Here are few sneak peeks at my new model:
4x4x4
1:5,4 gear ratio
Weight: 1900 grams
Lenght: 35 cm
Width: 22 cm
Height: 17 cm
Max theoretical torque at wheels: 890 N/cm (OMG/WTF)
Max speed: 0,7 km/h
  • Replies 50
This comes after your Titan so what comes next? A trial truck with 10 Xls or something like that? :P Its great!!! But I don't want to be the axle between the final gear and the wheel... :D
Sweet! I love the sleek low look. Awesome man!
Can't wait to see this thing in action! :thumbup: :thumbup: :thumbup::grin:
Sometimes you can just use the battery boxes as part of the design, and it just works. :sweet:
Wow! Looks very cool. Moreover, using such rare combination of colors also impressed me)
Wonderful MOC. However, isn't it too heavy for its size?
Thanks guys!
I broke many gears trying to channel the power of 4 XL motors, but the end result sure is powerfull. I will get some more of the new reinforced 8 tooth gears for the hubs, but so far only one 8tooth rear gear got chewed and sometimes a rear U joint will pop out if the wheel is blocked. Other than that is works pretty damn well :) Speed is simillar to 9398/41999, but the steering is better even without diffs. Also its very low and stable.
Edited by Zblj
> Zblj
Awesome looks!
I know the wheels have totally incompatible axle comparing with Technix axle. So I wonder if you could post an image how you attached those wheels to normal axles.
That looks very sci fi. Did you consider only using two motors as a default then activating the other two motors if extra power was required.
I look forward to the video.
H
Edited by Horace T
> Zblj
Awesome looks!
Yes I to would like to know how to connect them, and also their weight, as I would love to use bigger wheels but them power puller ones are just toooo heavy.
Thanks.
...and also their weight, as I would love to use bigger wheels but them power puller ones are just toooo heavy.
Thanks.
According to BL the weights are:
Technic Power Puller - 181.55 g
Lime RC one - 108 g
Ok, now I know how that wheel is connected - look closer to the wheel center and you can see 24 teeth gear is used. 4 pcs. of 3L pins used inside can secure the wheel pretty good. And if you use 2pcs 24teeth gears with only 2 3L pins inside and attaching them from different sides as a result it gives rigid connection once you mount the wheel on an axle!
Woohoo, I got new weels to use! And the best thing about it - rim has an offset. Rim's offset isn't that great, after all.
Edited by zux
Guys guys :D
Here are the pics of the hubs and the way wheels are attached :
The 24 tooth gears and 3L pins provide the interface. But remember the 8L axle withs top may be pernamenlty bent cause of the sheer power
Hubs are extremly strong:
Also steering point is fairly close to the wheels:
Edited by Zblj
