  • Replies 1.9k
Ok, better than to loose. I will make a comment on shapeways
Let them know one out of the four installed on the axle without too much difficulty, the other three needed help in cleaning out the axle hole. :wink:
Hi efferman,
I watched this thread very closely. First of all, GREAT work...
Do you have an idea for a nice wheelcover for the Unimog? Especially for the U406?
And the next challenge. A rim for a large tractor in the scale 1/12,5...
Pat
The original Xerion has a 710/70R42 tire. In the scale 1/12,5 the tire should have an outer diameter of about 150mm... The Barnhausen wheel no. 8077 should fit best...
Looks great! Is it possible to show how this wheel cover would look when mounted on the original lego rim? Is this Wheel cover only mounted via the axle hole or does the 4 edges have any clipping function?
@ Pat-Ard: Why not use a 900/60 R 42 as reference? This is also possible on the Xerion 5000. Just more expensive... :laugh:
Edited by stefan_betula_pendula
the rims for the xerion should the fit on my planetary gear? and i need the exact dimensions of the rim, because the tires are full rubber so they cant be squeezed
Edited by efferman
wow, that's a number ;-) I'll try to get contact to the tire manufacturer. There are some things I would like to ask him. After that I think we can get into the details...
To all considering these custom parts........................................as they say, " Just Do It", you'll see you won't be disappointed. :thumbup: :thumbup:
Here is an example of effermans' first wheel covers
These are installed on M_longers L580 Loader, very pretty aren't they? :wub:
