Okay, so this has happened with past versions and now the current version. I'm on Windows 8 (Not 8.1), and when I launch from my start menu, LDD will come up in compatibility mode. But when I launch from my desktop, it launches just fine. It's not a major thing, but sometimes its easier to just go to my start menu and launch it from there, as opposed to collapsing my windows and finding it on my desktop.
I haven't really seen much on this issue, but it would be nice if someone has some tips to fix it.
I dealt with that issue too. I found that if I remove the Safe Mode version in the start menu and replace it with the Desktop one, everything worked.
Could you post the destination of the shortcut that you use in the Windows 8 Start Screen?
It seems that LDD is not able to place the right shortcut in the Start Menu.
Maybe you can solve the problem simply editing the shortcut.
Edited by Calabar
I have no idea how to edit start menu shortcuts, I'm not used to Windows 8 yet. I know it's linked the same as the desktop shortcut since it was put in the start menu by the install wizard.
You can find the folder containing the shortcuts related to the tiles in the Start Screen in
For all users
%ALLUSERSPROFILE%\Microsoft\Windows\Start Menu\Programs\
For your user
%APPDATA%\Roaming\Microsoft\Windows\Start Menu\Programs\
