doug72 Posted April 10, 2016 Posted April 10, 2016 Efferman, Many thanks - that's exactly what I need. Also useful for making ferris wheels and fairground rides. Once price is known will be ordering with next batch of 3D parts from Shapeway. Quote
efferman Posted April 10, 2016 Author Posted April 10, 2016 It is a set of two pieces which comes in white, black and metallic plastic which has a silver grey finish Quote
Dafgek81 Posted April 10, 2016 Posted April 10, 2016 Looks very nice, the price is very steep, but it will look so cool. Quote
Cumulonimbus Posted April 17, 2016 Posted April 17, 2016 As promised, here are my experiences with your 42030 wheel covers, so here it goes. Contrary to my Unimog covers, this time I wanted to get a smooth finish so after receiving the parts, I started sanding by hand and with a small power tool. However, I wouldn't recommend this because I ended up with some polished areas, but the difficult to reach areas were still rough and some of the details (fake wheel nuts) were damaged by the process. It took a lot of time to get an acceptable finish. Luckily, the painting step went a lot easier because I found a close to perfect colour match with a Motip acrylic spray paint in a rattle can (nr43570). In conclusion, the end result is not perfect but all in all I'm happy with the end result: Efferman, thank you for your design, it really completes this excellent set. Quote
Gnac Posted April 17, 2016 Posted April 17, 2016 As promised, here are my experiences with your 42030 wheel covers, so here it goes. Those rims do look mighty fine, and as a layman I wouldn't even know there were problems unless pointed out. Quote
AFOLegofan66 Posted April 18, 2016 Posted April 18, 2016 Now that I see the wheel covers I will get a set for myself...thanks Quote
JJ2 Posted May 10, 2016 Posted May 10, 2016 Can you try to make a portal hub gear protector to keep dirt out for the 9398 hubs the connect using the two pin holes near the dark grey hub? Quote
Dafgek81 Posted May 11, 2016 Posted May 11, 2016 My Actros is finished, hope to order the clamshell buckets soon. Quote
MRP_ Posted May 14, 2016 Posted May 14, 2016 Could you design a steered wheel hub, like the normal ones used in 42037, but instead of a slot for a cv joint, it has an attached half of a universal joint, like kind of recessed so you could have front wheel drive with full range of suspension travel? (If you do I promise I'll go make a donation to a local animal shelter :D) Quote
MRP_ Posted May 14, 2016 Posted May 14, 2016 (edited) edit- invalid link Edited May 14, 2016 by MRP_ Quote
MRP_ Posted May 14, 2016 Posted May 14, 2016 Oh how do I fix it Sorry was on my school account here is real link https://drive.google.com/open?id=0Bw3xDAPnR3sbQk4wdEZmTGJndVk Quote
efferman Posted May 16, 2016 Author Posted May 16, 2016 why not using this? instead of you joints the piece 2907 is used https://www.shapeways.com/product/PS74T8S2G/wheelholders-in-8880-supercar-style Quote
AndyCW Posted May 16, 2016 Posted May 16, 2016 MRP_, The part that Efferman posted is stronger and has a closer pivot than your concept. I have a pair and they 'get-r-done'!! I've even managed to make a training arm IRS with them. v/r Andy Quote
MRP_ Posted May 16, 2016 Posted May 16, 2016 Hmmm yeah that looks good, but I dont have any of the balls that go into it, do you have a print for those, or would I have to go to bricklink? My friend's looking into buying a 3D printer, I might have him do it... Quote
nicjasno Posted May 16, 2016 Posted May 16, 2016 Please no moulded ball joints on the hubs. If we do hubs, they need only pin and axleholes. Quote
MRP_ Posted May 16, 2016 Posted May 16, 2016 Ye I know I don't NEED it but I'm lazy and it would make things easier and look nicer... Quote
nicjasno Posted May 16, 2016 Posted May 16, 2016 Can someone post images of all the current wheel hubs with 8880 cv joint from this thread? Quote
efferman Posted May 16, 2016 Author Posted May 16, 2016 There is only the type above and the large driveshafts Quote
nicjasno Posted May 16, 2016 Posted May 16, 2016 I see... that one isn'tvery good looking. looks very fragile and has ball joints on it, which is a big no-no. Quote
MRP_ Posted May 16, 2016 Posted May 16, 2016 Read back mate, the people who actually have one beg to differ... Quote
AndyCW Posted May 17, 2016 Posted May 17, 2016 Here are those hubs with the ball adaptors from 8880. This iteration is far better than V1 and should hold up to a great deal of abuse. Basically the same architecture was used in this MOC. With the ball part installed, I can not separate the wheel adaptor from the hub, but removal of the ball may weaken the structure. After all, the ridge that holds the wheel adaptor to the hub is preventing from deflecting by the presence of the ball. v/r Andy Quote
MRP_ Posted May 17, 2016 Posted May 17, 2016 It seems I got kind of skipped over before, I was just wondering if you have a design for those ball adapters, to print, or would I have to order some from bricklink or something? . Quote
nicjasno Posted May 17, 2016 Posted May 17, 2016 The problem wit the integrated ball joints is, that it completly eliminates all suspension variations. It's then only made for a double wishbone setup, and that's it. Quote
