  • Replies 1.9k
Hi efferman,
a part I'd really want to see was a McPherson wheel hub.
Basically a 42000 front wheel hub, but instead of the upper pivot hole there shoud be the opportunity to attach a spring.
Something like a combination of 731c04.gifand 11949.jpg or at least an anchor point for the spring.
To get proper kingpin inclination, the spring should be set up with some angle.
If you're bored, maybe have a try. This would be a fine part.
Hi efferman,
This would be a great item to make.
The black part of the 'shock' should be joined to the hub and the yellow part should cap with an axle cross hole going vertically. Having it this way allows for custom lengths of the shock.
Or have a axle hole like the big shock on either black or yellow, basically a smaller version of the big shock. Then use a tan/blue axle pin to attach it to the hub.
interesting idea, but for which scale of car? so small as possible like this part for driven frontaxles? (it is for use with the dark gray cv joint part) ore more massive for cars like sheepos masterpieces?
Same dimension as the 42000 hub should be fine. Then it can be used with all existing six holes rims.
The dark grey part with three connectors should fit. The "tightness" of the printed part will eliminate the wobble of the original hub.
Edited by automatic71
pleas look here
the McPherson part. you need the dark grey wheelholder part of 42000 steering hub, the outside and the spring of a big shock absorber to complete it
it should work, but i give no guarantee till i have built the 3 pin part
Edited by efferman
Perfect.
Steering arm is supposed to be "self made" with the cross axle hole, right?
Thanks for your effort, very simpe design - nice.
indeed. this is better than made a left and right part.
edit:
this is how it looks with rim
mcpherson von efferman auf Flickr
Edited by efferman
