DrJB Posted December 6, 2014 Posted December 6, 2014 (edited) besides the bucket, the rest are all common parts, right. I want to try with my existing parts first, and decide if it'worth getting. Has anyone tried this? Yes I have plenty of parts and no need to add, at this stage at least. Edited December 6, 2014 by DrJB Quote
therealjustin Posted December 6, 2014 Posted December 6, 2014 This is a must if you own the 42030. Stellar work indeed by Efferman! I was surprised at how many of the needed parts I had but I still had to order a few through Brick Link so I don't cannibalize other models I also grabbed a set of Crawler Innovations closed cell foam inserts for the rear tires to help with the weight of the battery box. Quote
miguev Posted December 9, 2014 Posted December 9, 2014 Thanks again for the LDD and detailed steps relative to original instructions. You details (beyond step 57) out, as an exercise for the reader I guess... it was fun Is anyone planning to MOD the bucket arm? The range of bucket tilt makes it really hard to pick up big blocks, I just tried today and was much harder than with the 8043-B model, which allows tilting the bucket back/up when the arm is lowest. Little video to explain this better: Quote
TJoling Posted December 10, 2014 Posted December 10, 2014 The range of movement is appaling indeed! But that can easily be fixed by changing the pivotpoint on the lever which connects the LA to the bucket, right? You lose a bit of force for tilting the bucket, but the range of movement increases a great deal. I do not own the set, so I don't know if this is possible, but that would be my solution. Quote
miguev Posted December 10, 2014 Posted December 10, 2014 Yep, you nailed it, I was too lazy to even think about it. I just shifted this join by 1 stud: and now I can pick up many more blocks! :) Shifting by 2 studs wouldn't work because then you wouldn't be able to empty the bucket when raised, it would only stay with it's bottom flat horizontal. Shifting the point where the LA joins the other end of this inner lever didn't seem like it'd work either, the LA would not be able to fully retract. Quote
Paul B Technic Posted December 18, 2014 Posted December 18, 2014 LEGO Technic 42030 - MOD Fork Attachment Recently I purchased LEGO Technic set 42030 with a view to modifying this and adding my own attachments. My first attachment is a set of lifting forks and a pallet which can be used to lift and carry various items. This took me about a hour to build using a few parts. I have used the same mounting points as the standard bucket which can be easily swapped over as needed. Video and photos can be found here: http://paulstechnic.blogspot.com.au/2014/12/lego-technic-42030-mod-fork-attachment.html Quote
Rishab N Posted December 18, 2014 Posted December 18, 2014 (edited) LEGO Technic 42030 - MOD Fork Attachment Recently I purchased LEGO Technic set 42030 with a view to modifying this and adding my own attachments. My first attachment is a set of lifting forks and a pallet which can be used to lift and carry various items. This took me about a hour to build using a few parts. I have used the same mounting points as the standard bucket which can be easily swapped over as needed. Video and photos can be found here: http://paulstechnic....attachment.html I thought you sold all your Lego and gave up? Nice to see you back though Edited December 18, 2014 by Rishab N Quote
__________________________ Posted December 18, 2014 Posted December 18, 2014 Thanks Now, where the first reviews are online, i see that i have a higher gear reduction, and the 42030 has more speed. Not sure which solution is better. The real model probably has more torque than RPM. Quote
Paul B Technic Posted December 21, 2014 Posted December 21, 2014 Following on from my previous MOD attachment for LEGO Technic set 42030 I have just finished my next attachment, a grabbing claw. This attachment is normally used in forestry type work but can also be used for general lifting and loading. I spent about 5 hours over a few days working on this, the most amount of time was on testing the claw to get the opening and closing working correctly. I have used the same mounting points as the standard bucket and my other attachment which can be easily swapped over as needed. A Video and more photos: http://paulstechnic.blogspot.com.au/2014/12/lego-technic-42030-mod-grabbing-claw.html Quote
Freekysch Posted December 21, 2014 Posted December 21, 2014 Interesting attachment you made, I like it very much ! Quote
efferman Posted December 21, 2014 Author Posted December 21, 2014 there is an instruction available for my steering mod https://www.dropbox.com/s/nw33u1dekbi6e47/42030%20lenkungsmod.pdf?dl=0 thanks to catweazel for doing this Quote
technicbuilder Posted December 21, 2014 Posted December 21, 2014 Hello Efferman and Catweazel, Great job did you both with the steering mod and the great building instruktions,i just start building my second 42030. Thumbs up. Thanks. Quote
Kumbbl Posted December 23, 2014 Posted December 23, 2014 (edited) Thanks a lot to Efferman and Catweazel for sharing this MD and on top this great instructions... now - after eliminating this crappy because so jerky steering - the 42030 loader is a winner for me... Edited December 23, 2014 by Kumbbl Quote
efferman Posted December 24, 2014 Author Posted December 24, 2014 I have a updated instruction for you http://bricksafe.com/files/efferman/42030%20lenkungsmod.pdf again many thanks to catweazel Quote
barman Posted December 30, 2014 Posted December 30, 2014 (edited) Just like efferman I modified the steering with mini LA's and a M-motor. I did this in September so I could use the Volvo moving crude wooden sawdust around during Legoworld the Netherlands. In order to have more power I reduced the gearratio 12:20. I had no time to post this earlier. See my Flickr ablum for detailed photo's. https://www.flickr.c...57649994492661/ 42030 modified-02 by Barman76, on Flickr To have a good control over all 4 functions, I made a dubble joystick controler. In the video you can see how it works. https://www.flickr.c...157649994492661 Instructions on how to make the controler, will be uploaded in a couple of days, in the same album. Edited December 30, 2014 by barman Quote
JuiceStain14 Posted December 31, 2014 Posted December 31, 2014 Now when there is a Quick-change coupling we need some attachments for it Pallet forks for example or is the crane arm more interesting? I did fix the bucket too I have created LDD files for all three https://www.dropbox.com/s/1i1qbcejkujutmn/L350_Quick_connect_pallet_forks.lxf https://www.dropbox.com/s/hkcdiffm07k2hw8/L350_Quick_connect_crane_arm.lxf The big bucket does not exist in LDD yet so I have just made the adapter https://www.dropbox.com/s/jb0jee102w2kqqw/L350_Quick_connect_Bucket.lxf Can you make the file in a different thing from dropbox Quote
Siegfried Meyer Posted December 31, 2014 Posted December 31, 2014 Down at the bottom end of Africa you still can't get truckloads delivered from Bricklink... And internartional incoming small packages have a nasty habit of disappearing in the postal system. So I kinda have to make do with what I have Hi There Try ordering from the USA or Netherlands shops on B-Link with DHL as courier. You should receive them within 6 weeks from date of order. Your quick coupling system does it just hook on to the attachments or are there any pins holding it together. Quote
Brick_Sticker Posted January 1, 2015 Posted January 1, 2015 (edited) I've heard several reports of people being unhappy with the 'jerky' steering on this model. One quick and easy mod that I did is to use the train remote for steering, and then connect the xl motor to the receiver that controls the steering. You get variable steering and speed which makes the model much more realistic, and when you steer while moving, it is fairly smooth. I set the remotes up like this: then connected the wires like this: Like the quick attach idea very much! Brick_Sticker Edited January 1, 2015 by Brick_Sticker Quote
Paul B Technic Posted January 2, 2015 Posted January 2, 2015 LEGO Technic 42030 - MOD Road Grader Attachment Following on from my previous MOC attachments for LEGO Technic set 42030 (Volvo loader) I have recently researched and built another attachment, this is a road grader. I purchased a earthmoving trade magazine a couple of weeks ago and while reading this I can across this sort of attachment, the ones I saw were designed to be used with "bobcat" type tracked loaders, I have taken this idea and modified it for use on the Volvo loader. The idea for this road grader attachment has been on my mind for the past week or so and I did some basic design work on this last weekend, my original idea was to simply have the blade raise and lower. Yesterday I was able to get a few hours to work on starting to build this, as I was working on building it I decided to see if I could also make the blade turn from side to side, this I felt would make it much more realistic and life like. After about five hours yesterday and another couple of hours today refining some details I am happy with how this has worked out. This road grader attachment uses the standard mounting points and has two functions: - Raise / lower (This uses the bucket lift remote function) - Blade rotate (This uses the bucket tilt remote function) A video of this in use can be seen on my blog: http://paulstechnic.blogspot.com.au/2015/01/lego-technic-42030-mod-road-grader.html Quote
davidmull Posted January 2, 2015 Posted January 2, 2015 With the type of steering on the volvo does this not drag the grader left to right? Iv never seen such a set up in real life. Quote
Paul B Technic Posted January 2, 2015 Posted January 2, 2015 Sadly you are right, I never tested this with steering until you posted this. I think I might have to change this. Quote
Brick_Sticker Posted January 5, 2015 Posted January 5, 2015 Thought I'd try my hand at the quick connect, wanted to do something that's quick but fairly secure, so I made more of a quick clamp: I also made the bucket quick-attach: Then a set of forks with a headache rack: And finally a log grapple: The grapple has an m motor and a mini LA that opens and closes it, and is powered by a long extension cable that runs to a switch hidden under main hood: My $0.02, a few more pics here: http://www.brickshelf.com/cgi-bin/gallery.cgi?f=551289 Brick_Sticker Quote
Paul B Technic Posted January 5, 2015 Posted January 5, 2015 LEGO Technic 42030 - MOD - Tilting Dozer Blade I have just finished work on my latest MOD attachment for LEGO Technic set 42030 - Volvo Wheel Loader, this attachment is a tilting dozer blade. Last week I built a road grader attachment, this didn't work out as well as what I had hoped so I pulled this to pieces and used the blade from this as the basis to build this dozer blade. The remote bucket lift function lifts this and the remote bucket tilt functions tilts the blade backwards. It attaches to the Volvo wheel loader using the standard mounting points. More photos: http://paulstechnic.blogspot.com.au/2015/01/lego-technic-42030-mod-tilting-dozer.html Quote
Paul B Technic Posted January 5, 2015 Posted January 5, 2015 LEGO Technic 42030 - MOD: Lift and Carry Crane Attachment Today I have finished my latest attachment for LEGO Technic set 42030, this is a lift and carry crane. The idea for this came about from a PDF file I found on the Volvo website which showed some of the attachments which Volvo offer for this model of wheel loader. This attachment is used for lifting and carry various items such as pipes, timber and building materials. A video of this in use can be found here: http://paulstechnic.blogspot.com.au/2015/01/lego-technic-42030-mod-lift-and-carry.html Quote
