  • Replies 98
Doubt it.
Me too.
Fortunately gravity is working for me, so it won't be a problem this times, but still I would like to know if there's a better solution for this problem.
Yeah, but that's 4L isn't it.
Yes a diff is 4 long but that would work on it's own like what Weavil posted.
This type of backlash always appears when you have more than one axle going through a turntable.
But when you add gears to the axle going through the different, it becomes at least 6L without any spacing. If you put diff then beam then gear it becomes 8L.
I'm looking for 6-wheels motorized vehicles (or 8-wheels), something in the nature of a 9398 Crawler but instead of 4x4 it's 6x6.
I'm building one myself and I'm having trouble finding a good sollution for the suspension.
I don't think my english is good enough to provide a decent explanation of the problem so It's probably better if someone could give me (some) links to older MOCs featuring 6 or wheel Trial Trucks.
I think your English is very good! Nico71 has a very good design for a mini 6x6 on his website :) a place to start anyways!
close to what i did not to long ago...
I never put on LDD before I took it apart so its hard to remember exactly how it was. LXF
Thanks a lot! I will take a look.
Yes, but that introduces a LOT of backlash! And that's what he's trying to avoid ;-)
Indeed :sweet:
The driving ring extension is a major no no :laugh:
Not sure if this post belongs here or should start a separate thread! I am looking at ways to make a large beam (cross section approx. 3 x 3 studs) as strong as possible. I have come up with these ideas, in studful and studless (these are 'opened' to show the construction) p1020026.jpgp1020035.jpg but wonder if anyone has better ways. The studfull appears stronger (in terms of bending and torsion) but is much more difficult to assemble since the whole of one side needs to be fixed at once across a large number of pins. This is a pain when trying to sort out how the ends of the beams are joined together. To see what I'm trying to do, there are more photos of the application (a W.I.P.) here . If I can decide on the best method I'll need to order a whole load of new parts, but don't want to order parts for the wrong method - and if I can't make the beams stronger than they are now I think I'll have to abandon the project!
Thanks Jim. I have tried the 3x5 liftarms but the results seem similar to using the pin connectors. The cross-section could bigger at 4 x 4; but 3 x 3 seemed a good size to use for the long pins and other available parts. 4 x 4 would be tricky in studful, it would need to be 4 x 5 or even 5 x 5. I'll do some experiments - if it works it will be costly at Bricklink!
I did think about these but there are no holes across the centre (in the right direction!) for the middle three layers of liftarms. This wouldn't matter so much for connecting sides made of studded bricks, because the middle layers are held by the studs. Anyway I have made a 5 x 3 version of both p1020037.jpgand the studded version is considerably stronger when trying to bend the beam (in the vertical direction , which is most important). (ignore the 'bend' in the photo, that's due to the camera lens!) .... thanks Blakbird, just seen your comment after posting mine. Yes, triangles are strong but the diagonal (5) needs a 6-hole liftarm doesn't it? -not available in thick and expensive in thin. The 5x3 liftarms are a good compromise.
Edited by quilkin
OK, thanks guys. Tests with the 5x3 cross-section made with (studded) bricks and joined with 5x3 liftarms are good, so I'll go with that. I'll need about 100 12-hole bricks, 50 or so 5x3 liftarms, 200 long pins and I haven't yet worked out how many 8x1 or 6x1 plates as spacers. The colour scheme will be better than my test constructions! Careful planning will be required to ensure I can fit the two half-sections together for each of the three beams; that'll be up to 60 pins to push home at the same time.....I wonder if they'll ever come apart?
If you're using any normal-length (2L) friction pins, make sure none of them are the old ones (the ones without center slots)! Those are hard enough to pull out one at a time.
