As promised, some images of the U500 covers, painted and mounted.
A short review:
- As mentioned, the size of the axle hole needed to be increased slightly to fit on an axle. You will need a set of small hand files for this.
- The texture of the surface is grainy, typical for a 3D printed part made with this particular technique. I sanded them lightly with 400 grit sandpaper.
- I spray painted the covers, but I'm not too happy with the finish: 2 came out matte (as intended), two ended up glossy. I blame the spray paint, which was a left-over.
- They fit perfect on the 8110, I played around with the offset (as shown in the image) and settled with a 1 stud offset to get as close to the look of a real U500 as possible.
- Compared to the real deal, the covers could get some more definition: the ring could stick out a bit more, slightly curved background would be nice and a recess in the centre of the cover. Google some images, you will see what I mean. That said, my 8110 look much better with the covers (ignore the WIP tilting bed).
- The covers are 1/2 stud thick, I would prefer the mounting point to be 1 stud thick, similar to the Lego covers.
The verdict:
These covers are a really nice addition to anyone's 8110 if your not scared of a little bit of handy work. Worth buying!
Edited by Cumulonimbus
  • Replies 1.9k
Thanks for the review...
The covers look great. Hmmm, maybe I have to order them, too...
I painted my U406 covers today. I think that I'm able to post some pictures tomorrow...
Pat
thanks for the pictures, i have made black material available so that pinting is not neccesarry for black rims. the thickness of a half stud i want hold, to let the adjusting be possible, for the overall look i will look what you mean.
edit: i know what you want say
Edited by efferman
Hi Efferman, yes, that could work. I'm not really sure if all my suggestions even fit in a separate cover. The image below shows a bit what I have in mind:
The centre of the rim is deeper than the ring which protects the bolts. There seems to be some details inside this recess as well, but I can't find good images, anyone here has an U500 at home? :wink:
As said, I can image that this isn't feasible in a cover, since you need room for the axle hole. My guess is that a cover with these features could become 1 and 1/2 stud thick, three times the current version. This might reduce the flexibility you want. I could draw you a cross-section if you want.
you should keep in mind that the rim in your post is for a narrow tire, the 8110 rim is more a wide tire. whats the opinion of other people?
Hi folks and best efferman,
here you go. The painted covers for the U406.
There's nothing to add to the review of cumulonimbus. I mounted the covers with one half stud bush, so they come a little more out. Compared to the "old" version with the 6x6 dishes it looks way better.
Here are pictures:
Pat
The cutout is exaktly 4,8mm. It should fit without problems. But wait with an order, i havevan idea to make coupling easier
Edited by efferman
someone, polo-freak to be exact, has asked about a countach style wheel cover
Many Thanks efferman, Dreams come true :thumbup:
Order now, and my Technic Countach is happy :wub:
Hi stefan,
here are pictures with black rims...
But I prefer the grey ones... Or maybe I'll paint the whole rims red.
@efferman: is it possible that the parts on shapeways are also available in polished black?
Thanks
Pat
Edited by Pat-Ard
polished black is unfortunately not in the visible options. maybe when you contact them during the ordering process they can throw them into the polishing machine.
edit: i have made black detail available. the surface should more smooth, but the price is roundabout the double of the white and strong unpolished.
Edited by efferman
How could we use this new ,from efferman, rim for the 49.5x20 wheels in combine with the part of 42000 steeringhub and insert for a steering mechanism in a model like the 42024?
I could need som help with this.
Edited by scooby136
i dont have ordered this colours, so i dont know how good they match.
edit, how about a panel like the curved 3x2x11 panels but in 5x3x5 ?
What about 3x2x5 ? Those small panels will be good for small models
Edited by rm8
should be possible, but first at next weekend. i have to go on the way.
the new steering part of 42021 snowmobile has unfortunately a bad steering angle, so i have designed this
what do you think about it?
edit:
a different angle
steering hub von efferman auf Flickr
Edited by efferman
