  • Replies 1.9k
Is there any chance of your reviving this piece?
It seems far superior to the 8880 hubs I am struggling with. An independently sprung crawler would be quite awesome.
v/r
Andy
Dafgek, a friend has ordered the leafsprings. He want to build a tipper truck with them.
Andy i will take at this weekend a look on it to bring it online.
Efferman, When I look at the Axle Support Frame piece I always think of using it as part of a custom bionicle figure but there's another custom part I'd need to do that. Could you make a ball-joint socket that I could attach to the four holes on either end?
Efferman,
Last year you made mudguard parts for the Unimog and 8258 tyres, could you design a size for the old 24x43 wheels, the ones used on the back of the old 8862 backhoe loader?
I am collecting parts for an Actros that uses those wheels and planning on building a tipping trailer behind it, would like to use a set off those type mudguards on it.
Hello Effe,
I have ordered few 3D printed objects from Shapeways designed by you.
I received this E-Mail regarging "Actuator Stroke 18 Outside"
XXX (Shapeways)
Hi XXX,
I wanted to reach out to you about your order XXX .
Specifically your Actuator Stroke 18 Outside. We here at Shapeways try to be as open and upfront as is possible with our community. I have your model in front of me and it looks like it did not leave our printing process unscathed. It looks like the sprue broke before we could dye it.
Can you review the attached picture and let me know if you would like us to still dye the model in black and ship it to you?
What do you say Effe... It's OK to dye it BLACK... or?
Thanx...
MaxSupercars
Edited by MaxSupercars
damn connection wires! now i know why the print success is lower than 80 percent. ok, next revision of connection is to do.
for you i guess is best to get the white parts and colouring it yourself. so you can colouring the hull and the piston rod in different colours.
nevercallmebyneme
here it is
https://www.shapeway...0ddc96667284bc7
axle support frame for torsen diff with bionicle ball on top
a suspension arm for bionicle balls
a wishbone for bionicle balls, made for large truck models
[quote name=efferman'
Love these parts, can you show in a render how they are placed and fit together and how a technic diff would fit in there?
Hello Efferman, love those suspensionparts, can you make a render how they are placed together and how a Technic diff would fit.
Edited by Dafgek81
Hello Efferman,
Thanks for designing the fender.
Will take some time before I can use it, money is kind of tight now and I have to build the truck fisrt.
Maybe I will use them for that to, but I don't know yet.
Still hoping to build the truck this year, but I don't know if I can.
Can you also make a fender for a single tire, maybe the trailer will get single tires.
You are from Germany, could you tell me what is common there on a side tipping combination.
Dual or single tires on the trailer?
@nevercall
I will order a set at beginning july.
Dafgek
I am not much in touch with trailers, but simple standard trailers should have a wider single tire.
