Posted January 18, 201312 yr It's snowing in the UK So I would like to make a vehicle for use in the snow, but I have no idea what . Anyone have any suggestions/links/instructions for something to build? I don't have two of the same motors and not many track pieces so a tracked vehicle is not possible, however a snowmobile might, but I have no idea how to go about making one of them Thanks in advance, legomuppet9
January 18, 201312 yr Author unfortunately, no, the only treads I have are the ones from the 9391 tracked crane...
January 18, 201312 yr Author Yep. The sets I have are: 9391, 9392, 2506 (not complete), 5866, 4837, 4995, 7736, 8292, 4958, 4891, 8418, 8641, 8642, 8435, 4094, 8441 and some joblots (which include u-joints and beams mainly...)
January 18, 201312 yr if you want you can test my snowmobile...i dismounted before it was snowing but i have detailed pictures to rebuild it quickly :)
January 18, 201312 yr Author if you want you can test my snowmobile...i dismounted before it was snowing but i have detailed pictures to rebuild it quickly :) looks good, I'll have to change the track type however, how hard would that be?
January 18, 201312 yr easy i guess...and as it has L motor with 1:1 ratio it should also be "fast" :P let me upload all the pictures :)
January 18, 201312 yr for the moment we also have snow in belgium . and if in the uk the snow is tesame as over here the snowscooter will be to noseheavy. it will sink in the snow unless you go on snow that is allready compressed by something else. grtz Johnny Edited January 18, 201312 yr by Johnny P
January 18, 201312 yr Author easy i guess...and as it has L motor with 1:1 ratio it should also be "fast" :P let me upload all the pictures :) I don't have a L motor... but I think a gear ratio of 20:12 should make an XL motor have around the same performance... am I right?
January 18, 201312 yr hope this is gonna be helpful :) for the moment we also have snow in belgium . and if in the uk the snow is tesame as over here the snowscooter will be to noseheavy. it will sink in the snow unless you go on snow that is allready compressed by something else. grtz Johnny no it shouldnt....last one i built a snowmobile its weight was 829g and it didnt get stuck in fresh snow....this one weights only 400g
January 19, 201312 yr Author Thanks for that Ill have to adapt it to the motors available but the basic frame and suspension etc should be able to stay the same...
January 19, 201312 yr Author Ok, I built the back end to the letter, but had to design the front end myself, and it doesnt look good or work at all... i might look at your other snowmoblie piterx and copy that as it uses the same sort of pieces as I have, it'll be slower, but a necessary sacrifice. Or should I make a 4WD quadbike or something like that? Edited January 19, 201312 yr by legomuppet9
January 19, 201312 yr Perhaps you could build a half-track? I'm not sure how well it would work in the snow though.
January 19, 201312 yr unfortunately i dont have detailed pictures of the other one :( at the moment i'm uploading a video on YT, some pictures and features of my quad....i put it on snow...that wasn't bad :P and it works with the pieces that you have :) i got these pictures for the frame :) if there's something not clear just ask ;) Edited January 19, 201312 yr by piterx
January 19, 201312 yr maybe you could build that frame and adapt it for the snow with tracks and skis in the front :P i think that might work good :D
January 22, 201312 yr Sooooooo I tried I did not want to disassemble my 9398 for the motors so I used an XL motor for propulsion and an M motor for the steering; I did not connect the steering wheel to the output of the medium motor (yet). I added 5/8 pins to the threads as without them the scooter wasn't able to plow through the snow. I used piterx' photos as a guide for building this, and it actually is my first real TECHNIC MOC, yay The problem at the moment is that it kind of sinks in deeper snow. It's either not fast enough (will try with other gear ratio if the snow doesn't disappear too soon) or the front skis weigh too much/aren't large enough. I tried with the original skis from piterx first but they were way too small to support the weight of the snowmobile. It does run fine on compressed snow or carpet though, but my carpet is only 3 feet long so there's not enough to make a movie. I'm gonna keep trying until it actually runs in normal snow and then I'll take some decent pictures Edited January 22, 201312 yr by Strikeman
January 23, 201312 yr ♥.♥ you made me feel really proud man! to me the wider the skiis will be the worse they're gonna be....mainly because of friction, and the second reason is that they are supposed to "cut" the snow... anyway try to see it in scale, the range of snow that it can afford is not more than 4 cm :P im so glad you took inspiration :D btw...this one was really heavy, more than 800g...it's al about how much snow there is lol Edited January 23, 201312 yr by piterx
October 12, 201311 yr Nice sled. Impressive work on getting all the RC components to fit in the small package.
