The_Cook Posted November 6, 2013 Author Posted November 6, 2013 (edited) One of the other key features of the trolls are their seige engines with their big speckle silver wheels. I had been considering some form of extra-muros industry in terms of yards for creating the siege engines. My gut feeling was that I should be looking at the 7036 Dwarves Mine or the more recent Lone Ranger 79110 Silver Mine Shootout for inspiration which I duly did and felt that they weren't quite what I had in mind. What I was thinking of was some form of double height wall from which extends tiered platforms for building siege engines, and a siege engine being built. Perhaps a gateway at height through a gap in the wall that leads out onto the walkways. Given that I'm thinking of tiered platforms it's going to need something with some height, therefore it has to be a siege tower being built. The siege tower could be a duplicate of the one in 7037 Tower Raid or it could be a simpler construction that follows the same basic premise; notably for forward leaning of the slopes. It's worth noting that the the mid platform of the siege tower in 7037 Tower Raid is at 12 bricks high and the top platform at about 18 bricks high. A little bit more playing in LDD whilst on the tube allows me to flesh out the structure. From a conceptual point of view I'm happy with the general shape but the actual execution leaves a lot to be desired. Twin mountains either side, these work and the Burps build up bulk quickly. Upper level door feels like it's going to work. Twin height platforms. Something in behind: stockpiles, anvils, sawpits High level crane to get onto the upper deck. A tower structure could support the crane. It might be nice to try to substitute one of the upper LURPs for a tower assembly to give a little bit more asymetry. Can the side mountains be pivoted for flexibility? Needs to open inwards rather than outwards so that it's not covered by the platforms. Support, how? Something structurally strong. Check to see what the Dwarf mine did. Width, 4 or 5 studs. Anything wider and the support gets harder and the interior becomes inaccessible. There are plenty of ideas above to work on based on the first sketch model. As it stands the first sketch was only 100 bricks, so there's room for more to be added. Second attempt. One of the mountains has been replaced with a double height tower. The gate has been moved to the inside and both mountains are now hinged. It's getting better but the platform structures are still a little lacking and there's no detailing for the interior in terms of construction materials. The structure is currently 170 bricks, although that will probably increase as the platforms are rebuilt. A small siege tower will probably be a good 80 bricks, another 30 for interior props and 20 on a collection of minifigs. Having spent a few days away from the design I'm now certain that the platforms aren't right. It's very reminiscent of the situation I was in with the Trolls' Landing, where the jetties weren't right. I try to work that train of thought through. It's obvious that the flat plating of the platforms is incorrect and that they need to be replaced with the "planking" of my Troll Town. What supports the planking? The spindly Support 1x1x6 Solid Pillar don't work but I can't see how to form rock pillars that will sensibly support the platforms without them becoming too crowded to get into. Then lying in bed in a Polish hotel room with a stinking cold I started thinking could I support the platforms off of BURPs. There's precedent with the Trolls' Landing the Trolls build on top of rock outcrops so the base layer of the structure could easily be BURPs. The following day I start to make changes to the design. The old platforms are removed and I stick in two BURPs back to back, except they don't fit. The doorway isn't wide enough. I open up the doorway and it becomes much more like the doorway from Trolls landing, this improves the look of the gate tremendously since it's more balanced and symmetric than before. A bit more work and I have a first level platform built across BURPs and LURPs. The current design has the BURPs and LURPs immediately adjacent to each other, but I recall now that I was thinking about separating them and creating an arch between the two, or just spanning the gap. This precedent / design motif follows the arch in Troll Forge between the wall and the forge. Separating the BURPs and LURPs allows me to raise the platform. The proportions are better. I try to construct an upper level but around halfway through I realise that it's not tall enough and it's too late in the evening for my fatigue addled brain to work out how to raise it the few bricks necessary to make it work. It is however showing promise, the structure is right and the design is falling into place, it's just needs some more effort to get it to work. What I can't work out at the moment is how to support the upper platform. A few days later with a clear mind I try to get the upper level built again. It needs some form of pillars and the style that is currently being used to support the lower level is based around black 2x1x3 Inverse Slope 75. I follow that through and use those slopes atop a 3 high stack of 1x1 bricks. If I turn the slopes outwards I can run supporting beams across the outer edge and have some form of tie across to the opposing pillar; this is important because it provides structural support to the upper platform. The architectural detail is shown in isolation in the image below, it's unique enough and interesting enough that it will join the series of architectural details that I outlined in Trolls' Landing and I'll use it elsewhere in future builds. I use a mix of wedge plates to plate out the platform. One last minute change is to replace one of the 1x1 bricks in the stack with a headlamp that has had a helmet horn inserted into it. This completes the structure; numerous cosmetic tweaks occur over the next few days but the structure itself remains unchanged. The design focus moves to the siege tower. Earlier revisions had had a half height siege tower, my idea being to mount some form of flick fire missile on the top. The problem is that a flick fire missile is feels too small atop a siege tower even a half height one. The solution is a bigger missile! Enter the competition cannon, there's already precedence for these in that one is mounted to the bottom of 7041 Troll Battle Wheel. I mount one in the middle of the siege engine and fashion a crude firing lever up the back. The flick fire missile is retained on the top but it's no longer the principle armament. Much happier with this design and it's added in. Several weeks elapse between the design being finished and being in a position to create it in ABS. The bricks took a while to arrive and then I've been building the earlier models such as the Troll Kings Hall and the Troll Forge. The build itself is fairly easy, the main issues being finding the right bricks. Everything goes together smoothly over the course of about two hours. I think my biggest concern is that for all it's bulk it's quite compact; it's got height but not much spread. I did have concerns about reaching into the lower platform and whilst it's tricky it's not impossible to get a minifig in there. Seen here with additional Siege Engines docked. The two Siege Tower variants side-by-side. Whilst clearing the models away at the end of the day I realise that I've built the siege engine wrongly there should be some Brick, Arch 1x8x2 in the upper section to provide structural support. I'll rectify that over the next few days ready for when I assemble Troll Town in all it's glory; my rough calculations are that it will fit on my table but only just. Unfortunately LDD files are unavaillable whilst I find another file hosting site. PM if you want them. Edited July 4, 2020 by The_Cook Quote
Mutant Orc Posted November 6, 2013 Posted November 6, 2013 This is such a cool project!! I have lurked here for a while but I don't think I ever commented- I really like your builds and I'm looking forward to your next. The only issue I have is with the siege towers, but you are doing it in a very TLG style and I didn't like theirs either so it's not really your fault. back to the main point- Brilliant! Quote
The_Cook Posted November 17, 2013 Author Posted November 17, 2013 (edited) The Trolls' Guarded Inn has been shown in it's own thread. Progress is being made on building up The Graving Dock, WIP photo's shown below. 7048 Troll Warship to be docked; there's a Troll warrior in the second photo for size comparison. Despite it's size (70 studs by 40studs) it's just under 1200 bricks (without minifigs). I'll post photos, full design notes and the LDD files once I return from a two week business trip to Warsaw, which will allow the last few BrickLink orders to trickle in. Bricklink orders to build up the last two models, Troll Marketplace and The Dragon Platform, have arrived and the all important Dragon has been sourced. I should be in a position to display Troll Town in it's entirety before Christmas. Initial calculations are that it will just fit onto my 1.4m x 0.9m dining room table... Edited November 17, 2013 by The_Cook Quote
csc166 Posted November 23, 2013 Posted November 23, 2013 I tried to download LDD manager so I could get a piece inventory for all of these, but I could not do so. Would some body help me out and either attach a link or tell me another way to do so? I absolutely love these and I want to know what pieces I need to create them! Please and thank you Quote
The_Cook Posted November 25, 2013 Author Posted November 25, 2013 I tried to download LDD manager so I could get a piece inventory for all of these, but I could not do so. Would some body help me out and either attach a link or tell me another way to do so? I absolutely love these and I want to know what pieces I need to create them! Please and thank you LDD itself will can produce bill of materials: File -> Export BOM . It will produce an excel spreadsheet with a list of all the parts and pictures of them. If you don't have Microsoft Office installed then OpenOffice will open the files. The only unique parts are that aren't listed at Lego Customer services are the actual Troll parts (such as banners and shields) which you'll have to pick up from Bricklink. Everything else can be obtained from either Lego Customer services or Bricklink stores. Usual caveat of "it pays to shop around" and be aware that Customer Services might actually be cheaper for simple parts in uncommon colours, eg. 1x2 plates in Dark Green were cheaper at Customer Services than my local Bricklink Stores, Happy building, if you do complete something please post photo's it's always good to know that somebody has been able to replicate a model since they are designed for building rather than display. There are a couple more models in the pipeline but work in the Real WorldTM has taken me away from my bricks for a few weeks. Quote
csc166 Posted November 26, 2013 Posted November 26, 2013 Thank you so much! It will take me a while to get everything together and clear some time to build it, but when I do, I will post pics and let you know how the build was Quote
The_Cook Posted December 6, 2013 Author Posted December 6, 2013 (edited) How about a market place, somewhere to sell the treasure the Troll's have accumulated? I was using the 7571 Fight For The Dagger as the structural inspiration for the market. Brick built angular arches working towards a BURP lined gateway. The concept of the market is still valid but this attempt isn't working. A few weeks later I started to think about the Troll Market again. Thinking about it in terms of caves from which wares are sold, caves very similar to the Troll caves either side for the main entrance on 7097. Two of those side-by-side. Could they be modular in their own right? A stair section? A bridge section? A hinged section of exterior wall that provides the perpendicular attachment. The thing about Chase For The Dagger is that it represent a scene in a movie where there's a chase, there's an obvious storyline to it, people chasing each other to get at something. How can we replicate that in the Troll Market? One of the market caves is a Prison Cell? Some way of getting the back off to break out of the cell. Then there can be chase, up and over, the props from the market form things to knock over or utilise for hiding. Then up the steps, over the top and swing out across the wall on a chain dangling from a crane. Why not make it a maiden (or feisty peasant woman rather than the sterotypical princess) who escapes. Troll, Ogre+Cart, Feisty Peasant Woman, Knight on Horse. In terms of props for the second cave; cloaks, armour, helmets and swords are all typical Troll things and would have more interaction value than food which could go in the cart. My recollection of the Troll caves is that they utilise two Mountain top panels across the back so there should be scope for hinging or loose breakaway of a panel. The tops are provided by a 6x8 plate which provides a suitable platform for a cross top-walkway. Some from of tower on the hinged outer wall would provide enough height to mount some form of crane. Possibly utilise the architeture from the siege engines for the tower rather than further stonework. Any gateway has to be sufficiently large to accommodate the Ogre and cart. This may have impact on the playability in terms of swinging across the outer wall. If there's a crane there should be playability in it, crates or barrel halves to lift from the cart. Idealy the crane is moveable on a swivel is chain based rather than string but has some degree of lift. One of the castles had a chain driven drawbridge - 7079. Can some of that mechanism be replicated on a crane? Beginning to feel that a troll crane is a big thing in it's own right in order to wind chain and have some form of ratchet to limit the unwinding of the chain. Might be better to pull a beam upright and have a chain dangling from the end rather than continuous chain from drum to hook. From an ideas perspective I think that the market concept now has merit and perhaps most importantly some form of story thread to enhance the playability. However I won't get an opportunity to fire up LDD and tackle the design until I get to the airport this evening and have a couple of hours to waste before boarding my overnight flight home. A chance to fire up LDD. The two caves are blocked out quite quickly and the arch and stairs added. Current cost is 180 bricks which is high for the size of set this was intended to be. The brick built caves are costly in terms of bricks compared with the inspiration set where a couple of arches form the main structure. The structure feels like it's going to work but at the moment it's just too big, it needs shrinking by at least one layer of bricks and the width of the caves could probably be brought down as well. The rebuild prison cave weights in at 46 to 68 bricks, so a 22 brick saving. 52 to 35 for the rebuilt open cave, so not quite as much of a saving. 18 to 11 for the stairs. Total for the 3 segments plus the stairs is 187 to 134, so 53 bricks saving, over 30%. The scale feels more human (rather than Ogre) although I still have to work out how to get the Ogre to pull a cart. Built up the a simple cart for a Troll to pull. Nothing fancy just a couple of long poles to allow the Troll to drag it. The width is about 7 studs, therefore the gateway needs to be 8 studs wide once opened to allow access, which means a 10stud space give that the clips that make up the hinges take up a stud either side. A section of modified wall allows the gateway to be connected to the perpendicular run of caves. With a 10 wide gateway there is going to be an issue of how to plate it. Another tube journey, another slew of improvements and additions. The main focus this time being the gate the upper structure and the crane. The gate was quick and easy to finish with rocky spike being borrowed from 7097. Those rocky spikes were also transposed to the top of the two caves to provide a back to the upper walkway across the caves with spiked rails being used across the front. I'd had a couple of attempts at using the styling from the siege engine in 7037 to create the tower. For the first few attempts I'd been building it running front to back which kept blocking the walkway across the top; the eureka moment was turning that through 90 degrees to allow continuation of the walkway; It seems obvious now, I have no idea why I didn't start that way to begin with. A 1x8 black arch in the middle gives some rigidity to the structure as do the 1x6 black tie bars across the sides. At 7 bricks high it's easily high enough for little hands to gain access and get minifigs through when the chase takes them that way. The crane is the thing that I'm least happiest with. Everything else clearly has the troll design DNA running through it but the crane looks like a couple of technic bricks thrown together. Which is essentially what it is since I was trying to work out how the chain winding mechanism and retaining ratchet would work. Mechanics done it's something that I need to revisit before I can call this design done. To determine the current brick count the props and minifigs were added. The feisty maiden (or as close as I can get with LDD's limited selection of female torsos and skirts) goes into the prison cave with a large bone to allow her to lever the back wall open. There's a knight on a horse outside to rescue her and two orcs to acts as guards. The second shop cave gets an armour stand, a barrel with swords and a bench with bottles. Rebuilt the crane. Decided that the key thing to tackle was the boom and replaced the two long Technic beams with a plate structure that has more of a resemblance to the troll doors and floors that I've been creating. It has cost a few more bricks but the effect is significantly more appealing. Further improvements would be to remove or cover the Other than waiting for time and bricks to be available to build it, the build went together very easily. A couple of minor colour substitutions en-route but pretty much everything major is as-designed. The main problems are in the crane, structurally it's pretty solid but the cam lever to stop the winding chain doesn't engage particularly well and the crane itself isn't quite long enough to swing someone out around the gate. All things that can be fixed with a little time and ingenuity but not something that I can correct immediately. The modularity allows the sections to be combined in different ways. The sections could even be part of the primary wall around Troll Town. Then to the storyline; our feisty maiden trapped in the prison. With the help of an old bone she prises the rocks apart at the rear... ...and is free. Sneaking past the hag selling rotten food. Hiding from Troll guards. Climbing the stairs to freedom. Swinging out across the market on the crane Dropping to freedom and riding away on the cart. This chap has been absolutely no use what-so-ever! Unfortunately the LDD files are temporarily unavailable whilst I search for an alternative file host. PM me if you would like them. Edited July 8, 2020 by The_Cook Quote
Mutant Orc Posted December 7, 2013 Posted December 7, 2013 Ha-ha! Grinning knight was hopeless! I like this but I find that the handles for the cart are out of proportion to the size of the cart itself. Quote
Soundmanred Posted December 18, 2013 Posted December 18, 2013 I really enjoyed looking through this thread. Being a Fantasy Era fan (and recently assembling my 7094 Kings Castle Siege and falling in love again!) these are more interesting to me than most "modern" MOCs. Quote
The_Cook Posted January 2, 2014 Author Posted January 2, 2014 (edited) What the Trolls lack is a Dragon of their own. The Skeleton Sorceror has one, the Crown King has one, the Trolls don't. Definitely not fair for the trolls. Looking at all the dragons that TLG have ever produced the one which best suits the Trolls has to be the Hungarian Horntail dragon from the Harry Potter series, which is nice but not cheap. Bricklink the Dragon alone is going to be 30ukp if I get it from Europe, 50 if I get it within the UK. eBay sales are probably few and highly contested... Still, regardless of whether I can realise this in ABS I press on regardless. My starting point is the Wall Defence model that I drew up the other day to act as a filler to close a gap in the second instance of Troll Town. I dismantled the slightly rickety wooden platform that had had a small catapult mounted on it, the idea being that this would form a bridge over to the dragon platform, similar to the design of 70403 Dragon Mountain. The initial problem is that the central pivot in the wall is only 2 studs wide and a bridge probably needs to be 4 studs. Because of the way that the rocks hinge back 2 studs isn't a problem but it limits what can be attached on the opposing side. I realise that if I increase this to 4 studs I can insert technic bricks with the right spacings to allow standard wall attachments; I decide to carry this concept on through the design so that each of the components, bridge, dragon platform, rock walls and stairs, will have connection points allowing lots of flexibility. The bridge is fairly simple, black 1x8x2 arches mounted atop troll style windows to give it a bit of character. I start by trying to squeeze the design of 70403's Dragon Platform onto an 8x8 plate, but it doesn't really fit so I opt for 10x10 octagons instead which give the structure a more rounded feel even when the support is actually square. There are various tweaks and changes, primarily the replacement of the rock walls with brick built equivalents which contain the technic bricks that form the attachment points, but essentially the structure is the same. I retain the potions lab inside but the treasure chest goes; Trolls would never leave treasure outside the walls. Two crownies to be terrorised by the dragon rider and it's all done; a short evenings work. Except it's not. Looking at it the following morning in a fresh light what it lacks is height on the wall side to visually balance the bulk of the dragon on the platform. I could rebuild on of the wall sections with a stack of French Towers but I've done that before on both the Engine Docks and the Graving Dock so I want to avoid that design choice. The thought sticking in my mind is some form of archway/tower over the end of the bridge. This is complicated however by the fact that doorway can't be attached to the central portion of the wall because those 4 studs will need to form the opening. The supports of the arch are therefore on the wall sections and some slightly tricky hinging is used at the top to support the top plate. Writing my design decision up the previous paragraph I have a few more moments of inspiration that could take the design down different paths. Firstly the blocky hinge mechanics at the top could be replaced with plate hinges rather than brick hinges. Secondly there is nothing to stop me having the hinge mechanics at the bottom of the arch to create an 8 wide platform there and then building up from that. Of the two options the latter turns out to have the most promise, it save a couple of bricks (3) and allows the arch to gain a proper inverse slope crown rather than the flat blockiness created by the hinges. The one disadvantage at the moment is that only the stairs can clip onto the back because the pivots of the hinge bricks extend into the space that makes attaching anything else impossible. One improvement might be to bulk out the width of the central section by another 2 studs to allow connection at the back. If connections at the back are allowed then why not extend the tower into something more structural rather than just an archway. After several weeks hiatus, where I've been out of the country and away from my bricks and building up the giant Graving Dock model, I started to think about the Dragon Platform again. For the design to work it needs a significant tower to balance the bulk of the dragon and the current gate just isn't bulky enough. So I pull the design apart and try to build a tower. I use the Dark Brown wood structures from 7037 Tower Raid as inspiration. Design finished I sit back and admire it; it looks awful! It's too spindly, awkward and just badly designed. Back to the drawing board; back to the source material. How does 7097 do it's tower? I start building 7097's tower section from the instructions. I start out faithful to the original but deviate a little as construction porgresses. The first floor becomes a through corridor to allow access to the bridge. The room above becomes a map-room and the tower top a signalling platform. We've gained in terms of brick count but surprisingly not that much. Finally the tower is massive enough to balance the bulk of the dragon. The Trolls gain aviator headgear for flying their dragon, it's a bit steampunk rather than medieval but I think it suits the trolls and I need to do as many things as possible to give the trolls some variation when they have such a limited torso selection. The second non-flying troll gains red and green flags to guide the dragon in, the tower acts a great place to stand. With designs finalised I start to build up the Dragon platform, primarily to determine what pieces are missing given that the design has changed quite substantially between the 3rd and 6th incarnations. The obvious parts are the various plates within the tower but also the Dark Brown roof turret top sections and a couple of basic Reddish-Brown bricks that I'm just missing. I'm also running low on basic Light-Bluish Grey parts; so various Bricklink orders are placed in order to get the relevant parts. It'll probably be the far side of Christmas before they arrive. Some of the Bricklink orders arrive before Christmas and some afterwards. It doesn't take long to finish the Dragon Platform, there are a couple of minor substitutions en-route but nothing that deviates too much from the main design. The chart room The robing hall where the helmets are stored Someone is having piggies for dinner... All in all, I'm very happy with how this has turned out. The larger tower is definitely needed to balance the bulk of the dragon. If I can source a second Dragon there is even the possibility of adding a second platform, the connection points are there for a second bridge and platform. I'll just have to keep an eye out for Hungarian Horntails... Unfortunately the LDD files are unavailable whilst I sort out an alternative hosting platform. PM me if you would like them. Edited July 8, 2020 by The_Cook Re-upload images Quote
ZCerberus Posted January 2, 2014 Posted January 2, 2014 Yep. Totally should build an troll army for Nocturnus is GoH. Lots of cool work here. Quote
thrak76 Posted January 2, 2014 Posted January 2, 2014 Great thread here! It's fascinating to see the transitions between LDD and actual bricks. In fact, this has inspired me to download LDD and start playing around! Thanks for the inspiration! Quote
csc166 Posted January 4, 2014 Posted January 4, 2014 I just finished troll hall and placed the orders for the remaining pieces for troll forge and I am deeply satisfied! The build was easy and fun, though the directions on LDD made it a little unstable at some parts during the build, but overall, great experience! Please keep up the great work! Quote
The_Cook Posted January 5, 2014 Author Posted January 5, 2014 I'm glad that you're happy with the Troll Hall. I'm afraid that I have no control over LDD's generation of instructions, or at least I think I don't... something in my brain is reminding me that control over the steps might be possible through editing the LDD xml file. Quote
The_Cook Posted January 6, 2014 Author Posted January 6, 2014 (edited) I started work on designing the Troll's Graving Dock as an academic project rather than something that would be a standalone set. The issue is that for it to be a play set it would need to contain the majority of a ship and that would add half as much again to the brick cost. It is however a very tempting project and one that in then end I eventually decided that I would have to realise in ABS. What would a Troll dock or slipway look like? The idea in my mind is something like a Fjord, towering cliffs on either side hemming in a boat. Caves in the cliffs allow the Trolls access to build there ships. Great chains wound on giant drums haul the ship up the slipway and above it all towers a rickety crane to lift the masts into place. The starting point is Light Purple. Before accusations of insanity are leveled against my good self the light purple has a purpose it acts as a scaffolding to build the graving dock around whilst being blatantly obvious that it's not part of the actual structure. Since Troll architecture isn't known for it's Light Purple it's an easy task at the end to select by colour all the Light Purple bricks and then delete them en-masse leaving the actual model. Using Light Purple I mock up the outline of 7048 Troll Warship with a couple of hull pieces, the outrigger boats, the mast and the battering ram prow; this gives me the something to build the graving dock around. I know that I want the inner end of the graving dock to be curved. Pure curves are a pain to do and never line up exactly with studs therefore the curve is going to be just three segements. So that everything fits a round number of studs those curves will be 3-4-5 triangles, or a useful scaling such as 6-8-10, where 10 just happens to be the width of a BURP. Three BURPs form the length of the dock with another hinged segment at the end to bend the wall around into the main wall of my rapidly growing Troll Town. Each of the faces of the curved end gain an arched entrance, for the two angled segments this is a full height arch for access to the dock, for the very head of the dock it's a small cave big enough to pass a chain through. The dock needs more height than just a single layer of BURPs but I don't want to just double them up or stack LURPs ontop as that would be visually boring. I use LURPs as bookend but the gap in the middle is filled with other stuff. One side gains an arch and ladder to descend on the deck of the ship, the other side gains a small tower and some barred gratings. Capping all of this off is a run of 4 wide plates that the crane will traverse over. Inspiration for the crane came from the Troll siege engines. The wheels were my starting point at 3 studs wide they neatly fit onto the platforms that I'd prepared with a line of bricks down the outside to keep everything running straight. Using dark brown Slope 75 1x2x3 and plates I constructed a nice rickety truss between the wheels and started thinking about putting a crane on-top. Except that the truss will hit the mast if the crane tries to move. The aim now is to get the crane tall enough to pass cleanly over the mast. A couple of extra slopes later and the truss spans the gap at a height suitable for passing over the mast. Turning my attention to the head of the dock I try to work out how to reel in the chains. I try a couple of halfhearted experiments trying to build some form of capstan but it's too fiddly to get the workings into a small enough space. I start thinking about vertical wheels and a mix of 7041 Troll Battle Wheel and 4183 The Mill springs to mind. I can use a giant wheel to drive a small drum through some Technic gears. A framework of dark brown slopes supports the wheel and winding drum. For stability the entire lot is braced across into the wall of the dock which forms a nice platform from which the overseer can direct the work. The clearances on this are very tight, when it comes to building in ABS it might require a bit of fettling to run smoothly. Last thing is to dress the back of the dock walls. Detachable sections are designed for both sides, on side has a storage cave with more storage space ontop, the other side has a small smithy. More playability if only the crane could reach them but the original design just spanned the space between the wheels so the crane is pulled apart for the third time and rebuilt to allow a sliding winch the ability to pass from outside the dock on one side across the dock and out the other side. All with enough clearance to allow items to be hoisted up and over. At 1200 bricks including figure, but excluding a ship, it's a beast of a set and clocks in at 74studs long, 52 studs wide and 35 bricks high. Building this one in ABS is going to be as expensive the rest of the sets designed to date put together. Sourcing the BURPs will require another TLG Customer Services order and there are a fair amount of large Dark Grey plates that it might not be possible to source elsewhere. After that it's all fairly standard piece that I just need to obtain a fair stock of. The bill of materials list 143 unique elements, excluding minifigs and utensils, most of which are easily obtainable it's just that they're used in large quantities. Parting out existing sets like my copy of 4813 The Mill will go a long way to providing the parts for the wheel and topping up the stock of Dark Bluish Grey. Colour choices might be an issue a quick scan of Bricklink reveals that the inverse 1x1x3 slopes aren't available in Dark Brown and the 1x12 plates aren't available in Reddish Brown so some recolouring will be required. I've two other sets in the pipeline for Trolltown that will need parts purchasing so once the existing batch has been built I'll compile a fresh inventory of the bricks that are left and work out what I need to obtain. It's likely to be Christmas at this rate before it's all done. I bite the bullet and place about 8 BrickLink orders totaling just over 100ukp in order to build the 2nd tranche of Troll structures including the Graving Dock, Guarded Inn and Dragon Platform. A TLG CS order to get Dark Green 1x2's, Dark Bluish Grey BURPs and some other bits and bobs. Since there is a paucity of Dark Bluish Grey BURPs available on Bricklink I decied to substititue the Marbled Dark Bluish Grey/Dark Green BURPs for the plain BURPs, the marbled ones will form the interior of the Graving Dock. Another interminable wait for the TLG order to arrive. To be fair the orders always arrived within the 7-9 days that TLG say they will take and that's reasonable given that it's being despatched from Denmark; it's just that I'm impatient and want it now! The order duly arrives exactly when TLG said it would. A window of opportunity opens up one evening. 3hrs to build the Graving Dock? If all the parts are to hand it's possible and the design actually only calls for a handful of parts so they should be easy enough to find. I need to pull black 1x2x3 inverse slopes out of my stocks as well as black 1x1 headlamp bricks. The later should be fine, the former is likely to be more of an issue as I don't recall having much of a stock of these as they get used so regularly in castle builds. The Graving Dock requires 2 more than I've ordered in tranche 2 and there should be 4 spare from tranche 1 so it should work. For the headlight bricks the Guarded Inn used a couple so I'll have to see what stocks I actually have in my boxes of black bricks. Between the three boxes of sorted, unsorted and uncleaned I should be able to locate the handful that I need. The bigger question is how long it will take since I'm on such a short time window. If I can get home and get some of the picking done prior to cooking the evening meal then that means I'll be ready to start building during my 3hr window. I'm considering building this one up on a board of some form so that I can move it around easier. 70x50 studs, I'll have to work out what that is in real world units and find some form of suitable board. This does however pose an interesting question, How can this open ended - U shape be made more stable? Stable enough that it can be moved on it's own by lifting the two sides without it collapsing inwards. The key would be to either strengthen the base or provide a support across the top. The problem here being that the base needs to be thin to allow boats to be pulled up over it and the top needs to be open for masts to fit through. I wonder if there's a way that I could use Technic beams to provide structural support across the bottom and have rollers that boats travel across. It would significantly increase the brick count and add complexity to the build because the walls would need raising by a brick. Or perhaps there is a way of splitting the build so that it could be moved in separate sections? The obvious point would be somewhere towards the closing end so that it comes apart into the two sides and the end; the difficulty is that the closing end requires some for of tie across it's width to ensure that it retains it's shape. I'll go with it as designed but it's something to consider if it's too unwieldy. Started building up the Graving dock in ABS. The build was going together reasonably smoothly until I realised that I was short lots of the Black 1x2x3 inverse slopes, there were only 7 in stock as I hadn't actually placed the order for 17 with one of the Bricklink stores. I've placed orders with 3 stores for another 36 inverse slopes plus some other bits like flags this morning with the hope that some might reach me by the weekend. Substitutions to the colour scheme were replacing the standard Dark Bluish Grey BURPs for Dark Bluish Grey/Dark Green mottled BURPs in the interior of the dock to give it some colour variation; I think that this has worked out quite well and the fade from Dark Green at the bottom to Dark Bluish Grey at the top of the dock is quite pleasant and gives the impression of moss and grass growing down in the depths of the dock. The wall structures are very robust, it remains to be seen whether there is sufficient strength laterally from side to side to allow it to be picked up. One modification that I will make is to extend some of the plating at the head of the dock into the dock until it intersects with the lateral plating, thereby locking the head of the dock in place which at the moment is free to move around on it's three hinges. I didn't have time to attempt the exterior sections such as the forge and wheel-store nor time to attempt the gantry crane whose structural strength is still one of my biggest concerns. To improve the strength of the lateral plating it would be possible to extend the underwall plating into the dock and support the lateral plating using slopes. The disadvantage si that this is an extra element rather than reuse of the prevalent 4x10 plated; additionally it still doesn't solve the primary weak point which is the join in the middle and is the point where any bending forces are highest. All that can be done at the center join is to increase the amount of plating layered over the top. The head of the dock has the advantage that there is now plating coming down from the head wall that will support it but there's little that can be done for the opening of the dock that will actually provide a rigid support all the way across. For all that the wall forming the interior of the dock are a line of BURPs I'm quite pleased with how they don't appear too repetitive. The marbling, the green wedges and the fact that the upper layers aren't regular all helps to give the impression that the walls are more irregular than they really are. One other way of breaking up the wall would be to substitute some of the brown 1x1's for black 1x2 inverse slopes stick out into the dock, these won't impact on the ability to all boats in. A 2x2 corner plate, a 2x2 corner plate; my kingdom for a 2x2 corner plate. I managed to get another hour of build and having had another 12off 2x1x3 inverse slopes delivered in the morning was able to get the sides of the graving dock complete. However my progress on building the crane is stymied by the fact that I need a large number of 2x2 corner plates and a data entry error in my ordering spreadsheet caused me to only source 7 rather than the 22 that I need. I'd accidentally entered 71 instead of 7 on the column detailing how many that I'd ordered from a shop which triggered the spreadsheet to colour the piece as green and as soon as items are green I won't bother trying to order more from the next shop... Another Bricklink order was placed late last night but it will be next week before it arrives and I'm definitely out of the country next week. As a structure it's pretty solid, I'm quite able to pick it up with a hand on each side without it feeling unstable; a fact that's probably helped by the fact that the hinges providing the articulation at the head of the dock are well locked in and that there's typically three of them supporting each join. This means that the ability to twist the walls is limited and therefore the strain on the plating and the bottom joins are reduced. A little bit further and another missing element, 6x10 plates in Reddish-Brown, I need at least 1 for the platform that backs onto the forge. One more Bricklink order in the system. Another batch off 1x2x3 inverse slopes arrived and I complete the last of the plating on the hinged sections at the open end of the dock. I assemble the wheel. A couple of modifications are made. Firstly the winding-drum design allowed the chain to wedge between the drum and the wall. I'm happier with the redesign but the next issue is that the mechanism doesn't run in reverse. What I mean by this is if I pull the chain then the wheel doesn't spin; this is due to friction between the wheel and it's supports and the fact that the gearing is working against the pull of the chain. This is a potential issue because the first thing that someone is going to do after winding the chain up for the first time is to pull on it to unwind it; I know this because it's the first thing that I did! The problem is arising purely because of the friction between the wheel and the supports, by leaving clear air between the wheel and the supports I can pull the chain out easily. Although the crane isn't fully built yet I've been considering alternative builds that might provide more rigidity up the sides, primarily using Technic beams. The initial attempt was a bit clumsy but I feel there's a way to make it work. Annoyingly the beams don't come in reddish-brown or dark red so it'll have to be black or dark grey. Another option that I might explore is to use Technic, Plate 1 x 5 with Smooth Ends, 4 Studs and Center Axle Hole and plates since I'd be able to add banners or teeth to the plates and use an appropriate colour. BL prices are high and the CS site hasn't been update to show prices yet. The image below shows a test models in LDD that I used to follow the ideas through. In the end it proved impossible to get the Technic Plates to align properly and my chosen solution was the left-most one that utilises a Technic, Liftarm 1 x 15 Thick. Corner plates arrive and I am able to complete the structure of the gantry crane. To cut a long story short, it's fragile! The wheels especially are prone to falling off therefore I'm going to need to properly investigate and add some form of bracing in order to keep it strong. There are a couple of options available, I should do an architectural detail model to show them. I'll also need to check my stock of black bricks to see whether I have any spare Technic beams. The box girders are robust it's just the wheels below that aren't strongly connected. Redesigned the capstan wheel in LDD, just need to realise the changes in ABS. Primary issue is going to be whether I have 1x16 bricks in Dark Grey that the change requires. Everything else I know I have it's just a case of pulling it from stock. Real Life finally catches up with me and my build time becomes limited as I jet of to Warsaw for a couple of days work. On the flight east I spent 15 minutes building up an architectural study of the various crane engineering options before fatigue took over and I feel asleep infront of the laptop. What I realised whilst building the study was that the 15hole Technic beam will reach right to the underside of the horizontal truss. This allows the bottom plate of the horizontal truss to be locked into place and we've already established from handling the existing model that the truss itself is strong due to the number of 2x1x3 slopes forming vertical connections and the double layer of plates forming the top beam. The cross connections are also fairly strong between the two sides because on the lower sections the cross plates are locked between other bricks, connections which will be further strengthened by the Technic beam locking them into place. Annoyingly however my last BL order was for a set of 11 hole rather than 15 hole beams. Therefore it seems likely that I'll have to place yet another BL order before I finally get this part of the build under control. Colour choice? The Technic beams are available in black and dark bluish grey or old brown. Black is marginally cheaper, I'll have to see what else the store has to see whether there's enough to pull an order together. Starting to favour Dark Bluish Grey over black. I also need to rework the main Graving Dock design to reflect the changes proposed by the study. Modified the LDD design to utilise the 1x15 Technic beams and placed an order for them, dark brown 2x1x3 normal and inverse slopes, 1x1 Technic bricks in reddish brown and 1x3 inverse slopes in reddish brown as well a some 1x16 dark bluish grey beams that are needed for the rebuild of the wheel support structure. It wasn't one of the cheapest BL stores but it was one of the few that had all of the required parts. Being several hundred miles away from my bricks means that not much more that can be done at this stage. I could perhaps think about a boat to go into the graving dock but should it be part-built or have the ability to be both part built and fully built? Build as major components that the crane can lift in? Requires the crane to be wider to be able to move pieces through, could probably scale from 10 to 12 maybe even push it out to 14 but this creates issues binding the top together; would need to use layered plates. Some form of snaps or Technic connections to bind the sub-builds to a simple hull structure? Brick budget around the 100 mark. If the crane is being made bigger is there any way to increase it's range? Invert the end-stop slopes, extend the end-stops out beyond the main part of the graving dock. The tower impedes the latter from occur would need to swap the two sides around so that the tower occurs on the outer edge. Visually less pleasing but it allows an overhang to exist. How to support? How much to support? 4 studs, 6 studs? Could we support a partial platform, ie. 1x8 tiles with gaps between? What would structurally support this? Something to investigate later. A few days and I'm back home again and I have a morning free to modify the graving dock. The articulated sections at the open end are swapped around to allow the crane tracks to be extended by another 4 studs. Additionally the stop points were rotated so that the sloping side faces inwards which should mean that the crane can get one brick further out, but since the crane is now a brick wider in each direction this balances out. The extensions utilised 4x10 plates rather than a more ambitious design with holes and is probably as adventurous as we can get given the lack of support beneath. I didn't get as far as a deconstructed boat, might tackle that this evening. Brick count is currently 1200 of which 30 or so are the pink bricks of the "ghost" ship that I've been using to determine appropriate sizings with another 30 involved in large props. Therefore it should be possible to easily achieve boat, minifigs and hand-props within a 1400 brick allowance. If I'm going to build a troll boat what are the salient features Viking hull with battering ram (ideally dark brown) Troll square sails (junk rigged? check precise phrasing although I know what I mean!) Inverse arches in dark red running up to a cabin. Hanging cage Drum Outriggers Without replicating the existing warship how can sufficient "clip-on" sections be provided. What can clip-on, cages, drum, outriggers are obvious. Masts? Cabin sections? Do we even want the outriggers, how can we make the ship different to the existing ship? Deliberately shorter, single. Some form of forecastle to launch attacks from, borrow from the siege engines of 7037 Tower Raid. Rear structure. Outriggers using canoes? Are canoes available in Reddish-Brown? Grapnels? Some form of mechanic whereby ramming drops the grapnels and latches onto a ship; nice but we don't have another ship to attack. Modular rear structure, left and right halves mirrored, no more than 8 bricks wide to fit through crane. How does it clip/fit? Slot together? I note that canoes are available in Reddish-Brown, would need to source Commanche Camps from the Lone Ranger theme, or they're 1ukp each on BL from reputable stores. 1414 bricks eventually. 6 trolls, a foreman, a blacksmith, a crane driver and 3 workers. The ship is shorter than the warship but follows the hull design. The rear structure is easily demountable and should fit through the apertures in the legs of the gantry crane. Double masted in the end with assault platforms at the front. The design is such ship can be docked backwards, unlike the main warship, so that the superstructure can be rebuilt with the crane. This required removing the outriggers but that saves 12 or so bricks some of which, ie. the canoes, are quite big. I realised that the oars and some row-benches were missing which has pushed the brick total up to 1428 bricks. Which is just about where I want it to be. We've finally got the dock, a boat within it which is the reason for it's existence and a number of trolls. If anything another few bricks to take us up to the 1450 mark with two or three more minifigs would just flesh out the dock and make it look as if it's busy rather than slightly sparse. One on the wheel, another in the boat and one in the stores. Total 1441, happy now. Another round trip to Warsaw and then I'm back with an hour spare to tackle the next part of the Graving Dock build. I extended the crane tracks out over the articulated sections at the open end and built up the wheel store. Still have a couple of finishing touches to add: Wheel store ladder Macaroni bricks around the forge chimney Flames on the torches and forge 1x2 Bley slope on the articulated tower section Winch for the crane 1x4 black plate and dark red teeth for the non-tower articulated section Tiling on the crane tracks Barrel, Minifigs and other props Boat! The Graving Dock without it's boat Forge Detail Chain Wheel Detail Gantry Crane I manage to find one more Bar 7 x 3 with Double Clips (Ladder) in order to complete the wheel-store but I definitely need to order as many of these as possible in my next Bricklink orders; the Graving Dock alone (with the landing craft) requires 6 more. I also complete the winch, forge chimney, forge, non-tower articulated section and the tiling on the crane tracks. This just leaves the boat. I've got an eBay bid in on a bare hull (no-minifigs or dragon) which I'm hoping will come to fruition at a reasonable price. Additionally I'm pulling together two orders to cover the deltas between a 7048 and what I need for the landing craft. Mostly fairly minor. A reasonable chunk should come from stock. I missed out on one boat, there's another coming up on eBay tomorrow that I'll have to take a shot at. Managed to get a Tower Raid for 25, but it's no recompense when what I really need are hull sections. I could also check my box of fantasy sets to see whether there's a Hull otherwise I'll have 3 boats which is more of a navy than I was expecting to amass. On top of all that I'm still waiting for the final bits to come to finish the graving dock. The latest work sojourn take me Stateside, I pickup and build Lake-town Chase whilst I'm over there since the dollar/pound exchange rate and pricing differential is in my favour. Upon returning home I find that I did have most of a 7048 in my big box of Troll bits, therefore I can start building up the landing craft. I manage to get most of the ship built but find that I'm missing 4off 1x8 brick in Dark Brown and that these hadn't been properly ordered in the last tranche of Bricklink orders. Only one shop is selling them in the UK and they've got a high minimum order going at the moment. I have a potential substitution in mind but I'm also missing the sails. I need to check the bottom of the box of bits to ensure that it's not just a case of me putting the sails in tidily at the bottom so that they don't get damaged. First two bricklink orders have arrived with most of the bits needed to complete the dragon platform and to finish the boat in the graving dock. The crane in the Graving Dock isn't quite tall enough; I need to raise it by a brick or two in order to get it to pass over the sails of the boat. This should be possible with the existing structure with a bit of tweaking. Added an extra two bricks worth of height which will get the raw masts underneath, I don't think it will quite allow masts with crows nests but I can always try. I did consider using a second Technic beam to extend even further up in order to give a full 6 bricks clearance at the top for the hoist carriage; however I think that the aesthetic is destroyed if the upper part gets too tall with respect to the lower half. The additional bricks are all 1x1 in Reddish-Brown or 1x2 Pallisade in Dark-Brown so I should have enough spares in stock to make the alterations. Over the Christmas period the final Bricklink order arrives and I manage to complete the boat for the Graving Dock and make the changes to the Graving Dock's gantry crane to accommodate the boat. The one minor issue that I still have to resolve is that the white horns sticking out the sides of the back cabin of the boat interfere with the foliage hanging down the inside of the graving dock. The latter will have to be relocated or removed in order to allow the boat to slide in properly. Other than that it just needs props and minifigs before it's ready to go. I'll try to photograph it over the next few days. Boat Detail Trolls' Graving Dock - Complete As always, the LDD files are located over on the MOCPages mirror of this posting. It's one of those sets that you possibly need to see in real-life rather than photo's; to properly appreciate the play value of assembling the boat in the dock. The Graving Dock is also the limits of my photo stage, there are millimeters to spare between the edge of the model and the end of the white background. The next job is to clear my dining room table lay some Dark-Grey and Blue card to form a landscape and then to set up Troll Town in it's entirety. I do have 3 more small designs lurking in LDD but they can wait. Edited July 8, 2020 by The_Cook Re-upload images Quote
Hive Posted January 7, 2014 Posted January 7, 2014 Impressive work, as always. I especially like how you turned the Dragon Mountain set into a troll set. I like seeing real sets modded like that. Great fit with the dragon, too. Quote
csc166 Posted February 2, 2014 Posted February 2, 2014 Just waiting to save up the funds to purchase the rest of the pieces for three more of your designs. Any more ideas coming down the pipeline? Quote
SMC Posted February 2, 2014 Posted February 2, 2014 very nice makes me want to try something big Quote
The_Cook Posted July 17, 2014 Author Posted July 17, 2014 (edited) It's been a long while since I last made an update, mostly due to European travel as part of the day job. Finally I've managed to scrape together the right bricks to get a few more bits of Troll Town completed. Maybe I'll be able to find a large enough table to actually set up the whole thing over the next week or two. This particular set is Cattle Poaching. I apologies if the narrative is somewhat disjoint, the initial ideas originally formed about 9months ago whilst building up The Graving Dock and it's had a difficult gestation period both in terms of design and sourcing the relevant bricks. What does Troll Town lack? It's got an Inn and a Feasting Hall, a tower for the sorceress and numerous buildings and mooring spaces for boats, siege engines and dragons. Something keeps drawing me back to animal pens, a menagerie? Think of the 7570 The Ostrich Race fences but between rock outcrops and penning in rock monsters or dinosaurs, at the worst bears or horses. Packs of hounds? Cattle? Use of the plastic wings to create shelters? Does it make a set - not on it's own but if you phrased it a as rescuing the stolen herd of cattle then it might. A more ambiguous title would be Cattle Poaching. Is it The Trolls that have poached the cattle or The Villagers? It means we're veering towards human influences such as cattle and horses rather than the arcane rock monsters or dinosaurs. 4 minifigures, 2 cattle and a dog. That was the idea, from there thoughts moved swiftly on how to arrange the plating? Is the set going to fit into the wall of Troll Town or is it going to be freestanding? Platforms around the rocks so that the trolls can look down into the pens. One end of the pen could be a portcullis that lifts, therefore a dark-brown troll structure (as seen in the cranes of Trolls' Markeplace or Trolls' Graving Dockto lift the portcullis. However having 2 pens side by side would limit the articulation of the wall (ie. no hinges) if it was to be part of the wall. Props of straw bales; should they be yellow or tan? Finally I would have to check parts availability. I probably have enough Ostrich Races to form enough fences, it would be the rocks and upper platforms that are the issue. I tinker with the Cattle Poaching sets in LDD. As first attempts they're reasonable but they're certainly not the finished product. Thinking more about the Cattle Poaching. Architectural consistency would have Trolls using Dark Blue Spindle Fences rather than the current cone and bar design, theoretically the brick count will be less as well, 4 fences rather than the current 9 cones, bars and rounds. How to create the center fence? Offset or on the mid-line using jumper plates. If the fence is mid-line how to get back on system for the top platform? This might also solve the issues with LDD not liking the cone and bar construction technique where it connects with the plate forming the observation platform. Stairs up the middle seemed to work in the first attempt. Can the wall be rearranged so that the French tower forms one edge of the guides for the near fence? A wait at Warsaw airport allowed me to consider a second version of Cattle Poaching. I'm happier with the design but there are still some issues notably that there's not enough colour variation to separate the fences from the rocks; everything is Blue Grey. I'm not entirely convinced about the rock pillars themselves they almost need to stick out of the base-plating more and my repeated use of 1x2x3 slopes makes them same-y. A month passes, I still intend to return to the last few smaller sets such as the Cattle Poaching and build them up. With respect to the cattle poaching there's probably more to do on the desing; recently I was looking at the Power Miners sets and the 8191 Lavatraz one caught my eye as a possible inspiration for Cattle Poaching. To form the walls Lavatraz uses the large Bar 11 x 13 Grille that have previously been used as portcullis'; the technique confers a substantial brick saving from doing it through 2x4 spindle grilles. Another other option that occurred to me would be to use the 1xX plates design of the Troll Gates from 7097 Trolls' Mountain Fortress. One other consideration would be to turn the set around so that the cells open away from the wall rather than parallel to it. Started playing with both turning the set sideways and using the large grille pieces but it' wasn't quite coming together. My conclusion was that I definitely need to investigate how Lavatraz secures the grilles. I had slightly more success with the use of plate built fences, although I need to think through how the are going to be secured into the rockwork as currently they're just held in place by two headlamp bricks. LavaTraz didn't help; all the pieces are secured using bottom clips. So I rebuilt the design using plate fences and finally I had a design that I was happy with at 300 bricks, although that feels slightly over budget for what the set is aimed at. I might have to see if there's a way to revise the rock formations to reduce the brick count. I'm finally at the stage where the LDD designs are firm enough that I can start placing Bricklink orders for the parts that are missing; primarily I needed to order a couple of 2x16 Plates in Dark Bley. Even though I've got bricks on order I keep toying with the idea of turning Cattle Poaching into an interior angle rather than a linear stretch of wall. I continue the strand of thought over the next few weeks. The rationale behind this is: when all of the sets built into the wall you end up with a city that has a larger and larger circle of wall and a big empty hole in the center, having a piece with an interior angle allows the building of kidney shaped cities which is turn means less of an empty hole. The next batch of parts to make up Cattle Poaching has arrived, although I'm still tinkering with the design. However build up the model doesn't run smoothly. Halfway through the build I realise that the pillars forming the runners for the lifting gates are too flimsy. A hasty redesign adds a layer of plates midway in order to lock the pillars together and give them stability. Then I realise that my design calls for 3x6 wedge plates in Reddish-Brown, a part which has never been produced so it's back to the drawing board. A tube journey into town meant that I was able to rebuild the set in LDD to utilise 8x3 wedge plates and I need 3 each of both the left- and right-hand variants. Downside is that these parts only exist in 2 sets, the recently released 75059 Sandcrawler and an old Ninjago set 9446 Destiny's Bounty. There are two Bricklink sellers in the UK that have a stock of these typically 2 of each where they've broken a set down. One (Otter bricks) has some of the dinosaur bits that I've been eying up as a means of transport for the Trolls, so I might have to place an order. As part of building up another set, The Dragon Carrier, I've been placing more Bricklink orders and manage to get the relevant parts to complete the build of Cattle Poaching. The build however is still putting up a fight, various colour changes and a redesign of the plating because I can only source 2 each of the 3x8 wedge plates have to be reflected back into the LDD models so that they represent what's actually been built. There are some minor colour substitutions in terms of 1x2 plates which should all be Dark Green, but most people would struggle to spot the changes, the only reason they should be Dark Green is to minimise the number of unique elements in the set. This quest for minimal unique elements also resulted in all of the 1x8 plates in the set being changed to Dark Brown with the exception of one 1x8 plate in black across the front and all the 1x10 plates being standardised on Reddish-Brown with the exception of one 1x10 plate in black across the front. The finished build; suprisingly small for 6months of at times quite painful gestation. Final piece count 310 including Minifigures, cattle and weapons; which isn't bad for it's size. It's got height, especially when the Troll is holds the flag on the tower top. The pens are accessible, just. I can get my hand in to move the cattle in and out but it's too tight for me to sit down and actually play out a "scene" within the pens. The gates work well although they can sometimes stick a little. High angle and overhead looking down into the pens. Seen set into the wall of alongside Troll Training and Trolls' Blacksmith. Consistency looks good. I do realise that I've forgotten to photograph the dog which should go with The Villagers to make them look more menacing. In the end what I most like about the set is the ambiguity. It's obvious that there is conflict, one side against the other but have The Trolls been poaching cattle from The Villagers or are The Villagers poaching cattle from The Trolls. It can be played either way. As always; LDD files can be found here on MOCPages equivalent of this post. Edited July 8, 2020 by The_Cook Quote
The_Cook Posted August 7, 2014 Author Posted August 7, 2014 (edited) The idea for the Dragon Carrier came from looking at my Troll Town and realising that the defining features are the Troll Navy and the Flight of Dragons. How to combine the two? Inspiration also comes from the novels of Naomi Novik which exist in a parallel universe where the Napoleonic armies are fighting with Dragons as well as the usual wooden warships of the era; one of those ships is Dragon Carrier, a giant ship with platforms from which Dragons can launch at either end and the usual square rigged sails inbetween. How can I recreate those concepts in a Troll style. The obvious Troll ship characterisics are a dark brown hull, the junk-style rigging with it's red sails, outriggers and the sterncastle structure. Extending a standard Troll ship by an extra hull segment was fairly easy, I then considered a different bow structure rather than the rising Viking hull a flatter set of stacked bow pieces, however this wasn't really working in terms of supporting a dragon platform. In terms of the platform itself my initial sketches had a platform surrounded by nets. How to support the nets? It took a bit of effort to arrange a suitable support structure but I'm reasonably pleased with the results in LDD. The sides also posed problems as there are only a limited number of Dark Brown 1xX bricks and I'm already having to source these from all across Europe to get them in the quantities that Troll Town is consuming. To my surprise it was reasonably easy to source the dark brown hull segments and some Troll sails at a reasonable price, reasonable enough to buy spares just-in-case. The hardest part actually turned out to be the turntables at the bottom of the mast, these only ever appeared in 7048 Troll Warship and some Star Wars sets of the same era. Bricks sourced and on to the build; nothing fancy no more complex than 7048. The dragon platforms are a little fiddly and with hindsight there should probably be some ties between the sections prior to the octagonal platform going on just to make connecting the platform easier. As well as building up the Dragon Carrier I've been extending Trolls' Landing by adding a few more quay sections, there are some new designs as well as the existing designs. The big issue now is that my photo stage (2 pieces of A1 foam-card) is now too small to capture the whole navy as these photos don't include the graving dock. Quite how I'm going to photograph the whole of Troll town is now a serious question, I might just have to lie the card and models on the floor. It will easily fill an 8'x4' space. As always; LDD files can be found here on the MOCPages equivalent of this post. Edited July 13, 2020 by The_Cook Re-upload images Quote
The_Cook Posted March 16, 2015 Author Posted March 16, 2015 (edited) A weary traveller approaches the Great Gates of Troll Town with news from the south. He brings news of the Crown King massing troops in preparation for invasion. Nobles with their bodyguards hurry to meet the king... as watchmen are stationed in the towers; crossbows at the ready. To bolster the numbers new recruits are trained and drilled; Whilst Ogres assemble the battle wheels ready for action Veterans patrol beyond the walls, checking the caves and crevices for malicious agents of the crown. Maps are studied and dragons fed; ready to take to the skies. Pilots take the reins; the Crown King's dragons will be met tooth and claw. The fleet lies at anchor as supplies are loaded. The market is bustling, a last chance to purchase the essentials before battle. Steel and spells will win the day. Champions fight to pass the time whilst the common soldiery looks on; meat and ale in hand. The ogres form ranks; taking their orders as a fighting force. Ready to defend their home against the antagonistic Crown. An overview. Even the plan view doesn't quite capture the expanse; the town covers an area roughly 2m x 1.2m. When I first plotted this out I was concerned that the middle would be empty; in the end there wasn't enough space for the Troll Battle wheels. The sketch plan for Troll Town. This has been well over 12months in the planning; although I have a day-job and a life to lead so progress on it hasn't been particularly fast. I happened to have a free weekend when the missus wouldn't be around to complain that little green men have taken over the house. I start assembling Troll Town; however the problem with Troll Town is that it has grown larger than my dining room table; and it's the largest table in the house. This shot doesn't show the Troll Navy nor the Battle Wheels... Quite simply it's not going to fit. I could haul an 8x4' sheet of plywood out of the garage, lay it across the table and work on that but I opt to assemble things on the floor instead. I'm going old-school, no photoshop, it's going to be done with coloured paper as backgrounds. I've already source card that is as close as I can get to Dark Green, Red-Brown and Bright Blue. The first few sections go into place. The disadvantage with working on the floor is that it's carpet underneath and therefore springy. I can't lean on the card as it will crease. I have to assemble the rear before the front. The majority of the strucutre of Troll Town is now in place although there are two gaps in the wall either side of the Dragon Platforms that need filling in. I have an unbuilt 7097 in reserve which just needs assembling to fill the gap. After 3hrs of effort I still have about 30 Trolls waiting to populate the town and that doesn't include another 20+ that I find in the box with the spare 7097... Placing minifigs on cardboard is slow and tedious, much like standing domino's with a similar propensity for falling over and taking an entire row with it. Overview. To be honest, I need to obtain more card. I have one sheet of green spare but need more green and more blue. I could also do with a bigger room. More time might help as well, this has to be disassembled and stowed by 21:00 when the missus returns! The blue sky card shows the gaps, I might try to source a roll of thick sugar paper that can be used in one continuous length. Somewhere in there are 140 trolls, 14 ogres, a couple of stray prisoners and the odd skeleton. Due to space limitations it's missing a warship, 3 battle wheels and an assault wagon along with anothe 20 or so trolls to man them... ...maybe next time, when I have more card and more room. On the drawing board is a mine to add to the walls and a giant crane for assembling battle wheels to stand in the middle. I also have a couple of spare 7097 pieces to add to the wall to make the town even bigger. Edited July 13, 2020 by The_Cook Quote
