VKTechnic Posted December 2, 2013 Posted December 2, 2013 For my next project, I'm revamping the 8297. My plans are to give it 4-link suspension, add 4WD with remote control, and "adjust" the bodywork. Oh, and I'm adding these tires to it: First step is new axles, so stay tuned for that. Quote
Junpei Posted December 2, 2013 Posted December 2, 2013 Those tyres are sweet! How much bigger are they than the 94.4 x 44R ones? They make that vehicle look monstrous. Quote
Lakop Posted December 2, 2013 Posted December 2, 2013 Should have good ground clearance with those tyres. H Quote
VKTechnic Posted December 2, 2013 Author Posted December 2, 2013 Those tyres are sweet! How much bigger are they than the 94.4 x 44R ones? They make that vehicle look monstrous. They're about 1.5cm bigger in diameter. Quote
JM1971 Posted December 2, 2013 Posted December 2, 2013 So many good parts on this moc, looking forward to a vid. Quote
VKTechnic Posted December 2, 2013 Author Posted December 2, 2013 So many good parts on this moc, looking forward to a vid. MOC? This is just 8297 with new tires (at least for now). Quote
JM1971 Posted December 2, 2013 Posted December 2, 2013 MOC? This is just 8297 with new tires (at least for now). I see power connectors too, just one change makes it a moc? (at least thats what I thought) Quote
VKTechnic Posted December 2, 2013 Author Posted December 2, 2013 I see power connectors too, just one change makes it a moc? (at least thats what I thought) Nope, tires are the only thing changed. But, as I said in the original post, there are a lot of changes coming to this offroader. Quote
JM1971 Posted December 2, 2013 Posted December 2, 2013 Nope, tires are the only thing changed. But, as I said in the original post, there are a lot of changes coming to this offroader. I never realized the original set had connectors sticking up out the roof, that's a bit sloppy from lego, I thought you had placed the battery box there temporary, hence moc. Quote
Paul B Technic Posted December 2, 2013 Posted December 2, 2013 I look forward to seeing the end result :) Quote
VKTechnic Posted December 12, 2013 Author Posted December 12, 2013 Finally put together a chassis using Unimog wheels (to keep the dimensions accurate). Also, the chassis is currently on a stand, which will be removed once I get the shocks mounted. Quote
piterx Posted December 12, 2013 Posted December 12, 2013 nice idea! i got that set...if you can make it better i may consider to give it a go :D Quote
Erik Leppen Posted December 12, 2013 Posted December 12, 2013 I'd say connect the top 13L beams that connect to the 9L links, by 15L so that you can connect them to the 5x9 beams for added rigidity. For the rest, looks cool :) Quote
Junpei Posted December 12, 2013 Posted December 12, 2013 Looks awesome! I love how you always use a caster angle on your live axles. Quote
VKTechnic Posted December 13, 2013 Author Posted December 13, 2013 I'd say connect the top 13L beams that connect to the 9L links, by 15L so that you can connect them to the 5x9 beams for added rigidity. For the rest, looks cool :) If I did that, it would interfere with the travel of the 9L links. Quote
VKTechnic Posted December 19, 2013 Author Posted December 19, 2013 Progress...It's there, but it's slow. Still have 2 motors to mount: Winch and steering. After that, it's all bodywork. Quote
Thirdwigg Posted December 19, 2013 Posted December 19, 2013 Such a cool MOD, and the live axles are a great addition. Those tires for perfect for 8297. Quote
Paul B Technic Posted December 20, 2013 Posted December 20, 2013 Thanks for the update on this, it is looking good :) Quote
VKTechnic Posted December 20, 2013 Author Posted December 20, 2013 What tires are those exactly? (link?) These. Quote
Gee Posted December 20, 2013 Posted December 20, 2013 Nice! I really like the positive caster angle. You see lots of 4x4s and crawlers with negative caster and also a few sets as well (8110 and 9398). Do you think that the positive caster will be an improvement over negative in terms of performance? Quote
Junpei Posted December 20, 2013 Posted December 20, 2013 It will definitely be an improvement. Here's something that demonstrates this perfectly: This project is coming along very nicely! Quote
Gee Posted December 20, 2013 Posted December 20, 2013 Aye, I've seen that video, explains it perfectly. I just wondered about caster angle specifically for crawlers. Quote
olaf9198 Posted December 20, 2013 Posted December 20, 2013 Overall it improves stability and steering, the steering needs less force for a positive camber then a negative caster. Quote
