DrJB Posted March 7, 2014 Posted March 7, 2014 (edited) when it is this part why design one ? i dont think a printed part will be cheaper. or should it deliver a different functionality? The original part came only in two sets: Dozer 8275 and Crane Truck 8421 ... Since both are no longer available and quite expensive ... people have been building them with spare parts from bricklink .... all other parts are rather common/cheap except such bracket. Incidentally, yellow wheel sprockets are also rare but one can use orange/black. Edited March 7, 2014 by DrJB Quote
efferman Posted March 7, 2014 Author Posted March 7, 2014 ok, then i will do one, but with an additional functionality Quote
D3K Posted March 7, 2014 Posted March 7, 2014 Yes, I meant the above mentioned part, used in 8421 and 8275. Ridiculously expensive on bricklink. Curious to see what you come up with On a different note, what are the main differences on your design of LA holder, compared to the normal one? I mean, I see they are different, but what are the new part's advantages? Quote
efferman Posted March 7, 2014 Author Posted March 7, 2014 here is my version of this part cylinder bracket von efferman auf Flickr Quote
Pat-Ard Posted March 7, 2014 Posted March 7, 2014 Hi efferman, that looks promising... Do you have a picture from an other angel? Thanks. Pat Quote
efferman Posted March 7, 2014 Author Posted March 7, 2014 sure cylinder bracket 2 von efferman auf Flickr Quote
Pat-Ard Posted March 7, 2014 Posted March 7, 2014 That's really interesting... Real good work!!! Quote
efferman Posted March 7, 2014 Author Posted March 7, 2014 (edited) in this combination it would cost 10,69€ does anybody know if two parts became one part when they are placed like this? source or is it better to make two of these, but these would cost 11,98€ source Edited March 7, 2014 by efferman Quote
lilongwe Posted March 7, 2014 Posted March 7, 2014 on one hand that is a good idea to make custom parts. On the other hand that is no Lego solution. In my opinion then you could also build like in normal modelbuilding. Quote
efferman Posted March 7, 2014 Author Posted March 7, 2014 yes, for purists this thread is senseless. and some things are possible with standard lego, but other things not. and there are custom parts make sense Quote
SNIPE Posted March 7, 2014 Posted March 7, 2014 (edited) How about a beam, its like a stud less beam but one has studs and clutches offset to the holes. but it will be very useful because they can be stacked with no external connections, I'm not sure if offset clutch holes are possible (those would be directly inline with the holes) Edited March 7, 2014 by SNIPE Quote
efferman Posted March 7, 2014 Author Posted March 7, 2014 can you please make a sketch? it seems iam lost in translation Quote
DrJB Posted March 7, 2014 Posted March 7, 2014 (edited) in this combination it would cost 10,69€ does anybody know if two parts became one part when they are placed like this? While I see (and agree with) the merits of the improvements you've made, I think MORE people would be more inclined to purchase a design that is very close to the original lego part ... The 'pull' that such parts exerts (imho) is not as much the need to connect two cylinders and increase stroke ... it's more like to get parts and be able to build an 8275. Lastly, I am not sure what Lego's position is regarding replicating parts that are not 'officially' terminated yet. One way around would be a design with a 'small' improvement ... aka ... the 'China' way. Edited March 7, 2014 by DrJB Quote
efferman Posted March 7, 2014 Author Posted March 7, 2014 A part, reduced to the minimum should be not a problem. And cheaper too. Quote
jorgeopesi Posted March 7, 2014 Posted March 7, 2014 Purists have to know these pieces, to know where they are used if they are not visible and not go crazy with a MOC that does things we can´t do. I see this a lot in the machinery forums and they build impressive metal and plastic things. Quote
unimog123 Posted March 7, 2014 Posted March 7, 2014 I have a question about these custom parts....if you can pretty much create parts to fit the pin holes and axle holes on lego creations, would it be possible to make bodywork for a lego chassis? I don't know if the software is complex enough, but I think some people would be interested in buying bodywork for certain kinds of vehicles. Of course it would be pretty expensive, though. Quote
D3K Posted March 7, 2014 Posted March 7, 2014 The 'pull' that such parts exerts (imho) is not as much the need to connect two cylinders and increase stroke ... For me, at least, connecting two cylinders end to end is the only reason for me wanting this part. There is no way to do this compactly without those brackets, and lacking longer stroke cylinders, this really is a must for certain medium to large size pneumatic MOCs. Quote
efferman Posted March 7, 2014 Author Posted March 7, 2014 Could you define bodywork more specific? Mudguards, bumpers, wings or full bodys? Quote
MrNumbskull13 Posted March 7, 2014 Posted March 7, 2014 I have a question about these custom parts....if you can pretty much create parts to fit the pin holes and axle holes on lego creations, would it be possible to make bodywork for a lego chassis? I don't know if the software is complex enough, but I think some people would be interested in buying bodywork for certain kinds of vehicles. Of course it would be pretty expensive, though. I think 3D printing would be a bit britle for something like that. Vacuum moulding would be more sensible... Quote
timslegos Posted March 7, 2014 Posted March 7, 2014 I might be the only one, but i think the current cylinder holding design is too bulky. I think it would be a lot more useful if the beams did not extend past the end of the circle. Looks spectacular otherwise! tim Quote
SNIPE Posted March 7, 2014 Posted March 7, 2014 (edited) Here is a rough drawing with the holes, studs and clutches at the right scale to each other, the lines don't take up any space since the gap between lego bricks is so small. holes and studs are the same space as each other but half space round the edge of the liftarm. Red is the studs and the bottom gaps guide where the clutches would roughly be, round recesses for the stud clutches would be best as it takes up the least area which makes it stronger. the bottom picture of the lift arm is more like a real side view since the clutches are centered Note tht this is a 6 L but is not a thin liftarm, I say 8L would be more useful though This enables you to stack liftarms without using the holes with more connections but still allows for each stud hole to be 0L apart instead of 1 plate apart like on the old technic beams Edited March 7, 2014 by SNIPE Quote
unimog123 Posted March 7, 2014 Posted March 7, 2014 Could you define bodywork more specific? Mudguards, bumpers, wings or full bodys? Well I guess full bodies would be a bit unreasonable, so I guess spoilers, splitters, mudguards, bumpers, and especially rollcages would be great. Quote
DrJB Posted March 7, 2014 Posted March 7, 2014 If I may oversimplify this ... you're essentially asking for the old technic beams, but with 'rounded' ends, and possibly a smaller height ... correct? Quote
