  • Replies 1.9k
Cool, thanks!!!!
Order them when the buckets are online and my Actros is nearly finished, won't be needing them sooner.
Edited by Dafgek81
I'm guessing it will be pneumatic?
Could a gear rack one be done or isn't that possible? Basically the 42043 outrigger but with another casing and the middle part would have gear teeth on the sides. I don't know. I wish my CAD program is working
Could be the image angle, but it seems a little big/bulky for this crane.
Is it pneumatically driven? Or can it be made pneumatically driven, with the new 1stud wide v2 pneumatic cylinders?
i have ordered the telescopic parts five minutes ago so i can show you the real life dimensions in roundabout two weeks. And we will see how the 1x11 cylinders work with them.
What about creating some bigger knob gears that works with the old one.
So you can use them for gearing up and down.
And create a differential made only with different knob gears.
Is this possible?
sorry for answering so late.
Tripletschiee
The female towballs dont have frictionridges, but they fit without much play.
rehnskit, i will make a sketch to get a idea about the dimension
edit: a knob 6 would have a diameter of 4 studs. a pretty large Diff this would give
Edited by efferman
Big sounds good.
So if I understand you correctly. It might be possible to build a big differential with only Lego parts. That would be really nice.
I been looking at your Torsen differential. How much rpm/torque can it take?
And how much does all of your other gears hold against high power?
As I understand your material is stronger then the material Lego is using. But can't you make parts in metal for example differential and gearboxes?
But maybe it would be to expensive...
Rehnskit, metal is to expensive and has some size limitations. for the torsen diff you should ask Sariel, he has made a test with it.
tripletschiee, sure it is possible, Do you would order some of them?
edit:
the knob 6 is online
Edited by efferman
Hello Efferman,
I would like a part to fit to front axle truck rims.
It's the ring that protects the nuts from the hub against damaging.
It should be something like the 4185 pulley wheel, but without the centre.
Just the outer part with the holes.
So it has to be fitted on the rim with the 1 1/2 dbg pins.
Hi efferman,
I want to order your wheel covers for the 42030, but I can't choose between the two options: the standard "white strong and flexible" or the "yellow strong & flexible polished". I have ordered your Unimog rims in "white strong and flexible" before and painted them myself, so I understand the finish of the standard material. Now I'm curious about the colour match and finish of the "yellow strong & flexible polished" material.
Do you (or anybody here) have a picture of the quality and colour of that material, maybe compared to TLG parts? Thank you in advance.
Edited by Cumulonimbus
Hi Efferman,
Would this crane section fit on my Actros crane?
It is a bigger scale as you know.
And can single pneumatic cylinder lift it.
Here is a link to the original crane:
http://www.brickshelf.com/cgi-bin/gallery.cgi?i=618399
It is made out of old bricks and plates, so it is a bit heavy.
And how is the clamshell bucket coming along??
Edited by Dafgek81
