Per_SW Posted June 24, 2020 Posted June 24, 2020 17 hours ago, Mandalorianknight said: I've been looking at getting a republic gunship, but they're pretty dang expensive. I have yet to look through to see which pieces I have in my collection already, but currently it's $100 plus 4 orders of shipping without the figures or sticker sheet and using a different print for the bubble turrets. Does anyone have the gunship, and do you think it would look good without the stickers? I did bricklink mine without the figures and stickers and I agree with @jdubbs that apart from the ones on the wings -and maybe the ones with the republic logo- the rest are not that essential, although I was looking at replica stickers on ebay that go for much less than the original sheet. That said I'm sorry for the prices of the ball turret, I was lucky to snag the four needed from a local seller for 0.29 each and have to agree that the prints do matter in this case. Also while looking trhough the pieces you already own keep in mind the old trick of color-swapping the internal ones if you already own them in a different color, I'm sure it saved me quite a bit. Quote
Mandalorianknight Posted June 24, 2020 Posted June 24, 2020 1 hour ago, Per_SW said: I did bricklink mine without the figures and stickers and I agree with @jdubbs that apart from the ones on the wings -and maybe the ones with the republic logo- the rest are not that essential, although I was looking at replica stickers on ebay that go for much less than the original sheet. That said I'm sorry for the prices of the ball turret, I was lucky to snag the four needed from a local seller for 0.29 each and have to agree that the prints do matter in this case. Also while looking trhough the pieces you already own keep in mind the old trick of color-swapping the internal ones if you already own them in a different color, I'm sure it saved me quite a bit. Thank you for the advice, I'll be sure to keep that trick about the internal pieces in mind! Quote
din0_21 Posted June 29, 2020 Posted June 29, 2020 Hi, Sorry i am new here. I hope i am posting at the correct thread. I am new to lego MOC and i am inspired to learn and try doing my own SW MOC. That being said, I am clueless on how to resolve off-axis angles and hope someone can advise and teach me the proper way. 1. I copied star destroyer wing design. Ie. to go off at an angled axis, with a hinge at front. Need find a way to hide it 2. However i cant find a suitable hinge to help connect the end on the right. Hope to get some advice on the know-hows here. 3. I wanted to get a clean no-gap exterior and hence i tried incorporating a hinged-4x2 that creates a 28deg in the center. However, is there any way to cover up that mini trapezium hole? Thanks so much! Quote
Mandalorianknight Posted June 29, 2020 Posted June 29, 2020 Welcome to eurobricks, @din0_21! I'm not that good at MOC making, but I came up with 3 solutions. You could put some rounded 1x2 plates with one stud on the 2x4 and one over the hole, then adding 1x1 quarter circle tiles over the hole. I believe that would cover it. This isn't too obtrusive and likely to work but doesn't fit your current angular design. You could put some more angled plates on top of the 2x4 and 8x4 pieces, with the wider end covering the hole. This would keep the design as close as possible to what you've shown but I don't know for sure if it'd work. The third option depends on what your MOC is going to end up being, but you could remove some of those 4x2s to lower it and then stack some plates on that 2x4 and place a tile over the hole. I don't know what your intentions are for the end shape of this MOC though, and it might change the design too much. I hope one of these helps. Quote
Gremer2 Posted July 4, 2020 Posted July 4, 2020 Has anyone built the Victory-I or Lucrehulk V2 from Jorstad Designs? I'm interested in both of them, but I want to know how stable they are and if there's any rare, expensive parts required for them before I buy the parts list. Quote
2maxwell Posted July 6, 2020 Posted July 6, 2020 Is there any reason why lego doesn't use 3L bar pieces for shoto sabers for characters like Yoda and Ahsoka? They already have it in the trans bright green and light blue colors so they might as well. Hell, I'm planning on using them for double bladed sabers myself since the 4L bars just seem too long and unwieldy in lego form. Quote
Mandalorianknight Posted July 6, 2020 Posted July 6, 2020 2 hours ago, 2maxwell said: Is there any reason why lego doesn't use 3L bar pieces for shoto sabers for characters like Yoda and Ahsoka? They already have it in the trans bright green and light blue colors so they might as well. Hell, I'm planning on using them for double bladed sabers myself since the 4L bars just seem too long and unwieldy in lego form. They seem to be used in translucent colors mainly in CMF sets, although there are a few exceptions like construction kylo. It's possible it has something to do with the slightly different plastic used in CMFs. Good idea though, I want to use one of those trans green ones for my yoda now! Quote
Sucram Posted July 11, 2020 Posted July 11, 2020 I want to buy the UCS Falcon from the online Lego Shop, but its out of stock. How often is this the case? Do scalpers buy them all the second it gets in stock? is there a way for me to be notified when it is in stock? Im in Australia btw Quote
Mandalorianknight Posted July 11, 2020 Posted July 11, 2020 8 hours ago, LEGODrongo01 said: I want to buy the UCS Falcon from the online Lego Shop, but its out of stock. How often is this the case? Do scalpers buy them all the second it gets in stock? is there a way for me to be notified when it is in stock? Im in Australia btw I think the best you can do is just wait for it to restock if you want to buy directly from lego. Looks like there aren't any on bricklink in australia except for one $400 more than what lego sells it for. There's one for $660 NISB in france, so with shipping to australia you might be able to get it for around the $800 retail price. Quote
Sucram Posted July 11, 2020 Posted July 11, 2020 4 hours ago, Mandalorianknight said: I think the best you can do is just wait for it to restock if you want to buy directly from lego. Looks like there aren't any on bricklink in australia except for one $400 more than what lego sells it for. There's one for $660 NISB in france, so with shipping to australia you might be able to get it for around the $800 retail price. I don’t really want to buy it from bricklink, considering the size and price of the set. I’m just gonna check LEGO Shop and Myer until it’s in stock. Quote
Csaba Posted July 12, 2020 Posted July 12, 2020 (edited) Does anyone know whose Tie Bomber MOC is in this video at 2:20 and if instructions are available? Edited July 12, 2020 by Csaba Quote
jdubbs Posted July 12, 2020 Posted July 12, 2020 7 hours ago, Csaba said: Does anyone know whose Tie Bomber MOC is in this video at 2:20 and if instructions are available? It's not the one pictured in the video you linked to, but Barneius' version is similar, and I've heard nothing but good things about it: https://rebrickable.com/mocs/MOC-22018/barneius/bomber-twin-ion-engine-bomber/ Quote
Csaba Posted July 12, 2020 Posted July 12, 2020 3 hours ago, jdubbs said: It's not the one pictured in the video you linked to, but Barneius' version is similar, and I've heard nothing but good things about it: https://rebrickable.com/mocs/MOC-22018/barneius/bomber-twin-ion-engine-bomber/ I think this one is quite a bit smaller. The one you've linked to appears to be minifig scale whereas the one in the video is the same scale as the UCS TIE Fighter. It's still a really nice model. I'm working on Jerac's minifig scale TIE Bomber at the moment, this has made me want another minifig scale bomber :) Quote
jdubbs Posted July 13, 2020 Posted July 13, 2020 Pretty sure they're both System scale. Both use a 6x6 cockpit glass piece, wing panels are the same number of studs tall, etc. Quote
Fuppylodders Posted July 18, 2020 Posted July 18, 2020 Given that it now seems definite that they won't be producing a minifig scsle/system set release of a TIE bomber, can anyone point me in the direction of what seems to be a decent moc out there (instructions available would be a big pro) that also fits a minifig in it? Quote
TeddytheSpoon Posted July 18, 2020 Posted July 18, 2020 56 minutes ago, Fuppylodders said: Given that it now seems definite that they won't be producing a minifig scsle/system set release of a TIE bomber, can anyone point me in the direction of what seems to be a decent moc out there (instructions available would be a big pro) that also fits a minifig in it? I'm not sure if there are instructions for the bomber specifically, but Jerac's TIEs are the gold standard I reckon. Quote
autolycus Posted July 18, 2020 Posted July 18, 2020 58 minutes ago, Fuppylodders said: Given that it now seems definite that they won't be producing a minifig scsle/system set release of a TIE bomber, can anyone point me in the direction of what seems to be a decent moc out there (instructions available would be a big pro) that also fits a minifig in it? Brickvault has instructions for purchase. They've got TIE Fighter, TIE Bomber, TIE Interceptor, and TIE Advanced all in the same scale. You can buy the instructions 1 at a time or as a bundle. Quote
jdubbs Posted July 18, 2020 Posted July 18, 2020 2 hours ago, Fuppylodders said: Given that it now seems definite that they won't be producing a minifig scsle/system set release of a TIE bomber, can anyone point me in the direction of what seems to be a decent moc out there (instructions available would be a big pro) that also fits a minifig in it? There are several on Rebrickable that will hold minifigs, including Barneius', which I linked to above. There's another one that's around 1000 pieces, roughly equivalent to what LEGO would do, I would guess. Quote
Fuppylodders Posted July 18, 2020 Posted July 18, 2020 Thank you guys, appreciate that :) will check them out! Quote
2maxwell Posted July 27, 2020 Posted July 27, 2020 I wont say which figure exactly, but someone bought out almost every US Bricklink store of a certain Star Wars figure (that was going for ~$20 new over the last 6 months) and now has 6 of them listed for almost 4x that price. They are now the lowest priced seller of that complete figure in the US. The scalpers are getting out of hand man. Quote
Archer Posted August 15, 2020 Posted August 15, 2020 Has anyone else who owns the 75244 Tantive set experienced bubbling with the stickers around the cone / cockpit pieces? I'm very good when applying my stickers and have never had bubbles show up over time like they are here. It's very irksome given that they provide a lot of the detail on the front of the set. Quote
Redroe Posted August 20, 2020 Posted August 20, 2020 On 8/15/2020 at 8:19 AM, Archer said: Has anyone else who owns the 75244 Tantive set experienced bubbling with the stickers around the cone / cockpit pieces? I'm very good when applying my stickers and have never had bubbles show up over time like they are here. It's very irksome given that they provide a lot of the detail on the front of the set. I built up my old Tantive and got to say, much as I hate stickers on curved parts, the colour mismatch between the white mold and the white-on-trans print for the cone pieces is really irksome. I wondered about getting some aftermarket cones and stickers to replace the printed trans parts. Quote
Kit Figsto Posted August 21, 2020 Posted August 21, 2020 This is a bit random, but the thought popped into my head today and I was curious - What early (say 1999-2005ish) SW molds or prints have remained the same since being introduced? I know battle droids are an obvious one and are entirely unchanged, the astromech and protocol droid molds have stayed the same this entire time, Qui-Gon's hairpiece is the same, and I believe the Gungan mold is the same? Quote
LurkingEhlek Posted August 21, 2020 Posted August 21, 2020 The Gungun mold is different with more depth to the eyelids in the original version. A more apt example would be the Rodian head which as seen plenty of use since greedo. Bib Fortuna's headpiece was also shared between versions. Lightsabers are obviously the same configuration, but apart from those and what you mentioned, as a rule of thumb a lot of early molds have been phased out (Or in the case of the Rebel Pilot Helmet, given an altered helmet once then reverted back to the original). Quote
Mandalorianknight Posted August 21, 2020 Posted August 21, 2020 4 hours ago, Kit Figsto said: This is a bit random, but the thought popped into my head today and I was curious - What early (say 1999-2005ish) SW molds or prints have remained the same since being introduced? I know battle droids are an obvious one and are entirely unchanged, the astromech and protocol droid molds have stayed the same this entire time, Qui-Gon's hairpiece is the same, and I believe the Gungan mold is the same? Old ben's hair! Aside from a few other hairpieces, I don't think any other 2005 molds are the same, besides the Rodian, Male Twi'leck, and rebel pilot helmet @LurkingEhlek mentioned. Quote
