Nijcasno, you know that the small cv joint has a half stud a full round axle so you would have a half stud offset to the original holes?
Andycw, with the small cvjoint and one towball in the lower original hole and the upper new hole, the pivot line should end under the tire.
  • Replies 1.9k
another part which is not really neccessary, but i think it makes some things more stable. what do you think is the main use of it?
Edited by efferman
yes
btw, have asked a a rapid prototype companyhow much the parts would cost in white and silver
one set in white (hub, wheelholder and rim) 82,75 € and the same in silver 97,62 €
pretty expensive i think
they have two methods for plastics. Fused Deposition Modeling (material ABS) has a layer thicknes of 0,25mm and so this is not suitable for round things. the prices are for Selective Lasersintern (sls with PA as material) the dealer has this choosed for my parts
yes
:blush: Man I got lucky big time.....
If you want to pm me the files I could get a quote from the place I am using. :thumbup:
Sorry Efferman can you save them as STL files.
Regarding prices it is the volume of materiel that is expensive.If you can break your part into one stud thick sections if possible.
Edited by Alasdair Ryan
And this would give kingpin inclination. Even better. How much kingpin is too much? And is this an example of that?
v/r
Andy
No, this wouldn't have kingpin. Not by default.
I think AndyCW is right, the design allows for a kingpin inclination. The top and bottom connection points need NOT be on the same/aligned holes. All you need for a kingpin is to connect the Upper and Lower control arms to different holes (not aligned). It is however a FIXED angle and no room for adjustment.
Edited by DrJB
Efferman there is a problem with the scaling with your file,can you answer the question below......
"I had a look at them - some of them came out very small (under 1mm) - I thnk that there is a inch/cm/mm unit issue - can you give me the XYZ dimension of this parts and I can scale the others accordingly (they will all be the same)"
