Exetrius Posted January 21, 2018 Posted January 21, 2018 @Leewan As if you can read my mind; that's exactly what I need it for Thanks! Quote
Calabar Posted January 21, 2018 Posted January 21, 2018 Please note that this topic is for LDD assembly only, not mecabricks. LDD has some flexible elements, not many to say the true, did you check if there is something usable? The main problem should be that the torso with arms is a single part in LDD, and that makes to create this assembly more complicated, if possible. Quote
Exetrius Posted January 21, 2018 Posted January 21, 2018 28 minutes ago, Calabar said: Please note that this topic is for LDD assembly only, not mecabricks. LDD has some flexible elements, not many to say the true, did you check if there is something usable? The main problem should be that the torso with arms is a single part in LDD, and that makes to create this assembly more complicated, if possible. No problem with finding a flex tube, but if there is indeed no way of separating arms and hands from the torso, then it's useless in LDD. I know where to continue, thanks! Quote
Calabar Posted January 21, 2018 Posted January 21, 2018 To say the true, there is a way. Take a look at the Section Index (one of the two pinned topics in this section), probably the case is linked in the last post. Quote
Takanuinuva Posted July 20, 2018 Posted July 20, 2018 Can someone help me in getting a minifigure to hold the handlebar piece in both hands? https://www.bricklink.com/v2/catalog/catalogitem.page?P=30031&idColor=95#T=C&C=95 Quote
