2 hours ago, Erik Leppen said:
I once put a light sabre 4L rod in one of the small holes of a knob wheel.
It was already hard to push it in, but I have never been able to take it apart...
Did that once with minifig microfone - it's still there...:hmpf_bad:
  • Replies 275
Have you tried twisting the 4L rod? Also, sometimes using lots of the half-width 2L beams stacked on the remainder of the 4L as a grip can be enough to overcome the friction, and each individual beam can be removed one by one.
I have a contender (from disassembling the 8480 sub the other day, so this is from official instructions!):
Any ideas?  Genuinely at a loss as to how to separate them.  Possibly (gently) heating them would help...
Is that two regular round 1x1 plates? I don't find regular single studs any difficult to separate from pin holes, haven't found any studs having that much friction inside a pin hole.
They do seal nicely though, and with one on the other side, the air has nowhere to get in (my theory).
Yes, and until now, neither have I!
Brick Separator? That's all I can think of, I've never had an issue like this...
And older parts tend to have tighter connections, make situation worse.
I'd say try using two brick separators from both ends at the same time.
I use these tools for seperating parts when dis-assembling a model.
Needle nose pliers for grip and pull.
Craft knife for easing beams apart.
Modified screwdriver with a needle point for pushing out axles etc. - also useful for lining up parts and connector pins.
31992854094_d53cf50e94.jpgIMG_4308 by Doug Ridgway, on Flickr
Thanks for the suggestions folks.  Had another go at it today, and didn't need to break out the toolbox in the end.  Heated it up in hot water to expand/loosen the joint, then wrapped in a towel to get enough grip without ripping my fingernails off!  And no damage to the parts - bonus.
On 2/11/2017 at 2:21 AM, Buddy010702 said:
Brick Separator?
Or two brick separators
And some of that grip mat stuff, I have some really thin stuff that helps me to grip the other part when removing bricks.
@Didumos69 Could you just remove them in pairs by pulling two opposite the other two?  There are still two in-line pin connections joining them together if considered as pairs.  On each pair, one hole will be removed from a pin while one pin will be removed from a hole.
D.mn it, you're right! I got them apart. I never looked at it that way. I was convinced I had to pull all four simultaneously. Stupid me :blush:.
Edited by Didumos69
You are not the only one that makes silly mistakes!  I just knew that most pin connections that do not stress the parts should be able to be removed without stressing the parts.
Btw, I think these belong here too (see original topic):
On 14-5-2016 at 5:31 PM, Didumos69 said:
Who is the first to provide legal instructions (legal as in 'not making use of slack') for this cube? It is possible :classic: .
LXF-file here.
On 14-5-2016 at 10:55 PM, Didumos69 said:
its smaller brother fits inside.
Edited by Didumos69
@Didumos69 I see how it is possible and can be done legally, as you can use the double-length portion of the black pins (without the collar) to slide the pins out during pre-assembly and lock them in once all pieces are assembled.  Removal of the pins is entirely a different story, as you would need to grip the revealed shaft-portion of the black pins to slide the pins back out incrementally.  The "little brother" one does require the use of another cross-axle to push the internal cross-axles out for removal.
As a mechanical engineer, I find these connections quite fun to decipher, though I do not build much in the Technic realm.  If I had the time and funding available, I probably would expand beyond just LEGO System.
Edited by Slegengr
