SNIPE Posted January 18, 2015 Posted January 18, 2015 (edited) We need UV joints that dont slip off the axles and that dont crack. I dont know if LEGO will make something, a CV joint is too long and does not have much flex. Also a UV joint with a fixed 3 L axle on one side instead of an axle hole would be cool because it can fit in tight spaces, the 3L axle just goes to the diferential. Edited January 18, 2015 by SNIPE Quote
D3K Posted January 18, 2015 Posted January 18, 2015 We need UV joints that dont slip off the axles and that dont crack. Maybe one machined out of metal? How much do you think it would cost to have a standard 3L U-joint made that way? Does Shapeways do machining/milling of metal? Made of for example stainless steel, it would be strong enough to withstand a LOT of punishment Or does anyone on this forum have access to a high end mill or machining center? Quote
efferman Posted January 18, 2015 Author Posted January 18, 2015 Dont forget that you have to assemble the u joints. Snipe, a crossaxle instead of the crosshole. This i have tried and it is not solid enough Quote
D3K Posted January 18, 2015 Posted January 18, 2015 Dont forget that you have to assemble the u joints. Very true, didn't think that far ahead But do you know how they do their metal work? I know you can order custom jewelry and stuff, but I imagine they are cast in one way or another.. Do you know if they do machining? Quote
efferman Posted January 18, 2015 Author Posted January 18, 2015 They print with metal powder and put the piece after this in an oven. More i dont know. Quote
oracid Posted January 29, 2015 Posted January 29, 2015 (edited) I am very impressed by the work you do for the Lego community and I thank you. Currently, the maximum size of the racks is 13M. It would be great is there was a rack of 26 M. The same as the 64781. Do you think it could be possible to do this rack ? Thank you in advance for your attention. Edited January 29, 2015 by oracid Quote
Alien Posted January 30, 2015 Posted January 30, 2015 Hi Efferman Friend of mine pointed me in the direction of thompson coupling have you tried doing that with the 3D printing Its a great alternative to U Joints or even CV joints. Just don't know how doable it is. It looks to be a complex mechanism. CV joints on Wiki has a section and some technical pics of it also of course Google produces tons. Just a thought I know lots of the trail truck guys would love it. Quote
SNIPE Posted January 30, 2015 Posted January 30, 2015 (edited) it's the holes in the UV joints that break, the centre bit is fine. some axle holes on lego pieces are quite hard to push an axle in so maybe a UV joint can have this too, though it means having an accurate milling machine. For example this piece: is harder to push an axle into, and i'm sure ive seen harder pieces as well., the outsites of the UV joint should not be like a double bush but more like the very old red UV joints or the CV joints. Edited January 30, 2015 by SNIPE Quote
efferman Posted January 31, 2015 Author Posted January 31, 2015 (edited) Sorry for not answering, but iam actually on the dark side of the moon. And there is absolutely no internet in next three weeks. Oracid, theoreticly this is absolutely no problem, unfortunately i have actually only 24 hours at home per week. i will look what i can do. Dafgek, you are speculating for a rim like this? alien, the small balls are not successfully printable in lego scale. Snipe, my heavy duty u joints are like the old red ones Edited January 31, 2015 by efferman Quote
Dafgek81 Posted January 31, 2015 Posted January 31, 2015 (edited) I mean these type off wheel rims Edited January 31, 2015 by Dafgek81 Quote
efferman Posted January 31, 2015 Author Posted January 31, 2015 for this you can use the 530 rims 100_1460 by efferman, on Flickr Quote
Richard Dower Posted January 31, 2015 Posted January 31, 2015 Efferman....is it possible to make flat tiles with a curve on each end? Same type of curve seen in a Technic beam: Flat tile: So a flat tile with a curve on both ends, and another version with a curve on one end. In lengths 1x2 - 1x16.....is it possible? Quote
Richard Dower Posted January 31, 2015 Posted January 31, 2015 like the old steering plates? If you mean these old parts then no: I mean....kinda....the old steering plates have the curve at each end....but i just want them 100% flat on the top surface. The reason i want them is as you can see with modern Technic beams there is a curve on each end, wheni add a flat tile each end is square not curved to match the Techanic beam. Quote
Dafgek81 Posted January 31, 2015 Posted January 31, 2015 I understand, but a one piece smoother rim would be nice. Quote
oracid Posted February 1, 2015 Posted February 1, 2015 Tank you Efferman, I wil wait your coming back. Quote
efferman Posted February 1, 2015 Author Posted February 1, 2015 do you want a gear rack for extending a boom or as a steering rack? Quote
oracid Posted February 1, 2015 Posted February 1, 2015 Sorry, I don't understand your question. What I want is the same as this one but with 26M long: http://www.shapeways.com/product/CWAE2VNAR/gear-rack-7l?li=user-profile&optionId=41744904 Thank you by advance. Quote
oracid Posted February 4, 2015 Posted February 4, 2015 Hi Why do you use Autodesk Inventor instead of Autodesk 123D Design, which is free : http://www.123dapp.com/design . Only to make my mind understanding. Quote
efferman Posted February 7, 2015 Author Posted February 7, 2015 i use inventor because i need this in my job. Quote
oracid Posted February 7, 2015 Posted February 7, 2015 Hi, I just realized this is the piece I need. I ordered 10 : https://www.shapeways.com/product/4QE5P2AC9/gear-rack-beam-4l?optionId=41744256&li=ostatus Thank you for your attention. Quote
oracid Posted February 9, 2015 Posted February 9, 2015 Hi Since I have seen your topic, I Am very interested in 3D printing. I was wondering, in Shapeways site, I don't see nylon material. I Can see Detailed Plastic, Elasto Plastic, Frosted Detail Plastic etc... but nothing about nylon. I guess the real name is not nylon. Can you tell me what is the exactly name of the material you are using. Thank you in advance. Quote
nicjasno Posted February 9, 2015 Posted February 9, 2015 Ah, the trilex wheel system. I love the looks of the trilex rims on old trucks. Makes them look so tough. Quote
weavil Posted February 10, 2015 Posted February 10, 2015 I was thinking of something like this but shorter. This way I can fit it into a small LA to use with a U-joint. Something to this effect.... OR Quote
