Posted November 11, 201311 yr Can anyone suggest a good way to connect a streetlamp to the following SNOT road model? Thanks!! Mike [edit] Oops, typo in thread title! Edited November 11, 201311 yr by Dilvish
November 11, 201311 yr Author Where do you plan on putting the streetlamp? I'm planning on placing them all along each sidewalk. Replace one of the 2X2's with a bracket 1X2 - 2X2 and two 1X2 plates The model doesn't use any 2x2 bricks. Could you post pics of the ones you mean? Edited November 11, 201311 yr by Dilvish
November 11, 201311 yr Replace a 1x2 brick with a 1x2 brick with studs on 1 side and a 1x2 plate, or a 1x1 plate and 1x1 tile for the latter plate.
November 11, 201311 yr But if you do that, the lamp post would be crooked as it'd be perpendicular to the spot on the curved section. LEGO has released only 1 piece with fixed angled stud and it's a huge piece, like it's intended for roof support. Maybe replace one of the 1x2 brick with a technic that has a + hole, a 2L technic axle, and 1 angled connector?
November 11, 201311 yr It would be nice if you can upload the file so we can play around with it. Creating a solution off the top of our heads isn't the best way to do things sometimes. This looks like a pretty difficult setup. I'm actually amazed that LDD lets you make such a curve...
November 11, 201311 yr It would have to be something with a hinge tile with two fingers on top, in combination with a hinge cylinder with one finger. Hinge the cylinder to make it vertical, and then, somehow, connect the street lamp on top of the cylinder. Depends on the type of street lamp you're using. I used it in combination with 42445 (Bar 1x12), and it worked a treat. You can give the bar any angle you want. Well, almost... there's a click system between the tile and the cylinder that limits the number of positions you can fix the bar in. Edited November 11, 201311 yr by Withacee
November 11, 201311 yr I'm planning on placing them all along each sidewalk. The model doesn't use any 2x2 bricks. Could you post pics of the ones you mean? I meant 2X1's! It can get confusing with all those technical LEGO words, lol.
November 11, 201311 yr Author Here is the street lamp I had intended on using, though I see now that I will probably have to switch to something different. http://www.peeron.com/inv/parts/2039 I can't attach ldraw models to my post for some reason. So I uploaded the curving road model here: http://www.mediafire...unec00abww40144 Edited November 12, 201311 yr by Dilvish
November 11, 201311 yr You can use that lamp, but you can't maintain that "vertical", they will follow the curvature of the street. About attaching images and lxf files, you can open a free brickshelf account and direct link the files.
November 12, 201311 yr Nice road design! I have test this one with real brick. The angle is adjustable. LEGO Streetlamp suggest for SNOT road model _ by Dilvish by Nachapon S., on Flickr 3 minutes quick render: LEGO Streetlamp suggest for SNOT road model __ by Dilvish by Nachapon S., on Flickr edit: Use different slope brick for different angle. LEGO Streetlamp suggest for SNOT road model __ by Dilvish by Nachapon S., on Flickr Edited November 13, 201311 yr by bbqqq
November 13, 201311 yr Very nice! Thanks for the suggestion! You are welcome. I added more suggestions on the post #14 above. Edited November 13, 201311 yr by bbqqq
