I don't think what you're asking for is quite possible....
Anyway, I'm really liking some of the stuff posted on this thread.
I'd personally like to see:
some new wheels with positive offset for the Unimog tires
New clutch gears, compatible with the standard changeover clutches
and an end to end bracket for linear actuators, allowing them to be ganged easier.
  • Replies 1.9k
If I may oversimplify this ... you're essentially asking for the old technic beams, but with 'rounded' ends, and possibly a smaller height ... correct?
Correct, studless beam but with studs and clutch holes, the clutch doesnt effect the thickness
There would be a half clutch on each end so you can attach them ontop of a longer if not the extra on the longer beam wont have anywhere to interlock so neither will the rest of the studs.
Edited by SNIPE
upload your part to shapeways? and in which lengths?
to the rims
looks this superleggera better and do you think the superleggeras are stable enough ?
if you meant me then I recon 4L, 6L, because 8, 10, and 12L can be made with these combinations, lego should make even number of holes/lengh
Edited by SNIPE
are you watching TLG?
sorry, iam again lost in translation
edit: iam a afol, so i watching the lego group for 30 years. or wanbt you say something else?
Edited by efferman
Maybe you could make a version of this part:http://www.bricklink.com/catalogItem.asp?P=53178 for the small pneumatic cylinders. I only own one small pneumatic cyilinder, but it might be useful for other people.
Yes, that also works efferman
Is it possible to have the tiny holes in the clutches filled in, also How about offset clutches (these will be directly under the holes and may need to overlap with the holes but not in a way that putting a stud in the clutch would block the hole, there should just be enough room.
Edited by SNIPE
drJB, these parts are already existing?
No, those parts do not exist. I was simply referring to another lego brand (not in production anymore). In the past, lego made bricks that have the same height as width (these are called ModuleX). Though, lego never made Technic version of the ModuleX, as the latter was primarily destined for architecture studios. These new parts you've made, they kind of fill such gap.
snipe, 3, 4, 5 and 6 are online
snipego concept von efferman auf Flickr
Not sure how much of a difference this will make on the cost, but one can reduce the amount of plastic used by making small voids between the pin holes, as in the lego liftarms. The parts will not look very 'smooth' from the side, but I am sure Lego did that for reducing the cost/amount of plastic as well.
it would be a few cents cheaper, but the studholes at the bottom sides need the material around them. too less material thickness is not good to print
