Posted March 14, 201311 yr Winter is over (almost ), so I put away the track and get wheels. This is my fourth and best version of crawler. For drive I'm use 2 L motors (1:3 gear ratio) and one M for steering (1:3).
March 14, 201311 yr looks great, BUT-you definitely need softer shock absorbers and maybe lower gear ratio(maybe), either way nice MOC!
March 15, 201311 yr Author Gear ratio is ok, but suspension I must replace with the old, these are really to hard, but I do not have other.
March 15, 201311 yr Your MOC looks nice but i don't think that your suspension is too hard but i think that the body needs more weight to get more angle of your axles
March 15, 201311 yr If you use rocker arms, or push rod suspension, you can adjust the ratio and easily overcome the strength of those springs and attain a lot more travel. If you decrease the strength by half, you will double the travel, which is perfect for rock crawling. Create a right angle rocker arm where the top of the spring attaches now. Use a push rod instead of where the spring is now. Attach the spring at an adjustable (and probably much lower) lever arm length than the push rod. Voila, ridiculous travel. Edited March 15, 201311 yr by Bzroom
March 17, 201311 yr Author Thanks for informations! Something like that I'm today build and pictures coming soon.
March 21, 201311 yr Author Little modification of suspension and cab: Ldd: http://www.brickshelf.com/gallery/blaz62/Mgx4Red/mgx4.lxf Edited March 22, 201311 yr by blaz62
