Cutlass Cole Posted March 1, 2007 Posted March 1, 2007 I'm thinking about making a vessel called a bomb. If you don't know what it is, go to Wikipedia and search " Bomb Ship ". It should take you there. How do you make the Mortars? I was thinking with an airport engine, what do you think? Also, Could you guys show a picture of your ships deck? I don't know how to do it. :-/ Thanks. CC. Quote
Legeaux Posted March 1, 2007 Posted March 1, 2007 I'm thinking about making a vessel called a bomb. If you don't know what it is, go to Wikipedia and search " Bomb Ship ". It should take you there.How do you make the Mortars? I was thinking with an airport engine, what do you think? Also, Could you guys show a picture of your ships deck? I don't know how to do it. :-/ I think the airport engine is too big, but YMMV. The mortars on my two current bomb ketches are garbage cans. The most recent is the Bloviator. My first bomb ketch, the Fantine was originally armed with a 4x4 round mortar, but has since been rearmed with a pair of 2x2 mortars (sorry, no pics available of the new configuration). Quote
Dukesc Posted March 1, 2007 Posted March 1, 2007 How do you make the Mortars? I was thinking with an airport engine, what do you think? Here is a mortar me bro designed. This can also be found at the MOC cannon index. I too would like to build a bomb in my fleet, and this is how I plan to build my mortar. I hope this helps. Duke Quote
Governor Mister Phes Posted March 1, 2007 Governor Posted March 1, 2007 I'm thinking about making a vessel called a bomb. If you don't know what it is, go to Wikipedia and search " Bomb Ship ". It should take you there. Is this the Wikipedia Article you had in mind, Mr Cole? Quote
Capn Frank Posted March 1, 2007 Posted March 1, 2007 Cutless Cole, If the engine piece you are talking about is this piece: Then i've never tried to use that brick for a motor before. Hmm, i wonder how it'd turn out. I think i may try that when i get home tonight. If you're speaking of the x-wing engine, i tried it with making a (very large) carronade: It turned out ok. :-/ Hopefully that helps. P Quote
Governor Mister Phes Posted March 1, 2007 Governor Posted March 1, 2007 Mr Phred, why don't you point Mr Cole in the direction of the MOC Cannon Index? He might that it very useful, especially the cannonade section. Quote
Cutlass Cole Posted March 1, 2007 Author Posted March 1, 2007 Okay ... ( Deep breath ) 1. I was talking about the engines on LEGO set 7893.It's the things under the Wings, for other people. X-D 2.Your absolutly correct, Mr. Phes. *y* 3.The Info is helping,but I have to go to Yahoo ( Yahoo the Pictures won't load ) because AOL Eurobricks boots me off posting, even though i'm logged in as CC. :-O :-O :'-( *n* 4. 7893 also has good hull pieces. I saw it on a MOC. ;-) 5.I'll look at the MOC Cannon's thread soon. ;-) 6. That problem i'm having needs to be solved. :skel1: Quote
Capn Frank Posted March 1, 2007 Posted March 1, 2007 Mr Phred, why don't you point Mr Cole in the direction of the MOC Cannon Index? He might that it very useful, especially the cannonade section. Doh! As Mr. P has mentioned there is a MOC Cannon Index too where there are 50 to 60 different designs for lego cannons. Ta da! The MOC Cannon Index :) P Quote
Governor Mister Phes Posted March 3, 2007 Governor Posted March 3, 2007 3.The Info is helping,but I have to go to Yahoo ( Yahoo the Pictures won't load ) because AOL Eurobricks boots me off posting, even though i'm logged in as CC. :-O :-O :'-( *n* 6. That problem i'm having needs to be solved. :skel1: Which Internet browser are you using? Quote
Cutlass Cole Posted March 3, 2007 Author Posted March 3, 2007 AOL! American online. Proubly because you don't lica, you don't have it. X-D Edit: live in America. :) Quote
Governor Mister Phes Posted March 3, 2007 Governor Posted March 3, 2007 I don't have AOL because I've heard its not a very good provider, as you're clearly demonstrating :-D I almost signed up to AOL once (yes, they even extend their evil clutches to the other side of the world) but I was talked out of it because they weren't very good. That was 6 years ago now, obviously things haven't improved much. Quote
Cutlass Cole Posted March 4, 2007 Author Posted March 4, 2007 Whatever! :-| By the way, Since Bomb's have less cannon's, I was thinking of putting only one gun on there, but that would be an even match with some sloops I want too build, and I still need to make the Imperial Flagship fearsome! 8-| By the way, what do you think about putting guns on the main deck? that would make IF four SES 8, but can you mount more with the Renagade Runner? Or the Crossbone Clipper? ( Gives Mr. Phes a good stare. ) :skel1: Quote
Governor Mister Phes Posted March 4, 2007 Governor Posted March 4, 2007 ( Gives Mr. Phes a good stare. ) :skel1: Stop checking me out or I'll start blushing! X-D Whatever! :-| Yes, whatever indeed! Is your problem still persisting? By the way, what do you think about putting guns on the main deck? that would make IF four SES 8, but can you mount more with the Renagade Runner? Or the Crossbone Clipper? I'd say the Cross Bone Clipper because it looks more spacious. Quote
Cutlass Cole Posted March 4, 2007 Author Posted March 4, 2007 BUT You own the Set! >8-) :skel1: Looks more spacious... Arrrrrrrgggggggggghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh a hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh h hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh Argghhh.. Quote
Governor Mister Phes Posted March 4, 2007 Governor Posted March 4, 2007 Yeah so? :-P I own two Renegade Runners and two Cross Bone Clippers (all built) making it very easy for me to compare them to determine which ship could have the most guns mounted to its deck. Quote
Cutlass Cole Posted March 4, 2007 Author Posted March 4, 2007 Well then... >8-) MOUNT THEM ALREADY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :( BECAUSE I, WHO IS PIRATE-SET-less CANNOT! *sad* Quote
Governor Mister Phes Posted March 5, 2007 Governor Posted March 5, 2007 Unfortunately I don't have time to do such things, but you should have your own Cross Bone Clipper - if everyone in the world dares not to bid on that eBay auction. Quote
