There is a much easier alternative, but works for a single wire/tube ... or maybe few, but they must be bundled together.
This can be done rather 'easily', without any complex seals/rings ...
and how do you would solve this?
It's a classical problem (with solution) in mathematical topology ... http://www.eurobrick...=0#entry1832795
Edited by DrJB
  • Replies 1.9k
sorry but not every mathematic solutions makes sense in real live, or why do you think the crane manufacturers ad a slew spool for thousands of euros when this is so easy to solve? a turntable without a slew spool must be blocked after 2 and a half turns to prevent the hoses to die.
btw
drehkranz mit durchführung von efferman auf Flickr
If you're 3D printing the turntable, why make it in 3 separate parts? You can get away with only 2 (and that might bring the cost down). Of course, if the parts were injection molded, you would not be able to assemble them.
Edited by DrJB
for the big turntable it is the most stable solution and the risk of popping out without a collapse of plastics is zero. the smaller turntable is not so safe with its two parts, and during asembly the part will be stressed.
alasdair, here are the files.
https://www.dropbox....urchführung.zip
the dimensions are in mm and in the textfile i have some dimensions as reference for your printing service
edit:
edit²
need a bucket for 8043?
bucket von efferman auf Flickr
Edited by efferman
Strange, it seems that my software makes an error in when it converts the model in stl and stp. So a diameter of 88 mm will be printed 8,8mm in diameter. Or is this the intention of autodesk to prevent an non school use?
It could be the non school use... Because some software made for students is cheaper, but has few features. Like the file types supported that only pertain to training/learning of the software.
I remember that being a problem with Pro/Engineer and Creo Parametric as well, where I couldn't take a model from my laptop (pirated software) to the desktop I used at school... These are very expensive programs, so I see why they might place piracey protection measures all over the place. :blush:
They hear the students cry about price, then they offer a discounted version as "Home/Student" and leave ,what they feel as, basic functions of the software. This happened with Microsoft when they released Office 10 (I think) and something else. Usually pirated stuff has the same limits as the retail version that is pirated. If something is wrong the person who did the crack it at fault.
Could it be this:
You have to make sure you use the correct notation for decimal point. In Europe, the coma (virgule) is used. In the US, the dot/point is used.
I had such issue on something as basic as Excel, trying to open files I obtained from German colleagues ...
Edited by DrJB
weavil, my software is not cracked. i have to learn a new job, because my leg is damaged permanently and i cant do longer my old job.
DrJB, my inventor softare let me only use the comma
d3k, there is minimum a permanent watermark on the files
indeed, iam doing this actually for the big turntable and i minimize the material usage for shapeways
edit, the turntable is available now at shapeways
https://www.shapeways.com/model/1734360/heavy-duty-turntable-upper-part.html?li=my-models&materialId=6
https://www.shapeways.com/model/1734369/heavy-duty-turntable-bottom-part.html?li=my-models&materialId=6
Edited by efferman
