LEGO Ink Posted February 8, 2013 Posted February 8, 2013 This set was originally commissioned by my father-in-law. His father used to drive a grader in his former years, and it was kind of a tribute to him and myself, as well, to get started building. I designed it about three years ago on LDD, and made all the current modifications while tinkering with excess yellow parts. The particular one you see is Version 3.2, as I've made several changes: - the central beam is more structural and it doesn't fold - lateral articulation points behind the blade are stronger and have a greater range of movement - the carriage holding the blade and turntable have been lowered to give a more disengaged feel. The whole body would fit under the 6-Wide category for the most part, although the front beam is 2-Wide and the engine compartment is 4-Wide. The entire Grader is 28 studs long (and true to form) the blade is almost half that length, at 12 studs wide. As a realistic detail, the turntable is positioned in such a way that the blade can be up, and turned to stay within the wheel-base, 9 studs wide. Feel free to check out the rest! Quote
LEGO Guy Bri Posted February 8, 2013 Posted February 8, 2013 Very nice work here LEGO Ink! Very detailed and very good scale size. I've wanted to build one of these for a long time myself. Does the grader raise and lower, or is it in a fix position? Quote
lightningtiger Posted February 8, 2013 Posted February 8, 2013 This is even better than the fire truck 'LEGO Ink'.....excellent piece of MOCing there - perfect scaling too ! Brick On 'LEGO Ink' ! Quote
Alasdair Ryan Posted February 8, 2013 Posted February 8, 2013 Excellent grader,I like how you managed to get some authentic functions in there too. Quote
Wedge09 Posted February 8, 2013 Posted February 8, 2013 Great work :thumbup: I really like your grader Quote
ER0L Posted February 8, 2013 Posted February 8, 2013 The shaping is very nice indeed. I like what you are doing with the black parts here to get more plasticity and make it look like a real machine. Great job! :thumbup: Quote
Midnight Posted February 8, 2013 Posted February 8, 2013 Very good work indeed, I like how it appears to be perfect size compared to minifigures. I have never seen a grader completed in lego form because I assumed it was too tricky and the shape hard to accurately convey. But this is great and to me perfect! Quote
BrixKix Posted February 9, 2013 Posted February 9, 2013 That's awesome! I see these all the time here in Iowa. The size is great and the details are perfect! Quote
LEGO Train 12 Volts Posted February 9, 2013 Posted February 9, 2013 Amazing working machine, this could be an original lego set! Great realization! Quote
Vincent Kessels Posted February 9, 2013 Posted February 9, 2013 That's a great grader! There are lot of nice details, but my favorite details are the functioning doors. Quote
LEGO Ink Posted February 9, 2013 Author Posted February 9, 2013 Thanks for all the feedback! LEGO Guy Bri, the blade does rotate as well as tilt. There's a combined screen shot here. When at the vertical position there's only a 1 plate difference between the two settings, which is still enough clearance for regular travel. If you wanted more, it can be tilted forward even further and positioned a little flatter to make it over larger objects. Quote
greg3 Posted February 9, 2013 Posted February 9, 2013 Nice work! I like all the details with the various pipes and tubes! Quote
pogie Posted February 9, 2013 Posted February 9, 2013 Great work. Looks like an official TLG set. Quote
dr_spock Posted February 9, 2013 Posted February 9, 2013 Excellent work and details. Is father-in-law pleased? Quote
stacker9000 Posted February 9, 2013 Posted February 9, 2013 Like everyone else has said,"Awesome design!" It would fit in perfectly with all the other LEGO construction sets! Great work in adding articulation in the rear axles, very realistic! Quote
LEGO Guy Bri Posted February 10, 2013 Posted February 10, 2013 LEGO Guy Bri, the blade does rotate as well as tilt. Thanks for the link. I was thinking it could when I saw the technic pieces Quote
