KirTech LAB Posted July 23, 2013 Posted July 23, 2013 (edited) Hello all! I want to present my MOC - remote controlled (RC) Grader. Total construction time – about 4 months. Total length without rigs – about 80 cm. Weight – 5 kg. Total parts quantity – 5200. There are 12 independent RC functions: five mechanical: - All-Wheel Drive (3 x XL); - Two-stage steering (1 x L – forward wheels steering, 2 x M – articulated chassis); - Forward wheels tilt (1 x M); - Mouldboard rotation (1 x L); and seven pneumatic (5 x M – I used scheme with dependent and independent valves, as illustrated on picture below, so I exclude two additional motors): - Forward and rear PPTOs; - Mouldboard attack angle; - Horizontal mouldboard shift; - Diagonal mouldboard shift; - Left and right main mouldboard cylinders. The two-pump compressor is auxiliary function and it has independent RC too (1 x M). All of these functions are provided by 17 Power Function motors connected to seven IR Receivers and two AA-Battery Boxes (electric scheme of the model you can see on the picture below). Model composition: Total pneumatic hoses length – 14.8 m. Scheme of pneumatic connections: The model has opening doors with locking, realistic mirrors and lights, some versions of rigs – forward (additional blade with pneumatic control or additional weight for mouldboard pressure increasing) and rear (pneumatic controlled ripper). Opening bonnet makes possible a visual control of pneumatic valves working. Paralleling of the Power Function channels is realized by covering/uncovering some IR Receivers by using independent RC channel (mode switch). The mode switch consist of three M-motors, one of them is used for dependent pneumatic valves management. The model is very big, so I create special platform for its transportation. And a small video demonstration: Thank you for your attention! Edited February 24, 2020 by desert752 Quote
Alasdair Ryan Posted July 23, 2013 Posted July 23, 2013 Amazing grader Desert752. I love how all the functions are wireless. Quote
LayinBricks Posted July 23, 2013 Posted July 23, 2013 Awesomely complex! Did you do the software model after you completed the build? Quote
07jkearney Posted July 23, 2013 Posted July 23, 2013 That is gargantuan! Good work on packing so many features in. Quote
legomuppet9 Posted July 23, 2013 Posted July 23, 2013 Awesome model with so many functions maybe the wheels are a tad small... my only criticism Quote
KirTech LAB Posted July 23, 2013 Author Posted July 23, 2013 Awesomely complex! Did you do the software model after you completed the build? Thank You! No, virtual model building is too difficult task for this project... Awesome model with so many functions maybe the wheels are a tad small... my only criticism Thanks! Yes, the wheels are a little smaller than the scale require :( Quote
skriblez Posted July 23, 2013 Posted July 23, 2013 Man, that is amazing! Great work on a huge and well functioning model! Quote
jorgeopesi Posted July 23, 2013 Posted July 23, 2013 Awesome and yes you need bigger wheels or a smaller grader . Many times I thought to build another one but there are too much functions for me... Quote
timslegos Posted July 23, 2013 Posted July 23, 2013 That is one huge grader! I think the wheels almost look too small . Great work though! tim Quote
Junpei Posted July 23, 2013 Posted July 23, 2013 That is a huge amazing MOC! :thumbup: Why do the front wheels have such excessive camber angle? Would power puller wheels work? I guess 6 might not be in your budget. Quote
EyesOnly Posted July 23, 2013 Posted July 23, 2013 Awesome model. I like the combination of studs and studless. My recommendation for wheels would be to look into rc wheels. Check out this thread for lots of ideas. It would probably be cheaper than powerpuller wheels and you would have lots of choices for how the wheels should look. I think that the camber angle is part of the steering somehow. Watch the video to see what i mean. Quote
Piratedave84 Posted July 23, 2013 Posted July 23, 2013 I hardly ever stop and comment in the Technic forum (Although I drop by every day to lurk) but this truly deserves recognition. I don't think I have ever seen a model packed with so many functions before! It looks awesome and is fully functional, AND it looks great; good job! Quote
dhc6twinotter Posted July 23, 2013 Posted July 23, 2013 You have an amazing amount of functions packed in there! The method of uncovering/covering the IR receivers is both simple and genius. Nicely done. Quote
Blakbird Posted July 23, 2013 Posted July 23, 2013 Absolutely amazing model of a totally unique subject. Incredible work not just on the model but on the presentation including the electrical and pneumatic functions. Do I understand correctly that the "mode switch" for the electrics happens by merely blocking the receiving port on the IR receiver? Do you have a picture of how this works? I am also interested to know how you command the pneumatic functions. Did you use autovalves? Quote
timslegos Posted July 23, 2013 Posted July 23, 2013 Do I understand correctly that the "mode switch" for the electrics happens by merely blocking the receiving port on the IR receiver? I believe it works by turning one battery pack on and the other off, not entirely sure though. tim Quote
rm8 Posted July 23, 2013 Posted July 23, 2013 I believe it works by turning one battery pack on and the other off, not entirely sure though. tim Curtain cover one receiver and open other to switch functions Quote
Foggy Posted July 23, 2013 Posted July 23, 2013 I love graders and hope one day TLG will make a flagship of this subject. This model is amazing! HAT OFF man for all the job and presentation with the schemes!! Big compliments again! Quote
KirTech LAB Posted July 23, 2013 Author Posted July 23, 2013 Why do the front wheels have such excessive camber angle? The front wheels chamber angle is near zero! Front wheels can tilt simultaniously - this is the feature of the most graders. Do I understand correctly that the "mode switch" for the electrics happens by merely blocking the receiving port on the IR receiver? Do you have a picture of how this works? I am also interested to know how you command the pneumatic functions. Did you use autovalves? Yes, i did "shutter" that covers top part of the IR Receiver. I'll upload illustration later. I did not use autovalves. I use some simple RC valves. Compact RC valve consists of M-motor, worm gear and 24t gear. I believe it works by turning one battery pack on and the other off, not entirely sure though. I considered this variant, but it is desirable to have the third battery box to realize it, that's why i found another solution. Quote
Junpei Posted July 23, 2013 Posted July 23, 2013 (edited) The front wheels chamber angle is near zero! Front wheels can tilt simultaneously - this is the feature of the most graders. Oh. That's called 3D steering, right? What happens if you adjust the camber all the way, get to the max turning angle, and rotate the turntable all the way? Do you get very sharp turning? Edited July 23, 2013 by TwentyLeggedHen Quote
grum64 Posted July 23, 2013 Posted July 23, 2013 (edited) Awesome! This is either witchcraft or the work of a mad genius! Edited July 23, 2013 by grum64 Quote
N-4K0 Posted July 24, 2013 Posted July 24, 2013 This grader is amazing it's incredibly realistic and well done, great work Quote
FuzzyBallz Posted July 24, 2013 Posted July 24, 2013 Wow, I'm speechless. The complexity with all the motors and then the pneumatics is mind numbing! Bravo Sir! Quote
KirTech LAB Posted July 24, 2013 Author Posted July 24, 2013 Oh. That's called 3D steering, right? I don't know special term for this mechanism. Additional tilt angle is needed to compensate a front axle drift that is caused by the load on the mouldboard. Quote
