delay folks! First, I had robotics class... then my Warp Stinger came in the mail. ( :wub:)
>Punii and Aquos both agree Sylph's singing voice was mediocre at best
>Galen gives Lycan Leather Armor (back):
>Johon gives Lycan rover (back)
>Lycan accepts armor and Rover (back)
>Alex VS Aquos (back): Special Damage Special Damage (Tail Swing: 18 damage to entire party)
-Sylph: Not stunned!
-Johon: Not stunned!
-Elgar: Not stunned!
-Galen: Not stunned!
-Lycan: Not stunned!
>Sylph heals Alex (back): No heal Heal (9+19=28 HP healed)
>Elgar consumes Greasy Sausage (back): +2 Max HP
>Galen daydreams about Beatrice (back)
>Johon twiddles his thumbs (back)
>Sylph heals himself (back): Heal Heal (9+19=28 HP healed)
The battle continues. The party plays completely conservatively, cautious about attacking the Tentacled Terror. Johon and Galen hand Lycan some sp-granting items, which the werewolf happily collects after his previous knock-out at this prince's hands. Misfortune frowns on Alex as he rushes Aquos, the beast tapping out one last beat before snickering. With one fell swoop and a swift swing of his tail, he smashes his barbed tail into all of the heroes. They all stagger from the blow, reeling backwards... but all of them, miracously, remain unstuned. Elgar gobbles down a greasy sausage while Johon and Lycan daydream. Sylph patches himself and Alex up.
kSClG.png"You got lucky."
Aquos, Level 28 Ancient *Counterstriking!*
HP: 1047/1100
SP: 18
Ether: 20/30
Specials:
Passive Specials:
Drops:
HP: 24/250
SP: 1
Specials:
Drops:
30 gold, potion.
HP: 28/250
SP: 1
Specials:
Drops:
30 gold, tonic
HP: 107/250
SP: 2
Specials:
Drops:
30 gold, tonic
Tentacle Chart:
>Left Tentacle B: Level 19, HP: 24/250, SP: 1 *Badly Poisoned!*
>Big Tentacle: Level 20, HP: 241/325, SP: 2 *Badly Poisoned!* *Decaying! 14 damage (2 rounds remaining)*
>Right Tentacle B: Level 19, HP: 28/250, SP: 1 *Badly Poisoned!*
>Right Tentacle C: Level 20, HP: 107/250, SP: 2 *Badly Poisoned!*
The Party:
Level 19.5
Power: 27 (19+7+1)
Defense: 0
Ether: 10/23 (5+16+1)
Gold: 19
Level: 21
Power: 29 (21+8+0)
Health: 18/36 (19+8+1+7+0)
Ether: ~/0
Quest items: (None)
Power: 31
Defense: 6
Health: 19/30
Ether: 8/19
Gold: 193
Power: 28
Defense: 13
Health: 38/38
Ether: 5/18
Gold: 4
Power: 33
Health: 8/17
Inventory: Bedroll, Staff of The Frog Paladin (WP:6, 1/6 chance of Amphibianocs Blessing (protects from damage)), Throwing Dagger (WP6), Deadly Venom, Venom x3, Sylvania's Cowl(grants Animal Talk to Wearer)Leather Armor (SP: 1) Rover (SP: 1) Borrowed!
Level 15.5
Power: 25 (15+10)
Defense: 1 (+1)
Health: 17/25 (7+13+4)
Gold: 969
Edited by Endgame
"Well done. Good swing, mate." Beamed Sylph.
"Well sure, but threatening to devour your enemies is also in bad taste. Get it? Bad taste? I agree with the distinction you suggest, but in your brothers case it was clearly the former. What's insane was that he wasn't doing that from the start. Who saves their strongest attacks for the end of the bloody battle? Was he honestly that stupid, or was his ego simply too large for his brain?"
Punii: Well why don't you sing the bloody song then?
Sylph: Heal TT, BR
Sylph: Heal Johon, BR (Or RTC, BR, if Roots of life previously rolled)
Alex: Heal Galen, BR (Or RTC, FR, if Roots of life previously rolled)
Lycan: Equip Leather Armour instead of Pugilist Gloves, BR
Galen: RTC, BR
Johon: LTB, BR
Elgar: RTC, BR
Galen: RTC, BR
Johon: RTB, BR
Edited by Dannylonglegs
