  • Replies 2.9k
Posted Images
Does any one have good tips for making a stain glass window with semi clear 1x1 slopes?
Hmm... Actually, the only thing I've ever built (or seen, I think) using them (your talking about trans-clear cheese slopes, right?) would be the third build in my Challenge VI entry, and those were only half windows :laugh:
If you had a few different colors (and the patience) you could make a mosaic or something though :wink:
Ooc: Loving all the activity up here :sweet:
Edited by Garmadon
yes I was talking about the cheese slopes, I think I'll try what you did, but with a full window.
After "joining" mitgardia a year ago and attempting to build for the final book 1 challenge, I've had little to no time at all to contribute at all. Regardless, I've been following the progress of GoH rather closely, so decided to come on today to just give a shoutout to you guys and say that your builds never cease to amaze, keep up the good work guys. Hopefully I'll be able to be more active at some point, but we all know real life has it's own priorities.
Edit - Decided I'll upload those long overdue pictures of those builds I smashed together in a week of the final challenge - but never got around to contributing. Nothing spectecular I must say, but do have a gander and of course comments and criticisms are more than welcome.
https://www.flickr.c...06/12489722243/
https://www.flickr.c...in/photostream/
Edited by nivremis
Wymond the Fox has returned from wandering the deep wilds of Mitgardia and wishes to pledge his services to the guild once more. He is at home in the wilderness having served as a guide through the various mountain ranges and having kept watch over a section of the wild near the southern border. Wymond prefers stealth and cunning to battle, though he can stand his own in a fight if the need arises.
Now that I'm around a larger portion of my Lego collection, I hope to be able to build more and better than I did for the previous Book of Historica and to learn from the amazing builders in Historica.
Really like the builds nivremes shame you couldn't enter them in time.
I hope to have my archery phase 2 uploaded tomorrow as well, if I get up early enough! Haha
Edited by IenjoyLego89
The only time I've done it was in my Book I, Challenge VI entry, where I built the windows laying down in frames (2 bricks thick where I had trans-clear panel pieces in the bottom). With the 4 studs wide and I-don't-remember-how high surface, the cheese slopes created quite a pressure so it was no problems raising the windows vertically after pushing on the upper part of the frame (which actually was not possible to push all the way down on the studs).
Good luck!
Keep them in tight with a row of bricks on each side until you are ready for photos. I nearly used this technique for my Temple of the Mad Monks but they fell out each time I moved it. Nearly turned me into a Mad Monk!
:classic:
Edited by robuko
Valdrfell Stables:
@Nivremis: Glad to see you're still keeping an eye on Historica at least, I hope you get some building time soon.
Your challenge I build looks very good, I like the fig posing and rockwork :thumbup:
@Direlda: Glad to see you back in Mitgardia :classic:
#1 - Don't try it unless you have a lot of patience! That's a key ingredient! Other than that, I would suggest mapping the design out (with actual bricks) on your desk/table/hard floor, making sure it's the right size and all. The larger it is the more patience you will need, I suggest you do a smaller pattern for starters, if you want a large window you can combine slopes and other trans-pieces (example). Keep in mind that four cheese on top of each other (rotated of course) = roughly 5 plates (actually slightly more, but usually a bit more pressure or a virtually unnoticeable crack between plates will remedy that). Here are some nice patterns, and here's a nice description of the cheese slope sizes.
Cheese slope sizes are fairly consistent but not absolutely. In a stained glass window where the smallest size error can make a big difference, if you find that something's not working when it mathematically should, try swapping some of the cheese.
Hopefully that helped you!
Here is a stained glass window I made of a cup and sword using trans plates and slopes.
It's surprisingly stable since I just forced a lot of the pieces in there. I used a wall behind it to stablize while building, then took it down when it was complete. I used bracket pieces on both sides so I could have the pieces connected on either side which also added some stability.
Looks nice, though personally I prefer the slightly less 'stud-y' technique of just cheese to the pixeled look the 1x1s give. Good job with the pattern though.
Just in general (no need to change it here, especially if your bricks are limiting you) I would think that a building fancy enough to have stained glass wouldn't have so many different brick colors in its wall.
Thanks for the tips, I was able to throw together a good window for a beginner,I'll post a pic of it here soon.
EDIT: here's my window I threw together, any further tips?
https://lh6.googleusercontent.com/-daV0xGE7DUM/Uv1O6zL5f7I/AAAAAAAABRA/v5Nol9cAteQ/s2048/photo%2B%25281%2529.JPG
Edited by Bkrosell
Welcome to the guild, Direlda, great looking sigfig there :wink::thumbup:
I'm still trying to figure out what to do for Barracks Phase I :laugh:
@Nivremis, great to see you back, and yes, you need to link your build to the AoM thread (I mentioned that in your builds' thread too) :classic:
https://lh6.googleus...oto+%281%29.JPG
It doesn't have an obvious color pattern, you could probably improve that by playing around with it a bit more. Also the tile on the bottom should be black to match the rest of the frame.
Oh man, I haven't been here in a while, I have missed a ton of awesome creations by the great Mitgardian builders, plus I love the history of the sig figs done by Garmadon. I have been busy working on a large project these past few months, that I decided to set somewhere in Historica. Here are some work in prorgress pics:
Enjoy!
Wow! Amazing scope you got there, the towers look great and the cliffs are awesome! :thumbup:
I agree with Kai, you definitely need a black tile at the bottom (Something the top of my Stained glass window is also missing. Though overall it does look good, the colors are pretty random but I like it. Of course your window is going to need some lighting on the inside for it to really stand out. Eventually you will have to work up to making designs, similar to this: http://mosaicbricks.blogspot.com/2012/06/cheese-slope-mosaics-tutorial.html
