SNIPE Posted March 12, 2020 Posted March 12, 2020 11 hours ago, amorti said: You can put a 24t gear inside one of these, but only if you do so before you clip it together... these old turntables can be pried apart with a thin blunt knife as a lever quite easily but yes this is correct. Quote
Alfe Berlin Posted March 17, 2020 Posted March 17, 2020 On 3/10/2020 at 7:24 PM, pleegwat said: He did state it looks the same from the other side. It's also possible the pins are not full pins, but half pins. In that case the 6x1 beams would barely be kept in place and easily pulled out. EDIT: Yup, that can definitely be assembled. And is tricky to pull apart, because the stud side has a better friction lock than the pin side. Yes, I did it with one half pin. Most people have quite a hard time disassembling it, but correct, the spot where the half pin is used is the weak spot to start it. It cannot be seen or felt. But if you try to turn it with a finger nail, the half pin will not be turnable because its stud had the mentioned friction. There are variants where only one vertical brick pair is used in the middle and two sets of plates are used on both sides of it. There it's even harder to take apart. The two examples I've built I cannot take apart anymore (without tools). Quote
doug72 Posted June 19, 2020 Posted June 19, 2020 (edited) On 4/11/2013 at 3:39 AM, Boxerlego said: A LEGO that once you put it together you can never take apart. Never have any bother removing 2L axles even when push fully in. I use an old screw driver with the tip gound to a fine needle point. Insert point into the gap along the 2L pin and lever out enough for needle nose pliers to grip and then remove the axle. THis does not harm the axle. Edited June 19, 2020 by Doug72 Quote
amorti Posted June 24, 2021 Posted June 24, 2021 2 hours ago, a1i2d3e4n5 said: heres one But that's not only impossible to take apart, it's impossible to build it. Quote
1974 Posted June 24, 2021 Posted June 24, 2021 It's impossible to build a tower with 2x2 bricks higher than 3,5km (375.000 bricks) apparently : https://www.bbc.com/news/magazine-20578627 Quote
2GodBDGlory Posted June 24, 2021 Posted June 24, 2021 I've long wanted to try and build a full RC car in which NOTHING can be taken apart. I'm pretty sure it can be done, but I'll have to get experience with using digital Lego programs first. Quote
astyanax Posted June 25, 2021 Posted June 25, 2021 16 hours ago, 2GodBDGlory said: I've long wanted to try and build a full RC car in which NOTHING can be taken apart. I'm pretty sure it can be done, but I'll have to get experience with using digital Lego programs first. Perhaps you can take some inspiration from set 8458 "silver champion"... Last year I had a need for its wishbone arms, but I found it nearly impossible to take apart the vehicle due to it being circularly form-locked somehow... Quote
weavil Posted June 26, 2021 Posted June 26, 2021 I have tiny drill bit and tiny screws for impossible axles. Recently got a small pair of forceps. Quote
astyanax Posted November 30, 2021 Posted November 30, 2021 Apparently the new AT-AT (75313) will be impossible to disassemble completely, due to a classic Technic frame mistake like in the original post. See analysis here: https://brickset.com/article/67650/lego-is-now-designing-sets-that-can-t-be-taken-apart Quote
Mr Ogel Posted November 30, 2021 Posted November 30, 2021 5 hours ago, astyanax said: Apparently the new AT-AT (75313) will be impossible to disassemble completely, due to a classic Technic frame mistake like in the original post. See analysis here: https://brickset.com/article/67650/lego-is-now-designing-sets-that-can-t-be-taken-apart ah, sometimes it would be a good point to also have a look at other "friendly" themes here on EB...Anyway, worst would be to put it here on the title page Quote
MajklSpajkl Posted November 30, 2021 Posted November 30, 2021 Well, it is not that dramatic...yes, it is not possible to do it without a sharp object, but it is perfectly doable without hurting the pieces. There is enough play to get the head of the stop axle out enough in order to reach beneath it with a tip of a knife...I just tried and succeeded with no effort at all. Will be interesting to see how will they try to solve this or explain it... Quote
astyanax Posted November 30, 2021 Posted November 30, 2021 1 hour ago, Mr Ogel said: ah, sometimes it would be a good point to also have a look at other "friendly" themes here on EB...Anyway, worst would be to put it here on the title page Indeed I omitted to look in other forums (fora?), and agree this thread is not the place to discuss the ensuing "drama" or possible fixes. Still I believe it is right to catalogue here a perfect instance -- in an official Lego set -- of the issue that started this very thread. Quote
pleegwat Posted November 30, 2021 Posted November 30, 2021 1 hour ago, MajklSpajkl said: Well, it is not that dramatic...yes, it is not possible to do it without a sharp object, but it is perfectly doable without hurting the pieces. There is enough play to get the head of the stop axle out enough in order to reach beneath it with a tip of a knife...I just tried and succeeded with no effort at all. Will be interesting to see how will they try to solve this or explain it... My thoughts exactly. This kind of thing is (barely) disassembleable only because an axle with stop is used. Quote
LvdH Posted November 30, 2021 Posted November 30, 2021 (edited) 3 hours ago, MajklSpajkl said: Will be interesting to see how will they try to solve this or explain it... As usual, it will be intentional, just like the intentionally incorrect gear sequence in the GT3RS I'm pretty sure you can just leave the green connector out without affecting really stability that much. It seems to only exist to keep the turntable in place. But like you said, it's not that difficult to remove it with some proper tools. Edited November 30, 2021 by LvdH Quote
allanp Posted December 1, 2021 Posted December 1, 2021 Yeah, a sharp needle in the slot of the green piece will get it moving. No Biggie for us, but an error non the less when Lego is meant to be dissemble able and other solutions are possible. Quote
Mr Ogel Posted December 1, 2021 Posted December 1, 2021 16 hours ago, astyanax said: Indeed I omitted to look in other forums (fora?), and agree this thread is not the place to discuss the ensuing "drama" or possible fixes. Still I believe it is right to catalogue here a perfect instance -- in an official Lego set -- of the issue that started this very thread. I fully agree Quote
aeh5040 Posted December 5, 2021 Posted December 5, 2021 In practice the ATAT axle assembly can be wiggled back and forth until a fingernail can fit under the axle stop. But still, it's poor form by TLG! Quote
Philtech Posted December 11, 2021 Posted December 11, 2021 (edited) A while ago I built these things, luckily only digital: Edited January 3, 2022 by Philtech Quote
Philtech Posted December 13, 2021 Posted December 13, 2021 After reading this topic my interest in these things has been rekindled. I don't know if this has been written here before, but I thought of this one: Quote
Didumos69 Posted January 1, 2022 Posted January 1, 2022 (edited) If you could build this Penrose triangle: you can build a strong triangular wall: Edited January 1, 2022 by Didumos69 Quote
astyanax Posted January 1, 2022 Posted January 1, 2022 9 hours ago, Didumos69 said: you can build a strong triangular wall: If I'm not mistaken, even making a single node in the wall (connecting 6 beams with 6 blue 3L pins) is impossible... Quote
Didumos69 Posted January 1, 2022 Posted January 1, 2022 1 hour ago, astyanax said: If I'm not mistaken, even making a single node in the wall (connecting 6 beams with 6 blue 3L pins) is impossible... Alright, let's fix that. Quote
Gray Gear Posted January 1, 2022 Posted January 1, 2022 (edited) On 6/24/2021 at 6:45 PM, a1i2d3e4n5 said: heres one With the new 3L pin introduced in the Darth Vader Meditation Chamber this is now kind of possible. Might be able to fool people who don't know that part exists tho lol Edited January 1, 2022 by Gray Gear Quote
