You ever consider adding a few more hinges?
Ahh!! Phes you have to consider that the hinges have to be on the EDGE of two base plates. If you attached it somewhere else, the base plates would hit each other. Maybe you are thinking that, but the location is where it has to be.
Of course on the far edge you could place several of them vertically so long as they are in the same horizontal plain! It would be hard in this place because there is a BURP in the way! perhaps the bes solution would be to move the BURP over 2 studs, or nor use a BURP or maybe a LURP and put another or maybe two more hinges vertically. In that space.
That's right!
I may try to fix another hinge above the other one. But being separated from my lego for a couple of weeks that'll have to wait a little.... :-/
