Balrog Posted August 25, 2013 Posted August 25, 2013 Hi Jurgen, I didn't check the instructions yet too thoroughly nor do I have 42009 yet. But I have a question. Have you included sync for the winch when raising/lowering and extending/retracting the boom or are the speeds just synchonized by the gearing up/down and simultaneously using them? From the video it looks as being automatically synchonized. Quote
leksivalen Posted August 25, 2013 Posted August 25, 2013 This will be very fun to build and play with. Thank Jurgen for this awesome mod's Quote
Theo van Vroenhoven Posted August 25, 2013 Posted August 25, 2013 When I did a comparison of the partlists of the original 42009 and the ultimate version I found out that the 92693c01 (Mini Linear Actuators) are missing in the partlist of the Ultimate 42009. However they are present in the instructions so I am curious how this could have happened and if there may be more glitches... Quote
therealjustin Posted August 25, 2013 Posted August 25, 2013 Are any additional pieces needed to redo the longer boom? Quote
technicmad Posted August 25, 2013 Posted August 25, 2013 You can see the list of parts that are in U42009 and not in 42009, or vice-versa, here: http://rebrickable.com/compare?s1=42009-1&s2=MOC-0853 Quote
Junpei Posted August 26, 2013 Posted August 26, 2013 (edited) Nice mods, wish I had the parts for it... Edited August 26, 2013 by TwentyLeggedHen Quote
Jurgen Krooshoop Posted August 26, 2013 Author Posted August 26, 2013 Hi Jurgen, I didn't check the instructions yet too thoroughly nor do I have 42009 yet. But I have a question. Have you included sync for the winch when raising/lowering and extending/retracting the boom or are the speeds just synchonized by the gearing up/down and simultaneously using them? From the video it looks as being automatically synchonized. No, the winch is not syncronized. But because all functions are motorized independently and are operated with x/y joysticks, you can controll boom lift, boom extention, upperstructure rotation and winch with 2 joysticks. When I did a comparison of the partlists of the original 42009 and the ultimate version I found out that the 92693c01 (Mini Linear Actuators) are missing in the partlist of the Ultimate 42009. However they are present in the instructions so I am curious how this could have happened and if there may be more glitches... The mini'la's is not a "standard" ldraw-part, because is can shange shape. I had to "assemble" it myself. That's why it didn't make it to the parts-list. I'll fix it. Quote
Alasdair Ryan Posted August 26, 2013 Posted August 26, 2013 (edited) The mini'la's is not a "standard" ldraw-part, because is can shange shape. I had to "assemble" it myself. That's why it didn't make it to the parts-list. I'll fix it. It should be there in three versions...I guess you will need to use the sub part commanded. Edited August 26, 2013 by Alasdair Ryan Quote
Erik Leppen Posted August 26, 2013 Posted August 26, 2013 I was genuinely surprised when I saw you put a battery box right there in the middle of the chassis. It looks like a wonderful build. If there's one MOC built by someone else I would like to try, it's this one. Quote
Tech-nick Posted August 26, 2013 Posted August 26, 2013 (edited) Is on Rebrickable now: http://rebrickable.c.../ultimate-42009 Thanks! Rest of the parts needed are on the way. From the set I'm buying I will get the missing XL motor and one pair of IR units. Then I'm only lack of lights but they'r not neccessary. Edited August 26, 2013 by Tech-nick Quote
BobSmithHello55 Posted August 26, 2013 Posted August 26, 2013 Awesome modification! Now, is it possible to put reverse lights and turn signals? I will try to do that once I finish the Ultimate 42009 itself. Thanks so much! Quote
EyesOnly Posted August 26, 2013 Posted August 26, 2013 While this model is fantastic i had a look at the parts and noticed some things that prevents me from building this thing now. First i need another transmitter. Second and more important, i would only have 2 M-motors left if i built this model. Since i want it to sit on a shelf for some time, that would make mocs much harder so i'll pass for now. I wont build this model just to take it apart a few weeks later so for now i think i'll build the reach stacker later on. Anyone feel up for making a ultimate out of it? Quote
Alasdair Ryan Posted August 26, 2013 Posted August 26, 2013 (edited) Anyone feel up for making a ultimate out of it? Not me. Edited August 26, 2013 by Alasdair Ryan Quote
Hopey Posted August 26, 2013 Posted August 26, 2013 This looks fantastic. I can't wait to build it. I'm getting the 42009 soon and plan on building the official model first soi can appreciate all the changes you've made. One small comment though: I'm not sure what software you used to make the instructions, but does it have an antialiasing option? Because if it doesn't, it should. I find the jagged edges on all the lines a bit distracting. Other than that, superb work. Quote
Arfman Posted August 27, 2013 Posted August 27, 2013 This is an awesome mod. I put together the partlist with BrickLink and am missing about €250 in parts, unless I part some of my vehicles (the 2007 Bulldozer for instance), I then get it down to about €150. Sigh .. what to do, what to do :) Quote
Jurgen Krooshoop Posted August 29, 2013 Author Posted August 29, 2013 (edited) Parts list on Rebrickable and jurgenstechniccorner.com have heeb correcten to include Metal hook and PF-extention wires. This looks fantastic. I can't wait to build it. I'm getting the 42009 soon and plan on building the official model first soi can appreciate all the changes you've made. One small comment though: I'm not sure what software you used to make the instructions, but does it have an antialiasing option? Because if it doesn't, it should. I find the jagged edges on all the lines a bit distracting. Other than that, superb work. I using LPub to generate the PDF-file at 200 DPI, that the highest quality my PC is able to produce. I don't know anything about graphic aliasing, so any suggestion would be welcome. On the other hand, higher quality will also produce larger files.... Edited August 29, 2013 by Jurgen Krooshoop Quote
Therion Posted August 29, 2013 Posted August 29, 2013 Jurgen, you can set AA-options in ldview, General tab. I always use it, i don't think it has much impact on filesize though. Quote
Blakbird Posted August 29, 2013 Posted August 29, 2013 The jagged edges are not from the original LDView images. LPub's instructions files are based on PNG images, and for some reason Acrobat does a terrible job of converting PNGs when making a PDF so these bad edges are added in the PDF conversion. I have tried many different settings in Acrobat trying to combat this behavior, but the only time I have found a good looking result is using more than 300 dpi which is bad for file size. Quote
nsxz Posted August 30, 2013 Posted August 30, 2013 It's funny how people were saying there isn't enough room for RC on this one You have proven that they are all wrong! Thanks for the instructions you rock Jurgen! Quote
Jurgen Krooshoop Posted September 4, 2013 Author Posted September 4, 2013 (edited) I've created parts-list images. Full-size files can be found here Edited September 4, 2013 by Jurgen Krooshoop Quote
CisFran Posted September 4, 2013 Posted September 4, 2013 Thanks Jurgen. Now it's easier to find what additional parts needs to be purchased Quote
therealjustin Posted September 5, 2013 Posted September 5, 2013 (edited) Jurgen, I noticed a few differences between the BrickStore file and the new images for just the additional parts: 62462 yellow pin connector, 2x or 3x? 42610 wheel 11x8mm 5x, not on new images Edited September 5, 2013 by therealjustin Quote
