Blakbird Posted January 7, 2014 Posted January 7, 2014 Here are some renders of this awesome model. Can't wait for the instructions to be available! Quote
750ACE Posted January 7, 2014 Posted January 7, 2014 This is funny, I was about to bump this thread today asking about the status of the instructions. I hope progress is being made. Quote
Balrog Posted January 7, 2014 Posted January 7, 2014 Is it just me or do the wheels look rather small in the renders? Quote
LEGO Train 12 Volts Posted January 7, 2014 Posted January 7, 2014 I've seen this beauty on youtube yesterday ...and I've no words! The sequential gearbox is a masterpiece ...and the brake system is a masterpiece too! This supercar in lego version is better than the real one! Quote
Blakbird Posted January 7, 2014 Posted January 7, 2014 Is it just me or do the wheels look rather small in the renders? They are a bit small, yes. Since these renders are made directly from the CAD file which uses very precise geometry, I can assure you that the render reflects the correct size of the Lego tires and wheels. On the other hand, the suspension is not compressed in the CAD file and the flexible axles used for the fender are not quite right, so this can give the illusion of different tire size. Quote
AndroTech Posted January 7, 2014 Posted January 7, 2014 UAU !!! .... the car is mind-blowing ..... excellent job on renders Blakbird ...... what was the part count, and was the car build with any rare parts? Quote
jantjeuh Posted January 7, 2014 Posted January 7, 2014 Since these renders are made directly from the CAD file which uses very precise geometry, I can assure you that the render reflects the correct size of the Lego tires and wheels. On the other hand, the suspension is not compressed in the CAD file and the flexible axles used for the fender are not quite right, so this can give the illusion of different tire size. You misunderstood me, I think the tires used are a bit small for a car that size. But then again, there aren't any bigger ones available. Quote
Alasdair Ryan Posted January 7, 2014 Posted January 7, 2014 UAU !!! What does that mean? When I look at the renders it make the curves on the body look a bit too sharp. Quote
Blakbird Posted January 7, 2014 Posted January 7, 2014 You misunderstood me, I think the tires used are a bit small for a car that size. But then again, there aren't any bigger ones available. OK, I understand. Yes, I agree that the rear tires especially are a bit small for scale. There are larger tires from the Silver Champion but they are too big. UAU !!! .... the car is mind-blowing ..... excellent job on renders Blakbird ...... what was the part count, and was the car build with any rare parts? Part count is about 4000, but you'll have to wait for Sheepo to provide more specific information. White parts in general tend to be more difficult to get than other colors. Quote
jantjeuh Posted January 7, 2014 Posted January 7, 2014 There are larger tires from the Silver Champion but they are too big. I think those have more or less the same diameter right? Just broader. Quote
Blakbird Posted January 8, 2014 Posted January 8, 2014 I think those have more or less the same diameter right? Just broader. Yes, the diameter is the same. Quote
Balrog Posted January 8, 2014 Posted January 8, 2014 Since these renders are made directly from the CAD file which uses very precise geometry, I can assure you that the render reflects the correct size of the Lego tires and wheels. On the other hand, the suspension is not compressed in the CAD file and the flexible axles used for the fender are not quite right, so this can give the illusion of different tire size. That makes sense. But I have seen some renders before, which also had a twixed perspective regarding the wheels. But I am to lazy now to look for an example. Quote
MasterEC Posted January 8, 2014 Posted January 8, 2014 Would it be "wise" (for the looks) to use other wheels, even aftermaket wise, bigger ones. If such exist that is :) Quote
Jurgen Krooshoop Posted January 9, 2014 Posted January 9, 2014 Propably not, bigger wheels would cause technical issues. Quote
Zerobricks Posted January 9, 2014 Posted January 9, 2014 What a beauty!!! Love all the angles and curves, very organic! Quote
Blakbird Posted January 9, 2014 Posted January 9, 2014 That makes sense. But I have seen some renders before, which also had a twixed perspective regarding the wheels. But I am to lazy now to look for an example. I'm not sure what it is about some of these pictures that gives such an optical illusion, but I have heard it remarked before that the front wheels look smaller than the rear wheels. Yet if you hold a ruler up to your screen and measure, you will see that this is not the case. I think this may be a matter of perspective. If you photograph a model from a short distance, you get perspective which makes the rear wheels appear smaller. But if you render with the camera at a very long distance, they are both the same size which is actually different than what you expect. Quote
Polo-Freak Posted January 11, 2014 Posted January 11, 2014 YES, the Instruction is available @ Sheepo's Garage Quote
jantjeuh Posted January 11, 2014 Posted January 11, 2014 Yep, go get it people :) Note that there is an RC and a manual version, make sure to buy the correct one. I'm only two parts short Quote
Kumbbl Posted January 11, 2014 Posted January 11, 2014 Fantastic news... @Sheepo: at your website you write the following regarding this instructions: "Build this car is very hard, if you have never built a Lego Technic set, I recommend you to do it first. Doing that is not necessary but it will help you later when you built the Land-Rover <...> Also you must think that the pieces are not perfect, so the gearbox are not 100% reliable, it should make good around the 90% of the speed changes" I'm now refering to the bold marked parts: is this copied from the Land Rover description and is therefore the warning about the reliability of the seq. gearbox here? Or with other words: is this also true for the Shelby gearbox or is this just a copy&paste-error? ;) Thanks a lot for your efforts and this awesome car and instructions! Quote
jadedomg Posted January 11, 2014 Posted January 11, 2014 Yay! I am looking forward to getting the parts and putting this one together, it will be a permanent piece most likely Quote
kevman Posted January 11, 2014 Posted January 11, 2014 will this be on rebrickable soon ? need to check my inventory. Quote
