T_Tank Posted May 10, 2014 Posted May 10, 2014 Sweet mother of holly molly that's awesome looking. Think you could do a set of none portal knuckles aswell for that? Also would that be using the cv joints or u joints? Quote
efferman Posted May 10, 2014 Author Posted May 10, 2014 actual it uses the cv joints. with U joints the width would be the same but the pivotpoint would be 1 stud next to vehicle center and then there would be less space for a low shockabsorber mounting point. or do you need the large steering angle of the u joints? a non portal wheelholder is no problem. then the axle is 11 studs between rims and not 13 like the portal. Quote
Pat-Ard Posted May 10, 2014 Posted May 10, 2014 Hi efferman, yesterday I had time to mount the fenders on my U400. Thanks again for the design! What do you think? Pat Quote
efferman Posted May 10, 2014 Author Posted May 10, 2014 Looks like the real one, so the goal is reached. Thanks for the pictures. Quote
T_Tank Posted May 10, 2014 Posted May 10, 2014 The cv joints will be fine I'll just have to order some only had u joints avail at the time. Quote
efferman Posted May 11, 2014 Author Posted May 11, 2014 (edited) ok, i have uploaded following things the straight axle the portal axle and a fitting 9L gearrack for 12 tooth double bevels more gear rack lengths wanted? Edited May 11, 2014 by efferman Quote
Technyk32231 Posted May 11, 2014 Posted May 11, 2014 I may be ordering these in the near future... Quote
T_Tank Posted May 11, 2014 Posted May 11, 2014 Are these also using the custom cv axle end or using the stock ones? Quote
efferman Posted May 11, 2014 Author Posted May 11, 2014 (edited) the standard lego CV joints were used according the high tilt bucket i have a question. One pneumatic actuator in center of the bucket or two at the end of the bucket? the casing of it will look like this Hochkippschaufel von efferman auf Flickr Edited May 11, 2014 by efferman Quote
T_Tank Posted May 11, 2014 Posted May 11, 2014 went ahead an ordered a set will be interesting to see how it comes out may need to sand an polish where moving parts meet. Quote
Dafgek81 Posted May 11, 2014 Posted May 11, 2014 the standard lego CV joints were used according the high tilt bucket i have a question. One pneumatic actuator in center of the bucket or two at the end of the bucket? the casing of it will look like this Hochkippschaufel von efferman auf Flickr The real ones used by Volvo have 2 cilinders on borh ends. Quote
efferman Posted May 12, 2014 Author Posted May 12, 2014 because there are high tilt buckets available directly from volvo which have the cylinders in center i have done the same the bucket is 175mm wide, this should be the same like 42030, but i dont know if you want pay 78 euro for a white set and 96 for a black one Quote
Dafgek81 Posted May 12, 2014 Posted May 12, 2014 (edited) Very nice work. I will have to think about that indeed, the rims you made for the wheelloader are going to cost me an additional €80-, but it would be so cool to have a hightiltbucket. Thanks anyway for the trouble. Edited May 12, 2014 by Dafgek81 Quote
efferman Posted May 14, 2014 Author Posted May 14, 2014 parts for an tatra style axle same gear setup like this tatra from nico71, but no load on the central driveshaft Quote
T_Tank Posted May 15, 2014 Posted May 15, 2014 I was wondering about tatra stuff though is it even possible to make a tatra style differential??? Quote
rm8 Posted May 15, 2014 Posted May 15, 2014 (edited) Hi Just printed leaf spring at local 3D priniting company. They just opened their company, so they dont have experince. Material is PLA Leaf spring looks very ugly (but ok for the first time), but my main question and goal was to find out "will this part work as leaf spring"? So this construction is working well. Middle point of leaf spring is moving up 1 stud. Video later. Edited May 15, 2014 by rm8 Quote
efferman Posted May 15, 2014 Author Posted May 15, 2014 this part was printed with a method which works like an inkjet. you should search for laser sintered nylon. then the Quality will be better. but its nice to see that the leaf spring works Quote
Mtx Posted May 15, 2014 Posted May 15, 2014 (edited) I also printed part last week. This was made our older 3d printer. Print is pretty coarse, but thicker protrusion makes the piece more rigid. I will make smoother print for better appearance. This was just test to see will it be strong enough to carry some impact forces. The fit was perfect for my standarts at first try. Pins are little bit stiffer than normally, but can be assembled just by using fingers. In conclusion i was very satisfied for the part. I made cube with 15l liftarms and bigger L-shaped liftarms and attached my gopro inside. After five drops from the tabel part is still undamaged. Edited May 15, 2014 by Mtx Quote
efferman Posted May 19, 2014 Author Posted May 19, 2014 new parts have arrived and i have made a short vid Quote
rm8 Posted May 19, 2014 Posted May 19, 2014 (edited) new parts have arrived and i have made a short vid Thanks. Dfferntial 20Z was too noisy when rotating. And small gears rotate with friction, like limited slip differential. Did you polished it or it is raw right from shapeways? Could you make this part with pins (non friction)? http://www.shapeways.com/model/1847043/driven-steering-hub-small.html?li=cart Edited May 19, 2014 by rm8 Quote
TomasHubik Posted May 19, 2014 Posted May 19, 2014 The differential looks awesome. Do you think, it will handle torgue from XL motor or L Motor? And what is the cost of the differential? Quote
efferman Posted May 19, 2014 Author Posted May 19, 2014 (edited) yes rm8, the small gears are actually a bit tight, but when the unpolished surface is cleaned be some movement, i think it will run smooth. for the steering part i will look if its possible. tomas, i think this will depend on the tires dou you want to use. in relation to its size it is very strong. actually it can not jump over the small gears which fit very tight together. how the nylon gears are working under load is out of my experience. so the time will tell how good it works. in the quality shown on the video it cost 4$/ 3,49€ with all internal gears edit: sorry rm8, the steering part is not possible with pins this is the smallest possible when pins are used. Edited May 19, 2014 by efferman Quote
T_Tank Posted May 19, 2014 Posted May 19, 2014 still waiting on my 20z diff to come in though seeing the video look forward to putting them in my mini unimog! Quote
rm8 Posted May 19, 2014 Posted May 19, 2014 (edited) Working LEAF Spring. Efferman Design. It was printed with low quality and NOT on Shapeways. Before ordering it on shapeways.com, ask Efferman for best and flexible material. As you see - it works. Ampitude of flexing is 1-1,5 stud. IMHO 4 leaf springs can hold and work good with 1-1,5 kg model. But this configuration is only for standart car without lifting and other stuff. Standart articulation for old Hilux and so on... Edited May 19, 2014 by rm8 Quote
