  • Replies 110
These aren't my designs... these are designs I have just discovered on Shapeways that I found interesting... I haven't tried any yet. I'm thinking of it though. Anyone can do it quickly and easily.
Yep... you can choose all kinds of different materials (like ceramic even???) and the different materials allow different resolutions/detail.
Edited by TasV
I was thinking I might try a few designs of my own and see what the quality is like.
Actually I have done this. The results were so so. Definitely usable, but not for all parts.
Let me look them up and share some pictures.
That's very cool!
True!
Like I said, it's useable, but the material is a bit grainy and the sizes are a bit different. So they don't fit as well as original parts.
If the material would be a bit better, this would really be awesome. But it's not bad, not bad at all.
The planetary gear also clearly shows the graininess:
I don't think you will be very pleased with that part
Based on the part, the materials, or the drawing? I'm not overly happy with the drawing and am redoing it at higher resolution and better quality when I get some spare time. The dimensions aren't very accurate in this drawing.
Edited by TasV
Hmmmm..... I'd be interested in some custom rims. :sweet:
Funny that you mention this, because custom rims was the reason I tried Shapeways in the first place. I would also like to have different rims.
Based on the material. It's fine to use a part with technical function, like some sort of pin. But I am not sure about using it as a liftarm.
I've redone the liftarm file and think I will send it to them to see if they can do it and see if it's any good. It's much higher quality and I've drawn it so that each hole, and the rounded ends, is a modular unit so I can just stack them end to end to make them as long or as short as I want. The model was made in Google SketchUp. If anyone would like the file just PM me.
The drawing was based on this diagram:
Ref: http://bricks.stackexchange.com/questions/2066/what-are-the-size-of-lego-technic-parts
Edited by TasV
