"We should divide the batteries into groups of three. Our first measurement should be two of those groups; if they are equal in voltage, we know that the last group must contain the fully charged battery, in which case our second measurement would be one battery on each side of the scale from the remaining group. If they are once again equal, that means the battery not on the scale is the charged one. Otherwise the fully charged one will tip the scale.
A similar process is done if we find that one of the first two groups has the charged battery in it."
  • Replies 815
Nerwen puts three batteries on each side of the scale, leaving three off.
Whichever side the scale indicates, she takes those three, putting the others aside. If the sides are shown as equal, she takes the three that weren't measured.
With those three, she puts one on each side, leaving one off.
The full battery is either indicated by the scale or it is the one left out. The full battery is identified.
She realized she was moving as Xander spoke and laughed gently.
Looks like we both figured it out.
Edited by Chromeknight
Under Xander's direction, Nerwen arranges the batteries and eventually settles upon one before plugging it into the dumbwaiter's power socket. With a slight hum the machine powers on successfully. Xander smiles at his resourcefulness and gains 1/3 a level of experience!
Xander Unth'or
24 year-old male Human Hunter
Level 29
*Natural Respite*
*Immune to Blindness and Fragile*
*Favors Beasts and Mechanical Monsters* *Earns Triple Experience*
Defense:
5
Health:
29/42
Power Bonus:
SP:
5
Gold:
21
Equipment:
Precision Bow (WP:19; all 'Aim's become 'Hit's), Hunter's Quiver of Marksmanship (WP:2 to a bow, allows the hunter to favor two types at the same time; protects from blindness-effect), Heavy Armor (SP:5, protects from fragile-effect), Medal of Glory (Wearer gains triple experience, accessory)
Inventory:
Pongcanis Club (WP:8), Enigmatic Hammer (WP:3), Electro Gear (Wearer deals and is immune to
lightning
elemental damage, accessory), Aquamarine (
Water
), Topaz (
Lightning
) 3 Potions, 2 Grand Potions, 5 Remedies, 2 Nostrum, Smelling Salts, Venom, Deadly Venom, Skeleton Decoy, 2 Phoenix Essences, 2 Smoke Bombs, 3 Bones, 3 Dragon Scales, Mead, 1 Level-Up Mushroom, Chicken Drumstick (Permant HP increase by 1), Seventh Heaven
"Well now, back and rolling. This'll save my feet and back some trouble now. Thank you."
Greetings. Party was sent to collect rent for new owner. Cronk knows 302 was not behind on rent, but party happened across a being in distress while collecting rent and is in need of shiny objects to turn other tenant back from being stone.
Does friendly Lucastoid have any shiny objects capable of redirecting light that party might borrow?
The lucustoid soon returns with the broken mirror pieces and hands them over to Cronk. Nerwen notices that the shield does indeed have a reflective surface and removes it from the wall.
I do not know friend Cronk, but we can try.
Nerwen leads the party to the petrified faun's room.
I'm away on a work conference for the next five days. I expect to have internet access, but if I don't and disappear, CM has Nerwen. (normally would have said Legonater, but he's QMing also).
The Party heads back to the faun's room. Laying all of their items on the floor they note that they have 11 reflective pieces to arrange. An inspection of the gems reveals that they redirect light of the gems color perpendicular to the incident beam. Sunlight continues to stream through the window, the diamond giving off a stream of color directly perpendicular to the window. There seem to be enough pieces, how will the party arrange them?
QM Note: Feel free to try representing the solution in any way you wish however this format might be the simplest.
A / C D
/ \ \ H I
etc...
Edited by Waterbrick Down
Nerwen looks at the pieces, trying to determine if there is a piece which splits the beam or if they needed to reflect the one beam through multiple gems to one of those mounted on the wall.
She also tries the surfaces of the armour, to see what it does to the beam.
Xander notes that the light is coming in from the window on the right and that the light beams cross over each other with no effect. Nerwen does not find anything that can split the beam and determines that the solution to the puzzle must involve the gem stones.
It would seem we need to reflect the light of the separate gems into the button(?) of their respective colour. However, we do not seem to have a red gem...
Nerwen takes a fragment, placing it at point H, trying to reflect only the red light into the Ruby on the wall.
She also looks at the pieces to see if any reflect on both sides, or whether the reflect from one direction only.
OoC: I'm assuming you are holding the piece at a 45 degree angle such that it reflects into the Ruby.
The Ruby lights up, but only dimly as if inhibited by the other colors. Nerwen looks at her reflective pieces and notices that they have a mirrored surface on both sides. Dyric fails to notice that the diamond is currently acting like a prism splitting the colors up.
