ritztoys Posted January 14, 2016 Posted January 14, 2016 New turntable parts received and prior to using them on my crane build I tried the suggestion that 4 wheel holders could be used and connected by Lego 90 deg connectors. It doesn't work - a 4L x 4L- 90 deg connector would be required to get aligment correct. Thanks for checking out that idea, as I didn't have the parts in front of me. Maybe effermans' new liftarm would work, post # 1285? Quote
doug72 Posted January 14, 2016 Posted January 14, 2016 Thanks for checking out that idea, as I didn't have the parts in front of me. Maybe effermans' new liftarm would work, post # 1285? Thats 5 x 3 but something similar with 4 x 4 with 3 horizontal pin holes on each side with a vertical pin hole in the corner. Quote
Aleh Posted January 14, 2016 Posted January 14, 2016 (edited) efferman, hi there! I'm new to this forum, Do you make parts for sale? Is it possible to see your custom partlist? Thanx! Edited January 14, 2016 by Aleh Quote
Tommy Styrvoky Posted January 14, 2016 Posted January 14, 2016 (edited) Could you eventually work on a 4 stud, 6 stud,and 7 stud wide sprockets, as It's difficult to work with just 5 and 3 stud wide sprockets, It would be nice to have different choices, as on some of my models the sprockets are too small or too big Edited January 14, 2016 by Tommy Styrvoky Quote
efferman Posted January 14, 2016 Author Posted January 14, 2016 Tommy look at this maybe this sprocket gears are fit to you. @aleh sure https://www.shapeways.com/designer/efferman Quote
Tommy Styrvoky Posted January 14, 2016 Posted January 14, 2016 (edited) Tommy look at this maybe this sprocket gears are fit to you. @aleh sure https://www.shapeway...signer/efferman You don't need to make all of them, but a 7 stud wide sprocket would be the most useful on other larger models. If it follows the same pattern of the other sprockets, it would have 10 teeth. I think the 4 and 6 stud sprockets would have a weird set of teeth, as I don't think it would be a whole number, though they would be cool to have as options.Also i'm refering to sprockets for the newer wider track, not gears for the older 3 stud wide track Edited January 14, 2016 by Tommy Styrvoky Quote
efferman Posted January 16, 2016 Author Posted January 16, 2016 tommy, the 7 hole diameter sprocket has 14 "teeths" i have set the holes in a cross to make it easier to put plates on it. The whole sprocket gear is only one stud wide to make the chassis more flexible Quote
Tommy Styrvoky Posted January 16, 2016 Posted January 16, 2016 tommy, the 7 hole diameter sprocket has 14 "teeths" i have set the holes in a cross to make it easier to put plates on it. The whole sprocket gear is only one stud wide to make the chassis more flexible Thanks for doing this, I like that it's 1 stud wide. Quote
doug72 Posted January 17, 2016 Posted January 17, 2016 (edited) @ efferman That new turntable idea looks great. :thumbup: Maybe that 'technic' piece (that holds the three wheels) could be used in (4) positions using a common LEGO 90* connector? http://alpha.brickli...age?P=55615#T=C Correction - it is possible to mount four wheel holders around the turntable support using four Cross Block Beam Bent 90 Degrees with 4 Pins (55615) see photo - note the four red 7L beams show where the wheelholders would be located - mine are now built into my WIP- MOC. My crane MOC uses only two wheelholders but is very stable when rotating without any wobble. IMG_3012 by Doug Ridgway, on Flickr Edited January 17, 2016 by Doug72 Quote
efferman Posted January 17, 2016 Author Posted January 17, 2016 aah, it fits. tommy, the 14 teeth sprocket gear is now available and some other parts which looks asssembled like this Quote
Tommy Styrvoky Posted January 17, 2016 Posted January 17, 2016 aah, it fits. tommy, the 14 teeth sprocket gear is now available How durable will it be with only the 4 attachment points on the outer ring? I fear something will break under strain. Quote
efferman Posted January 17, 2016 Author Posted January 17, 2016 It should be stable enough, but when you fear a break i will add something. Quote
aminnich Posted January 17, 2016 Posted January 17, 2016 Im just curious, but what is the advantage of having the sprocket 1L thick? Quote
efferman Posted January 17, 2016 Author Posted January 17, 2016 It makes it simply more flexible. Quote
aminnich Posted January 17, 2016 Posted January 17, 2016 Is their a video of how your turntable works? I kind of get it, but I just wanna make sure. Definitely something I wanna get Quote
aminnich Posted January 17, 2016 Posted January 17, 2016 Yes, I love this 3D part. But just to clarify, I need the "wheelholder for Turntable Support" and "Turntable Support 13 studs diameter", right? Quote
efferman Posted January 17, 2016 Author Posted January 17, 2016 Yes! If you need maybe a 17m version, wait a few days. Quote
aminnich Posted January 17, 2016 Posted January 17, 2016 Im thinking to add it to the 42042 crawler crane, once I mod it. So will the 13m be a good size?? Quote
efferman Posted January 17, 2016 Author Posted January 17, 2016 It would fit better than the 17m version. Quote
aminnich Posted January 17, 2016 Posted January 17, 2016 Ok thanks for your help! and the great parts! Quote
Tommy Styrvoky Posted January 18, 2016 Posted January 18, 2016 (edited) It should be stable enough, but when you fear a break i will add something. I have had models break and bend parts before, I want to make sure that I have a durable piece if I am going to spend $10 on it, and also what plastic would you suggest, i'm thinking black. If you could fill the piece like the lego sprockets. I just want to make sure it can handle some serious stress. Thanks! Edited January 18, 2016 by Tommy Styrvoky Quote
doug72 Posted January 18, 2016 Posted January 18, 2016 Is their a video of how your turntable works? I kind of get it, but I just wanna make sure. Definitely something I wanna get My post: http://www.eurobricks.com/forum/index.php?showtopic=117595entry2437779 This shows how the new Efferman 13L turntable support is mounted on a crane base and wheel holders are installed on my dockside crane MOC. The rotation is very stable and smooth. Quote
efferman Posted January 18, 2016 Author Posted January 18, 2016 (edited) Tommy i have filled the holes. now it is a full 2mm thick disk. edit: the turntablesupport is now available with a diameter of 17 studs. Edited January 18, 2016 by efferman Quote
Tommy Styrvoky Posted January 18, 2016 Posted January 18, 2016 (edited) Tommy i have filled the holes. now it is a full 2mm thick disk. Thanks, these sprockets are the perfect size for a Panther tank, as the sprocket should be larger than the road wheels, this will work great for 6 stud inverted radar dishes when used as road wheels. I may be putting 4 XL motors through both sprockets, so I think this will give me plenty of contact points to secure it to the final drives. Edited January 18, 2016 by Tommy Styrvoky Quote
