This is my Revamp of Jet Rocka. I've built the actual moc in LDD. I also made a half built version in real life as well. The real life version is just to show the new functions that the LDD one can't show.
.LXF file
http://www.brickshel...ocka_revamp.lxf
Gallery when public
http://www.brickshel...ry.cgi?f=537362
Changes from original set
1. Swapped trans green windscreen for larger trans clear windscreen. (Windscreen won't attach in LDD but I will in real life)
2. Modified wing unfolding gimmick. It also makes the jet engines move.
3. Changed handle to add stand so Jetpack can stand on its own when Rocka isn't attached. Stand folds up and extends handle to be held better.
4. Changed Rocka to be built the same as his bag set. Only things changed are removal of silver and both shoulders have armor
5. Zamor blasters can be moved up and down (Similar to LEGOJANG's JET NEX)
6. Red short beam handle replaced with longer blue one
Real Life pics (Not actual revamp. Just to show functions)
Front- Cockpit open
http://www.brickshel...t_rocka_001.jpg
Front- Cockpit closed
http://www.brickshel...t_rocka_002.jpg
Front- Wings extended (Wings can't be locked open. I just put a pin in a beam to hold it open for pics)
http://www.brickshel...t_rocka_003.jpg
Side- Wings folded
http://www.brickshel...t_rocka_004.jpg
Side- Wings extended
http://www.brickshel...t_rocka_005.jpg
Back- Wings folded
http://www.brickshel...t_rocka_006.jpg
Back- Wings extended
http://www.brickshel...t_rocka_007.jpg
Zamor cannon position 1
http://www.brickshel...t_rocka_008.jpg
Zamor cannon position 2
http://www.brickshel...t_rocka_009.jpg
LDD Pics (Actual Revamp)
Front
http://www.brickshel...t_rocka_010.png
http://www.brickshel...t_rocka_011.png
Landing gear folded up when in flight mode
http://www.brickshel...t_rocka_012.png
Comments and criticism appreciated
Edited by Takanuinuva
The colors on the real version are a bit all over the place but I guess you were working with some part constraints there. The LDD version looks a lot better sine you had unlimited quantities of parts in the colors you wanted. Overall, I quite like many of your improvements, such as the reduced height of Rocka (now pretty much any hero can use the jetpack regardless of height) and the larger windscreen.
Minor LDD color nitpicking:
  • You used 48 Tr. Green where you should be using 311 Tr. Bright Green.
  • You used 208 Light Stone Grey (Bricklink's Very Light Bluish Gray, the color of Thok and the Mindstorms NXT sets) where you should be using 199 Medium Stone Grey (Bricklink's Light Bluish Gray).
  • You used 283 Light Nougat (Bricklink's Light Flesh) where you should be using 5 Brick Yellow (Bricklink's Tan).
  • 47 Tr. Fluorescent Reddish Orange is not a color those flames come in but it's an acceptable placeholder since they can't be correctly dual-colored anyway (the flames you were thinking of are a blend of 41 Tr. Red and 44 Tr. Yellow).
Thanks and as for the color errors. Those are the colors I like to use since to me they matched there real life counterparts. Besides people should know what actual parts to use if they decide to build it in real life. A real life version can be made. I just didn't want to order parts to make a proper real life version since I had no intention of getting the actual Jet Rocka set. Though I've changed the .LXF file so the proper colors you mentioned are used.
