ZCerberus Posted March 4, 2007 Posted March 4, 2007 12a So if you read my first Arbiter II post (which recently should have been split), you will know that the old Arbiter, found here, that my old flagship was given to the Spanish to cease hostilities between the Spanish and Brick-tish. The ship was renamed 'Venganza' as it vowed revenged for the sinking of one of its own ships. As a result of the trade, however, I needed to refit the Venganza for duty as a Spanish ship. This wasn't overly difficult because all I really did was change the sails to white and replace the flags... Anyhow, I thought I would share photos of the Venganza as it is now! Here is the old guy The other ship seen is the photos for comparison is the Arbiter II which has now been completed. You can find that ship by clicking on the thumbnail below. Quote
exo attack Posted March 4, 2007 Posted March 4, 2007 Wow, this is really cool. Is the hull removeable?, and can you take a pic of the inside of the cabin? You have alot of canonns... Quote
ZCerberus Posted March 4, 2007 Author Posted March 4, 2007 Wow, this is really cool. Is the hull removeable?, and can you take a pic of the inside of the cabin? You have alot of canonns... Unfortunately, the decks are not removeable, nor is the cabin accessible... those were some of the down falls and the reason why I made the Arbiter II, which has both open-up sides and an accessible cabin, click the thimbnail to see the Arbiter II Quote
Eurobricks Emperor Bonaparte Posted March 4, 2007 Eurobricks Emperor Posted March 4, 2007 The new sails look good and it like the color scheme of this ship. But it should be a bit wider. Maybe by using some inverted slopes in the hull. What do you think Z? Quote
Governor Mister Phes Posted March 5, 2007 Governor Posted March 5, 2007 Unfortunately, the decks are not removeable, nor is the cabin accessible... those were some of the down falls and the reason why I made the Arbiter II, which has both open-up sides and an accessible cabin, click the thimbnail to see the Arbiter II Well back to the drawingboard you go to add these features X-D Quote
ZCerberus Posted March 5, 2007 Author Posted March 5, 2007 The new sails look good and it like the color scheme of this ship.But it should be a bit wider. Maybe by using some inverted slopes in the hull. What do you think Z? Yes much better, and it certainly could be wider, i guess that is the drawback of trying to make a large ship on the narrow standard hulls. *sigh* I guess seeing this ship makes me appreciate the Arbiter II more! I don't think I will be getting around to working on it for quite some time! Well back to the drawingboard you go to add these features X-D Ha! I might have to revisit this ship sometime later. Quote
Governor Mister Phes Posted March 5, 2007 Governor Posted March 5, 2007 It appears you're using paper sails - will you be replacing them with something made of fabric in the future? Quote
ZCerberus Posted March 5, 2007 Author Posted March 5, 2007 It appears you're using paper sails - will you be replacing them with something made of fabric in the future? Heh, they are not paper. They are canvas! The stuff is just so rigid that it looks paper-y, but it is a cloth like material. it sure is white! Quote
Scouty Posted March 5, 2007 Posted March 5, 2007 So if you read my first Arbiter II post (which recently should have been split), you will know that the old Arbiter, found here, that my old flagship was given to the Spanish to cease hostilities between the Spanish and Brick-tish. The ship was renamed 'Venganza' as it vowed revenged for the sinking of one of its own ships. [big Snip] You know, it's bad luck to change the name of a ship 8-| . Other wise, It's still a very, very nice ship :capn: . Quote
ZCerberus Posted March 5, 2007 Author Posted March 5, 2007 You know, it's bad luck to change the name of a ship 8-| .Other wise, It's still a very, very nice ship :capn: . Well throughout history tons of ships have been renamed... but talk to my Spanish, they are the ones who did it! I just couldn't take the name "Arbiter" away from my main flagship. Quote
Governor Mister Phes Posted March 5, 2007 Governor Posted March 5, 2007 Heh, they are not paper. They are canvas! The stuff is just so rigid that it looks paper-y, but it is a cloth like material. it sure is white! Yes the sails certainly are white, they're brighter than the hull even - but how long will it take before they start to discolour? Quote
ZCerberus Posted March 5, 2007 Author Posted March 5, 2007 Yes the sails certainly are white, they're brighter than the hull even - but how long will it take before they start to discolour? No idea! It is the same material used on the Arbiter II. The stuff dyes pretty easily, but I had the material for the sails for the Venganza just folded up and waiting inside a bag... I guess the next time I see the ship, I might be able to answer that question! Quote
Capn Frank Posted March 5, 2007 Posted March 5, 2007 You know, it's bad luck to change the name of a ship 8-| .... If that were true the HMS Surprise wouldn't have been such a lucky ship since it was originally a french corvette named Unit Quote
Governor Mister Phes Posted March 5, 2007 Governor Posted March 5, 2007 Vs I must say The Venganza is a bast improvement over the original Arbiter, particularly the sails. Even though the current sails are bright white the previously used Imperial Flagship sails didn't work very well with the hull at all. But mentioning the hull I'd have to say it seems a bit too narrow for the length of the ship. Quote
ZCerberus Posted March 5, 2007 Author Posted March 5, 2007 But mentioning the hull I'd have to say it seems a bit too narrow for the length of the ship. No disagreement here. I didn't really do much to the ship other than change the sails. It is definately too narrow for its length! But it is on the bottom of my list for updates! Quote
Governor Mister Phes Posted March 5, 2007 Governor Posted March 5, 2007 Any particular reason(s) you decided to make the ship that long with a hull that narrow? Quote
ZCerberus Posted March 5, 2007 Author Posted March 5, 2007 Any particular reason(s) you decided to make the ship that long with a hull that narrow? Yes... evolution... The ship started out as a an imperial flagship. Then it grew to a combo of two imperial flagships. Then I stretched the hulls with black slopes. Then the Armada line came out, and I found some white hulls through auctions etc. I switched the hulls over to white because they were the same size and matched the ship. So it is long and narrow because that is how it evolved. If I had to start from scratch, it would look more like the Arbiter II and less like it does now. Quote
Governor Mister Phes Posted March 6, 2007 Governor Posted March 6, 2007 Then the Armada line came out, and I found some white hulls through auctions etc. I switched the hulls over to white because they were the same size and matched the ship. Errr... The Armada line can out in 1996, you haven't been working on The Venganza for the past 11 years have you? :-P Quote
ZCerberus Posted March 6, 2007 Author Posted March 6, 2007 Errr... The Armada line can out in 1996, you haven't been working on The Venganza for the past 11 years have you? :-P The original Arbiter (Venganza) was probably constructed around 1998 or 1999. They were old when I dusted them off for pictures. I guess when my parents moved two years ago, my interests were re-sparked. I moved all the Lego(s) up to the attic, and in doing so, I say the harbor which has become Fort Brighton, and I thought how pointless and boring all the buildings were, so I started rebuilding, and that is when I found this site. After I re-did the harbor, the ships were a logical extension. And now I already have an itch to get some improvements on the Fort Brighton completed. I would say my general Lego® building skills and especially my ship building skills have upgraded a bit since the Venganza's predecessors creation! Quote
Governor Mister Phes Posted March 6, 2007 Governor Posted March 6, 2007 Which one is Fort Brighton? Is that the big harbour you built with a MLCAD WIP thread - or am I thinking of something else? Quote
ZCerberus Posted March 6, 2007 Author Posted March 6, 2007 Which one is Fort Brighton? Is that the big harbour you built with a MLCAD WIP thread - or am I thinking of something else? Nope, that's the one! Quote
Governor Mister Phes Posted March 6, 2007 Governor Posted March 6, 2007 I thought Fort Brighton was brilliant as it was - what more could you possibly want to do to it? Quote
Norrington Posted March 6, 2007 Posted March 6, 2007 Add a couple of base plates with walls to the garrison and stockade buildings I would think... Quote
ZCerberus Posted March 6, 2007 Author Posted March 6, 2007 Add a couple of base plates with walls to the garrison and stockade buildings I would think... Exactly. Like I said, I am pretty sure Brighton would get crushed from an attach by sea, and I don't think the fortress section has enough guns, or enough firing angles to defend the place! We'll see how it goes! Quote
oDDerFisken Posted March 6, 2007 Posted March 6, 2007 It's a very fine ship i must say. It still is. Especially i like that load of guns there's onboard But i dont get the point of this sail: To me it looks wierd. Quote
