Vectormatic Posted November 3, 2015 Posted November 3, 2015 I was originally not going to get the Carrier, but did in the end. It's far from being in scale with everything else, but I like it. The minifigs are all nice. Meh, scale is always an issue, not even the various fighters line up, at least the tie fighters are close enough (the carrier should be ~7-12 studs longer to match perfectly) Anything bigger then small fighters is going to have waaay too much size variation to find a common scale in Lego anyway. Ive got my Carrier in the mail, stoked for it, even if ill have to leave it closed till christmas Quote
Artanis I Posted November 4, 2015 Posted November 4, 2015 It's a big hangup for some, but for me the scale difference is only really apparent when you can't put minifigs in something. In this case, you can't put minifigs in the TIEs, and they are far from the same size as the "system scale" TIEs, so it is noticeable to me. If it didn't have the TIEs, I probably wouldn't care one bit. As it is, I care a very very small bit. Quote
Kman860 Posted November 4, 2015 Posted November 4, 2015 That worked, thank you! I wasn't doing it right. No problem Quote
Vectormatic Posted November 4, 2015 Posted November 4, 2015 It's a big hangup for some, but for me the scale difference is only really apparent when you can't put minifigs in something. In this case, you can't put minifigs in the TIEs, and they are far from the same size as the "system scale" TIEs, so it is noticeable to me. If it didn't have the TIEs, I probably wouldn't care one bit. As it is, I care a very very small bit. Remove the ties and adapt the mechanism to carry two of the upcoming at-dp microfighters, as seen in the series ☺ Quote
rollermonkey Posted November 4, 2015 Posted November 4, 2015 I think the polybag AT-DP are the perfect scale for use with the Gozanti... Quote
Vectormatic Posted November 4, 2015 Posted November 4, 2015 I think the polybag AT-DP are the perfect scale for use with the Gozanti... Hmm, i suspect they might look a bit small-ish, i have two of those though, so i could try it out. Anyway, i suggested the microfighter since Artanis wanted something to carry figs in, and four proto-Ties doesnt make much sense yet. Quote
ChiefPie Posted November 4, 2015 Posted November 4, 2015 Should I get the gozanti for my growing imperial army? Quote
Fuppylodders Posted November 4, 2015 Posted November 4, 2015 Should I get the gozanti for my growing imperial army? No. Quote
Robianco Posted November 4, 2015 Posted November 4, 2015 No. Fup doesn't always say very much. But when de does... Quote
pittpenguin123 Posted November 5, 2015 Posted November 5, 2015 Should I get the gozanti for my growing imperial army? that depends if you like it or not. Quote
YellowCorvette Posted November 6, 2015 Posted November 6, 2015 Should I get the gozanti for my growing imperial army? I personally like the Gozanti and I think that it's a good addition to your Lego Galactic Empire army, but the windscreen is way too big and make the ship itself looks extremely out of scale. Quote
Cyanide-Tipped Posted November 7, 2015 Posted November 7, 2015 I personally think the Gozanti to be an eyesore (sorry for the hate). :( Quote
Vectormatic Posted November 7, 2015 Posted November 7, 2015 Well, ill chime in and vote in favor of the Gozanti, it needs a few simple mods (there is a thread on it floating around), mainly the windscreen and spacing on the Ties, but it is a cool looking addition to the Imperial fleet imho, something different then the omnipresent star destroyer Mine is sitting in the garage waiting for christmas, and its killing me :P Quote
JPN366 Posted November 8, 2015 Posted November 8, 2015 What about 8 of these in black to modify the wing laser cannons on the X-Wing to get the "pitchfork" look on the end? http://www.brickowl.com/catalog/lego-bracket-1-x-1-1-x-1-42446 Quote
La Chupacabra Posted November 8, 2015 Posted November 8, 2015 Anybody knows when UCS Slave 1 will be availble again? Quote
lewis Posted November 8, 2015 Posted November 8, 2015 Help id parts please Big pieces are not Star Wars... UFO Quote
pittpenguin123 Posted November 8, 2015 Posted November 8, 2015 smaller is the old tie fighters window Quote
Richard Dower Posted November 8, 2015 Posted November 8, 2015 Buying a new or second hnad set is out of the question...so its buying as many parts brand new where possible, and buying everything else in used condition. if one was not obessed with having the original mold designs, or not too bothered about special printed pieces...is it possible to build 10179? as in can you find all the parts?.... what are the rare/qunique parts only found in the set?...are there newer sets that have new mold designs that could be used as alternate parts etc? overall i just want to know if its possible to buy and build it in 2015? Quote
Terrasher Posted November 8, 2015 Posted November 8, 2015 Yes, it's possible, tons of people have built the UCS Millenium Falcon. I'm not too keen about 10179's rare / expensive parts but I do know that there are two grey mast riggings that are quite expensive but that can be substitued by spray painting the same part but in a cheaper colour or by using other bricks to remodel the area where these pieces are needed, and that there are a lot of grey antenna pieces (grey base and antenna) that can be replaced with black antennas (grey base, black antenna). All in all, yes, 10179 can be built in 2015 but some modifications have to be done if you want to save a lot of money. Quote
Lobot Posted November 8, 2015 Posted November 8, 2015 Hi It's entirely possible to Bricklink a UCS 10179, but the cost will depend greatly upon how accurate you want it to be. I've built two of them in the last couple of years; I sourced everything new but made several replacements and the total was £600 - £625. From other attempts I've seen recently some of the rarer parts are getting quite prohibitive, so you may need to make some more compromises, it's up to you, although buying used parts will help. There's several threads about it, here's a few to start with http://www.eurobrick...showtopic=67818 http://www.eurobrick...showtopic=80053 http://www.eurobrick...howtopic=114619 For future reference, there's a general Q&A thread pinned to the top of the forum. I'll merge this with it in a bit Quote
Lobot Posted November 8, 2015 Posted November 8, 2015 Help id parts please smaller is the old tie fighters window Yes, it's part 30366pb02 Quote
Darth_Brick360 Posted November 8, 2015 Posted November 8, 2015 Boba Fett (UCS) Boba Fett (10123 Cloud City) Greedo (Original version) TIE Pilot (UCS) Bespin Guard (Original version) Darth Maul (Polybag) Darth Maul (Clone Wars) Wullffwarro (Rebels Wookie) C-3PO (Polybag) Thats about it off the top of my head... ish... I didn't realize wullffwarro and the TIE pilot had arm printing. That makes 10 if you include jerk-14 Quote
Retromatt Posted November 8, 2015 Posted November 8, 2015 ty for help , I need to dig up other bits! Quote
