  • Replies 51
A small price to pay for a perfect steering geometry, I have seen very few Tatra MOCs that don´t move the suspension and steering at the same time to be very difficult to isolate from one another, I try to get this on all my Tatras, none of them change the steering angle of the wheels when the suspension works.
Sounds interesting, I'm corious about the final model. :classic: Nice narrow suspension, this is proportional for the real one.
(but one thing: don't use SO BIG pictures. :wacko: It takes hours to download, absolutely doesn't necessary that resolution)
Edited by Mbmc
I like the progress, and it seems very compact. I think this is going to be a great MOC. I do however agree with Zblj, those steering links are likely to cause problems... I also seems you have some gears skipping, but i guess you are going to sort that out.
May i suggest that you use double gears to the axles? If you add a 12 tooth gear (where you now are using half bushes) along with the 20 tooth gears you will get a much stronger transfer of power, as well as less problems with gears skipping.
-ED-
The problem with the links is difficult to repair, the truck is 11 studs between the wheels and each link is 6 studs... the only possible position is the first in the picture for the wheels are perfectly aligned when the suspension works.
Of course the skipping gears will be repaired. I don´t undestand you the last part, I'm using this technique and I don´t see where you can improve it.
No I can´t do that... look at the picture and think about it, (credit go to me :laugh: ), work in small places makes you think a lot.
Yes credit goes to you! that is a great design.
Too fast? Use the proportional speed controller (train remote) :wink:
The photo of the small turntable between steering axles showed me how to solve a similar problem I have. Thanks.
Edited by andythenorth
The small turntable is a good solution to eliminate pressure from the drive shaft, it was the first thing I thought when they went on sale these parts.
I try with red too... anyway the cab isn´t finished yet, I think it has to be 1 or 2 studs longer. The back will be grey with 8110 panels and will have red or black connectors.
