Rockbrick Posted April 30, 2014 Posted April 30, 2014 (edited) I remember having a Kyosho RC car at the same time as getting into technic and I was always amazed at how thin the differential was on that model using 4 or 3 lego 8 tooth standar gears and 2 standard 24 tooth bevelled gears a custom driving ring would then enable the whole diff to be 3 studs wide.... Edited April 30, 2014 by Rockbrick Quote
Pat-Ard Posted May 5, 2014 Posted May 5, 2014 Hi folks, today arrived some parts efferman designed... The fenders for the unimog and some new lift arms. The last I'll use on my U4000 chassis. Thanks efferman for the great job!!! The pinholes of the LAs are perfect, there's no need to widen them. The axle holes of the fenders need some "work"... Just look yourself... Pat Quote
efferman Posted May 5, 2014 Author Posted May 5, 2014 cool, can you please make a picture with unimog tire in center of the fenders? Quote
Pat-Ard Posted May 5, 2014 Posted May 5, 2014 (edited) Your wish is my command: I'll try to mount them tonight... Edited May 5, 2014 by Pat-Ard Quote
EyesOnly Posted May 6, 2014 Posted May 6, 2014 This is getting serious. At some point I will need to open a new branch in my budget... Oh i know exactly how you feel. Quote
dirty bob 456 Posted May 6, 2014 Posted May 6, 2014 Can you efferman make a file for hight clearense suspesion arms? Quote
dirty bob 456 Posted May 7, 2014 Posted May 7, 2014 (edited) like this http://www.bing.com/images/search?q=hight+clearance+arms&FORM=HDRSC2#view=detail&id=1FAA78726708DA10835378442AEEB99AAADE0706&selectedIndex=45 Edited May 7, 2014 by dirty bob 456 Quote
efferman Posted May 7, 2014 Author Posted May 7, 2014 (edited) for driven axles? which length would you prefer? for the 42000 hub? Edited May 7, 2014 by efferman Quote
dirty bob 456 Posted May 7, 2014 Posted May 7, 2014 For driven axles, ~ 7 studs, for 42000 hubs Quote
efferman Posted May 8, 2014 Author Posted May 8, 2014 (edited) is this ok for you? The picture shows the lowest position, whitch the cv joint makes possible. the suspension arm is 7 studs long and the first three holes on differential side are in a straight row . Edited May 8, 2014 by efferman Quote
efferman Posted May 9, 2014 Author Posted May 9, 2014 (edited) on my german forum someone has wanted a tilting bucket for his 8043. so i have made this. edit: and a rock bucket Edited May 9, 2014 by efferman Quote
timslegos Posted May 9, 2014 Posted May 9, 2014 Those are magnificent looking buckets, great work. tim Quote
T_Tank Posted May 10, 2014 Posted May 10, 2014 Out of curiosity looking at my rc version of zbj's mini unimog is there a way to make a compact powered steered axle? looking at the mini diff you have on shapeways looks like it work fine for the size an application on the model but wish I had some more sturdy front steering that won't slip out at the 4 piece "knuckle" ground clearance is a minor issue to would like to keep the lower half of the assembly being a half stud tall. on another note i don't' see anything in the thread dealing with the planetary transmission you got rocking on shapeways definitely curious about that! Quote
efferman Posted May 10, 2014 Author Posted May 10, 2014 (edited) good morning, for the gears i have a separate topic , but the planetary gear is not produced or ordered yet. thanks that you have ordered two of the 20z diffs. i should mine getting next week and i hope they will work. sure, more compact, based on the small diffs is possible. which trackwidth and tires? which part is the 4 piece knuckle? Edited May 10, 2014 by efferman Quote
T_Tank Posted May 10, 2014 Posted May 10, 2014 The axles are 11studs wide at where the tires mount using a actuator holder to hold a 20 to 12t then straight to a u-joint then a 2stud lift arm with a smooth hole an cross hole. hope that makes scene. the tires used are 68 7x34r. Hope that helps out some http://www.brickshel...11140627084.jpg the lxf can be found in random stuff Quote
VKTechnic Posted May 10, 2014 Posted May 10, 2014 What I'd like to see is a sped-up version of you making these parts, using a screen capture software. Quote
T_Tank Posted May 10, 2014 Posted May 10, 2014 Well the current process through shapeways you would not see to much since its sintered nylon powder but a normal 3D printed would be win! Quote
efferman Posted May 10, 2014 Author Posted May 10, 2014 Victor, some month agos i have made a small vid of the progress of a simple part. with many errors T-Tank, portal hubs if possible? Quote
T_Tank Posted May 10, 2014 Posted May 10, 2014 portal hubs would be cool though currently just like some shorter steering knuckles so you could make a 11 stud wide powered steered axle. Quote
Dafgek81 Posted May 10, 2014 Posted May 10, 2014 Hello Efferman, Nice work on the rockbucket for the 8043 excavator. Can you design a functional hightiltbucket for the 8265 or the 42030 wheelloaders? Would work best with pneumatics. Quote
efferman Posted May 10, 2014 Author Posted May 10, 2014 T-Tank is it this what you search for? dafgek i will think about it Quote
