UltraViolet Posted February 15, 2021 Posted February 15, 2021 Hello efferman, You seem to be the go-to guy for custom part design, and I am seriously impressed with your work and creativity. I'd humbly ask if you'd consider creating a design for me. I am seeking an alternate size for part 65617: The original is 3x3x1 in size, but I need one that is 4x4x1. The layout for the underside could be sourced from the nearest similar part, 48092, because it has the same horizontal radius of curvature. If it were published to Shapeways, I would preferably like the color option Red to be available. I see that you generally focus your work on Technic parts, but hopefully you would be willing to do this 'standard' brick, as it ties directly into a number of other existing parts in the same family. Additionally, a question to the other members of the EuroBricks forum - how accurate versus standard LEGO color is the Red offered by Shapeways? Is it close enough, or would you recommend I paint the finished part myself? Quote
efferman Posted February 15, 2021 Author Posted February 15, 2021 11 hours ago, UltraViolet said: Red offered by Shapeways? Paint it by yourself. Colouring is a Gamble. This is 3 plates thick? never seen this part. Quote
UltraViolet Posted February 15, 2021 Posted February 15, 2021 65617 was released in 2020, and yes, it is 3 plates thick and curves continuously from the bottom edge. It's supposed to match with the straight piece 37352, and 24599 which are also 3 plates thick. As a family It shares vertical curvature with 6091, 6081, 6191 and 67810 (there are some others too), but those have an extra plate height at their bases before the curve begins. It would be more flexible to have a 4x4x1 than a 4x4x1-1/3. I need to make a continuous 180 degree bend between two parallel 6191s sitting on the outer studs of an 8-wide space. If this part can be created, I will need at least eight pieces, but will probably order many more in case this element is never officially released. Cost is of very little concern to me, as these will be a signature feature on a MOC. Quote
Bartybum Posted February 16, 2021 Posted February 16, 2021 I don't mean this as a request or anything, but have you ever looked into designing a fluid coupling/torque converter? Quote
DrJB Posted February 16, 2021 Posted February 16, 2021 1 hour ago, Bartybum said: I don't mean this as a request or anything, but have you ever looked into designing a fluid coupling/torque converter? You might as well ask for a Variable Volume Pump. Those parts are best made of clear plastic, so one can see the inner workings. Typically though they require very smooth surface finish for them to be hermetically sealed. Quote
Bartybum Posted February 16, 2021 Posted February 16, 2021 (edited) 14 minutes ago, DrJB said: Those parts are best made of clear plastic, so one can see the inner workings. Oh man imagine that. That could totally be possible with polycarbonate filament. Surely some o-rings could be enough to seal them mostly? I've seen a guy on YouTube who made one a while back out of bottlecaps: Edited February 16, 2021 by Bartybum Quote
DrJB Posted February 16, 2021 Posted February 16, 2021 (edited) Thank you for sharing. That is simply incredible. Now you got me thinking .... err ... dreaming. Edited February 16, 2021 by DrJB Quote
efferman Posted February 19, 2021 Author Posted February 19, 2021 On 2/16/2021 at 12:42 AM, UltraViolet said: I will need at least eight pieces, Mudguards? I can not guarrantee the grip of the studs. Maybe the holes are to tight, maybe to loose. https://www.shapeways.com/product/3WFLSFSSP/slope-curved-maccaroni-4x4x1-stud?key=18b09252707f3ff8394b285cd03c6f73 by the way https://www.shapeways.com/product/GRPT2GA4U/flatbedmudguardpanel-3x7x1-4-piece-set?optionId=200705104&li=shop-inventory Quote
UltraViolet Posted February 19, 2021 Posted February 19, 2021 9 hours ago, efferman said: Mudguards? I can not guarrantee the grip of the studs. Maybe the holes are to tight, maybe to loose. https://www.shapeways.com/product/3WFLSFSSP/slope-curved-maccaroni-4x4x1-stud?key=18b09252707f3ff8394b285cd03c6f73 This should do quite nicely, thanks so much!!! I may use this shape for mudguards on another project, but in my current build they will be laying flat, so clutch should not be an issue. I am prepared to fine-tune or glue them if required. I just ordered 16 pieces from ShapeWays so I'll have some spares to play around with, as well as some of your 3x2 panels and panel corners because I have another idea for them. Quite amazing, thanks again! Quote
UltraViolet Posted February 20, 2021 Posted February 20, 2021 The was something else that came to mind today which is actually technic related. I recall having more than one tight space were this would have been helpful. It would be like a 18677 "Plate, Modified 1 x 2 with Pin Hole on Bottom" except with the hole centered like on a 2444/10247. The 2444/10247 doesn't allow an axle to pass all the way through under the rest of the 2x2 plate. You could also think of it as a short-height variant of 32529. My only concern would be clutch power if suspended below another part. 18677 2444/10247 32529 11458 Also useful would be 1x2's plates with the hole facing out the narrow side. This could be done above or below the plate. I'm not actually requesting these, just musing out loud. The 1x2 with centered hole on bottom is the thing I could most likely use in the near term. Quote
efferman Posted February 20, 2021 Author Posted February 20, 2021 i see studs, many studs.... ....and Pinholes Quote
syclone Posted February 20, 2021 Posted February 20, 2021 (edited) Trypophobia intensifies Seem to be very versatile, even more than the cracker (?) parts introduced recently. Aslo something that TLG seems to be heading towards considering the beams with alternating holes from this year and extra large frames. Wonder how well they'll resist torsional forces Edited February 20, 2021 by syclone Quote
efferman Posted February 20, 2021 Author Posted February 20, 2021 21 minutes ago, syclone said: Wonder how well they'll resist torsional forces me too Quote
DrJB Posted February 20, 2021 Posted February 20, 2021 (edited) Very nice pieces indeed. While these would definitely increase the building options, I'm not sure TLG can make such parts 'easily'. When building a cavity mold for such pieces, while the shape is 'easy' (relatively) to make ... de-molding seems like an unsurmountable challenge. 2 hours ago, efferman said: i see studs, many studs.... ....and Pinholes Edited February 20, 2021 by DrJB Quote
pleegwat Posted February 20, 2021 Posted February 20, 2021 1 hour ago, DrJB said: Very nice pieces indeed. While these would definitely increase the building options, I'm not sure TLG can make such parts 'easily'. When building a cavity mold for such pieces, while the shape is 'easy' (relatively) to make ... de-molding seems like an unsurmountable challenge. Are they really that much more complicated than the sandwich panels though? Quote
DrJB Posted February 20, 2021 Posted February 20, 2021 (edited) Which sandwich panel ... the one below? Edited February 20, 2021 by DrJB Quote
UltraViolet Posted February 20, 2021 Posted February 20, 2021 I really like those so called "cracker" or perhaps 'waffle' grids. They kind of remind me of high-strength molecular structures, such as in carbon fibre. Quote
doug72 Posted March 10, 2021 Posted March 10, 2021 Both look ideal for solving the difficult mounting problem with these gear rack housings. Quote
suffocation Posted March 11, 2021 Posted March 11, 2021 2 hours ago, efferman said: What is your opinion about this? This would be a godsend, although I'd prefer it with axle holes to accommodate these: Quote
AFOLegofan66 Posted March 11, 2021 Posted March 11, 2021 Very nice pieces and very useful for me. Both pieces have their function but the second piece looks like it could take more torque ..It would be my choice. Quote
Bartybum Posted March 11, 2021 Posted March 11, 2021 I prefer the second piece - it looks much sturdier. I agree with the cross-axle hole idea though Quote
efferman Posted March 11, 2021 Author Posted March 11, 2021 6 hours ago, suffocation said: This would be a godsend, although I'd prefer it with axle holes to accommodate these: Axle Holes are a gamble at shapeways. They call a tolerance of +-a tenth and on axle holes this is the difference between falling through and inserting it with a hammer. so i prefer Pinholes Quote
Mechbuilds Posted March 11, 2021 Posted March 11, 2021 Pin holes are also sturdier than axle connections.. Pins don't slide out. Quote
J159753 Posted March 11, 2021 Posted March 11, 2021 First one looks much more 'Lego' to me - but either would be great! Quote
