Posted January 10, 201312 yr Just got finished building my switch track station that uses a power functions motor. And a video
January 10, 201312 yr I agree, very nice little switch house.....I how the PF has been done.......Brick On 'graphite' !
January 10, 201312 yr Congratulations! It looks great and works very well! Thank you for sharing it with us.
January 10, 201312 yr I don't like to much the modern dishes on that lovely shack , but the whole work is a GREAT work! Excellent engineering!
January 10, 201312 yr Author Thanks for the comments. It uses part 92693c01 http://www.bricklink...asp?P=92693c01� to push the switch forward and I use 2 http://www.bricklink...tem.asp?P=32250 with 3 3L technic axles to lock around the switch tight.
January 11, 201312 yr Creative build there Graphite! Would you be able to create a video with the shack sides removed so we can better see the mechanics of the design? Also, would you be able to document a break down and build up of your design through pictures on your picture host(Flickr,Brickshelf,Etc.)? Great job and thanks for sharing!
January 11, 201312 yr Author Here are some images of the inside. I can't really take a video of it with the sides off because the building holds the technic parts and the motor up so it would probably just flop around when i turned the motor on. The 24 tooth gear in the pictures is actually a 24 tooth clutch in my building and the black fork piece just represents the http://www.bricklink...asp?P=92693c01 piece since I couldnt find either in LDD. I also had to adjust where the fork was and moved it further towards the back side of the motor, but that was only because the roof of my building ended up over hanging the track not allowing the trains to go by so I had to position the fork so that the building could be a bit further from the track. I had hoped to fully encompass the switch lever within my building design but then added the overhanging roof which killed that idea. Some of my piece choices were just from what I had available and was trying to make sure the motor didn't torque too much inside the building. When I get around to building more I'll probably change it up some and make a few different buildings, but for now I want to work on a control box and figure out how I want to wire my train table for more of them. Edited January 11, 201312 yr by graphite
January 11, 201312 yr Author It could probably be made with the M PF motor as well, which is skinnier but I just had the XL ones laying around. Am going to order a couple M's to try out so I can look at more of a compact design without a building as part of it.
