efferman Posted March 10, 2014 Author Posted March 10, 2014 Thank you very much, yours looking good too Quote
Leewan Posted March 10, 2014 Posted March 10, 2014 Oh, thanks, I tried to stick as much as I could to the official designs. And the 3x11x2 curved panel is a very complex part, so that wasn't easy to get all the little details. But... yeah, I'm glad with how it turned out, and even if they are a bit dark, I must say I'm quite proud of my renders, I think they make the part look better than it would actually be. Quote
Dafgek81 Posted March 10, 2014 Posted March 10, 2014 Hello Efferman, If the rims are for the 8110 tyres, the are to big. 9398 Is the Rock Crawler if I am not mistaken, so those tyres are bigger than the 8285 towtruck. Hello Efferman, If the rims are for the 8110 tyres, the are to big. 9398 Is the Rock Crawler if I am not mistaken, so those tyres are bigger than the 8285 towtruck. Quote
efferman Posted March 10, 2014 Author Posted March 10, 2014 The rims of post 297 http://www.eurobricks.com/forum/index.php?showtopic=91294&st=275#entry1843701 are for the 62x 20 tires Quote
efferman Posted March 11, 2014 Author Posted March 11, 2014 (edited) and for the same tires i have made a mudguard piece. actually 4 studs wide. 8 of them would give a full circle with an outer diameter of 13 studs, but the most use would be this more mounting points? wider or more narrow? Edited March 11, 2014 by efferman Quote
Pat-Ard Posted March 11, 2014 Posted March 11, 2014 Hi efferman, the mudguards look good. I would suggest mounting points on one side... Pat Quote
D3K Posted March 11, 2014 Posted March 11, 2014 mudguard looks great, don't ruin it by adding more holes to it! Quote
Cumulonimbus Posted March 11, 2014 Posted March 11, 2014 Yes sir, I like those very much. Maybe one side (the back in you images) could have some additional mounting points? Or don't you want to sacrifice the symmetry? Those are at the 8110 scale, right? A similar part for the 8258 scale would be brilliant as well. Quote
Dafgek81 Posted March 11, 2014 Posted March 11, 2014 Hello Efferman, I think we are talking about different rims. I am talking about the rims you posted om march 8th, the top rim, I realy digg that one, looks like an american truckrim. Quote
Johnny P Posted March 11, 2014 Posted March 11, 2014 Hey dafgek. Elke post heeft een nummer. Rechts bovenaan de post. Anders deze even vermelden voor de duidelijkheid , of gewoon de post zoeken die je bedoeld en op het knopje quote klikken. Grtz Johnny Quote
ritztoys Posted March 11, 2014 Posted March 11, 2014 Hey efferman, Those ' mud guard ' pieces look great, additional holes as everyone has suggested. Could you design Mud Guards for single wheel width and double wide wheel width? ( 62 x 20 size tires ) Quote
efferman Posted March 11, 2014 Author Posted March 11, 2014 thanks guys i have made a 3 wide version for single wheel and a tire for my 62,4x20 rims. it seems i have to reduce the diameter of the mudguard Baugruppe1 von efferman auf Flickr Quote
Dafgek81 Posted March 11, 2014 Posted March 11, 2014 truck rim for 8110 and 9398 tires enough offset? I am talking about these rims Quote
efferman Posted March 11, 2014 Author Posted March 11, 2014 (edited) these are for 8110 tires, this look is on a 62,4x20 rim only possible if there is only a crosshole in the center and no pinholes around. to the mudguards, the first version is indeed to large in diameter. best looking is the left which has 10 studs from pinhole to pinhole, the middle has 11 and the right 12 studs. but has the smallest one enough space for steering? kotflügel test von efferman auf Flickr Edited March 11, 2014 by efferman Quote
Richard L aka Scooby Posted March 11, 2014 Posted March 11, 2014 Hi Efferman, The one on the left looks very good. I think the space will be good for steering, as far as i can judge from the picture. I would love to have them. Do you gonna make them also for the Unimog wheels? Richard Quote
efferman Posted March 11, 2014 Author Posted March 11, 2014 (edited) for unimog wheels it would be really expensive. a single mudguard piece for the 62,4x20 tires costs actually 3,14€ in white strong and flexible the next part which i make is an end part for this mudguard, and then i going in medical rehabilitation for a minimum of three weeks. maybe i have internet, but no access to inventor. edit: the endpart. 3 studs wide, 2 studs long with a rounded end Edited March 11, 2014 by efferman Quote
Milan Posted March 11, 2014 Posted March 11, 2014 Hope you will be better after rehabilitation. Quote
Richard L aka Scooby Posted March 11, 2014 Posted March 11, 2014 Hi Effeman, I wish you the best during your surgery and recovery. Could you ,when you have the time and the willingness for it, make these mudgards elements for the Unimog wheels? Grusse, Richard Quote
ritztoys Posted March 11, 2014 Posted March 11, 2014 these are for 8110 tires, this look is on a 62,4x20 rim only possible if there is only a crosshole in the center and no pinholes around. to the mudguards, the first version is indeed to large in diameter. best looking is the left which has 10 studs from pinhole to pinhole, the middle has 11 and the right 12 studs. but has the smallest one enough space for steering? kotflügel test von efferman auf Flickr efferman, Those fender mud guards are looking better and better. The first one looks the best, but with some MOCs that have suspension, maybe the second one will be better for wheel clearance when turning and going over a bump. I'd have to try it out in a mock up of my typical suspension ( ie. turning and going over bump ). Do get well and relax, it'll help you heal faster, we'll all be waiting for your healthy return. Quote
2winged Posted March 12, 2014 Posted March 12, 2014 Not only are you coming up with some great parts, but you are doing it as someone self taught. Impressive. And I say that as someone who uses it 8hrs a day on average. Good luck with your heath. Quote
efferman Posted March 12, 2014 Author Posted March 12, 2014 thanks ok, this is really the last part: the fender for 8110 tires 8110 fender von efferman auf Flickr available on shapeways Quote
Richard L aka Scooby Posted March 12, 2014 Posted March 12, 2014 Hi Efferman, Thank you very much for de fenderparts for the Unimog wheels. like i said, i would wait until you were heald, but thanks any way. Grusse. Richard Quote
AndyCW Posted March 12, 2014 Posted March 12, 2014 Get well soon. This work is amazing. I may get a set of the smaller wheels v/r Andy Quote
efferman Posted March 12, 2014 Author Posted March 12, 2014 thanks guys again a fender, this time for the new 49,5x20 tires. the diameter is for steered axles. the space for steering is 9 studs, the width of the fender is 20mm hopefully this was the last part Quote
