Blakbird Posted February 13, 2014 Posted February 13, 2014 The functional difference I found was that the splines that hold the axle do not go all the way through the wheel. Are you sure that they will work on Land Rover? When I test fit them on a shaft, there is obviously play in the shaft because it is not being held all the way to the rear surface of the wheel. Yes, I'm sure. If you don't like the new wheels then just send to me and I'll use them. Quote
keydave Posted June 5, 2015 Posted June 5, 2015 The next days i´ll upload some pics of my gearbox with the bands, so you can see what kind of rubber bands i use now. I´ve spend many hours to make the gearbox ~99% reliable...... it´s a patience game. Hi! It was a long time ago you built this creation but do you have any pictures about the gearbox fix? When I change the speed from 1 to 2 it always jumps in neutral. Also I have tried several rubber bands. I will appreciate your help. Quote
