Posted July 6, 201311 yr The Stealth Z-95 is a modified variant of the Clone Z-95 flown during the Clone Wars by the G.A.R. As such it uses the dual engine configuration opposed to the more standard quad engines found on most Z-95’s. The weapon systems were replaced with ones found on its younger cousin the X-Wing, laser cannons replacing the blaster cannons and a pair of photon torpedo launchers instead of the concussion missile launchers. The nose of the fighter was made shorter and resembles that of any number of other Z-95’s. The fighter also been modified to have an astromech port behind the cockpit and covered by a transparasteel canopy, x1 hyperdrive, installed, and finally a sensor mask and sensor baffling, making it harder it to be detected by sensors or sight. The Stealth Z-95 was developed by an Alliance agent during the early days of the rebellion to restore the Republic. The Z-95 was chosen due to being a common enough fighter, that if seen it would not be immediately apparent that it was an Alliance craft, unlike using a newer fighter such as the X-Wing. It was used in limited number of missions against Imperial targets in the core worlds. The Stealth Z-95 is a modified variant of the Clone Z-95 flown during the Clone Wars by the G.A.R. As such it uses the dual engine configuration opposed to the more standard quad engines found on most Z-95’s. The weapon systems were replaced with ones found on its younger cousin the X-Wing, laser cannons replacing the blaster cannons and a pair of photon torpedo launchers instead of the concussion missile launchers. The nose of the fighter was made shorter and resembles that of any number of other Z-95’s. The fighter also been modified to have an astromech port behind the cockpit and covered by a transparasteel canopy, x1 hyperdrive, installed, and finally a sensor mask and sensor baffling, making it harder it to be detected by sensors or sight. The Stealth Z-95 was developed by an Alliance agent during the early days of the rebellion to restore the Republic. The Z-95 was chosen due to being a common enough fighter, that if seen it would not be immediately apparent that it was an Alliance craft, unlike using a newer fighter such as the X-Wing. It was used in limited number of missions against Imperial targets in the core worlds. Stealth Z-95 Headhunter (Saga Edition) Gargantuan starfighter Init +3; Senses Perception +6 Defense: Ref 14 (flat-footed 12), Fort 26; +7 armor, Vehicular Combat HP 120; DR 10; SR 15; Threshold 46 Speed fly 16 squares (max. velocity 1150 km/h), fly 4 squares (starship scale) Ranged laser cannons +5 (see below) Ranged proton torpedoes +5 (see below) Fighting Space 4x4 or 1 (starship scale); Cover total (crew), Cover total (astromech droid) Base Atk +2; Grp +33 Atk Options autofire (laser Cannons), fire-link (photon torpedoes) Abilities Str 42 (+16), Dex 14 (+2), Con --, Int 12 (+1) Skills Initiative +3, Mechanics +6 (+13*), Perception +6 (+3*), Pilot +3, Stealth +3, Use Computer +6 (13*) Crew 1 plus astromech droid (skilled); Passengers none Cargo 85kg; Consumables 1 days; Carried Craft none Payload 6 proton torpedoes Hyperdrive x1, 10-jump memory (astromech droid) Availability Military; Cost Not available for sale * If the ship has an astromech droid, use these skill modifiers instead Special Equipment Sensor Mask, Sensor Baffling, Laser cannons (pilot) Atk +5 (+0 autofire), Dmg 5d10x2 -------------------------------------------- Proton torpedoes (pilot) Atk +5, Dmg 10d10x2, 4-square splash Front Rear Side Top Bottom Cockpit and Droid Port Edited July 6, 201311 yr by Knightsword
July 6, 201311 yr Are those stats from the D20 Star Wars RPG? Also Starfighters!!! yay the bestest best part of Star Wars :D This is a pretty cool MOC I'm hoping to find the stock Z-95 for cheap, as I love the X-wing and all it's relatives.
July 6, 201311 yr Author The stats are for the Saga Edition RPG, suitable for the Rebellion Era, and thanks. Edited July 6, 201311 yr by Knightsword
July 7, 201311 yr Nice starfighter! It looks a bit like a Bat-plane in all black,which just adds to the coolness factor. Purely out of curiosity,what is that poster in the background of?
July 7, 201311 yr Author Nice starfighter! It looks a bit like a Bat-plane in all black,which just adds to the coolness factor. Purely out of curiosity,what is that poster in the background of? Thanks and the poster is the Predaking lithograph from the long defunct Dreamwave comics.
July 10, 201311 yr Nice MOD. I love the blacked out look. Check out my dude https://www.youtube.com/watch?v=IFNmEbtf6Ck A whole bunch of awsome right there.
July 11, 201311 yr Author Nice MOD. I love the blacked out look. Check out my dude https://www.youtube....h?v=IFNmEbtf6Ck A whole bunch of awsome right there. Thanks for the comment and nice stealth/black ops team.
